Old 05-29-2009, 02:54 PM   #4151
jasonlee4180
Member#: 152819
06 STI
Originally Posted by All4bSpinnin View Post
i still say, imo and from years of experience and having a fmic...
a subaru is not designed to run a fmic, you hack the bumper, remove the bumper beam and you have to relocate things. FMIC's typically bend your stock fuel lines and pop couplers under pressure...
5-10 less HP with no headaches and not constantly having to worry about the fmic is > actually having one imo.
sure there are plenty of people using them and they work fine, but for the kind of driving most people do, the tmic will more than suffice. When i had a fmic, i made more power, but it lagged a lot worse and the cars i used to beat, started beating me.... I got so mad with always having to tinker with it and the lag it gave and i took it off and sold it. I went back to a tmic and was happy again
unless you have a 35R+ the fmic is a waste
but again, this is my opinion w/ first hand experience
one last thing... those ebay fmic's are garbage... the fitment is mediocre at best, the relocation items are crap and do not work and you have ZERO customer support... if you get a front mount, i would highly suggest the P&L performance kit... spend the money, do it right, quit trying to bling bling with a cheap fmic
I have to agree with you on a lot of your points. If I had to do it all over again, I would've gotten a quality top mount and added heat shielding to everything in the engine bay. Seeing how many people are putting out great numbers with a Dom3 or equivalent with just a quality tmic and with awesome boost response to boot.
The only nagging issue I had with the tmic was heatsoak...unless you ran meth, you were going to heatsoak in any hot climate. That tmic would get real hot, quick after sitting at a light. Now going with a fmic, I don't have any more issues with heatsoak....now my nagging issues are increased lag and boost leak paranoia. LOL. It's a trade off...but that's with any fmic kit.
But I have to disagree that the ssac fmic is not garbage. At least, not completely . It works great for the price and perfect for the budget engine builder. It's not mechanical so why not skimp a little on this item to instead get that quality turbo, coilover, injectors, pistons, etc. that is actually mechanical. All it is, is piping and a core. So as long as it cools the charge somewhat, stays un-heatsoaked, and keeps the pressure within the pipes, I don't see why it's garbage.
jasonlee4180 is offline   Reply With Quote
Old 07-04-2009, 01:47 PM   #4152
tC2WRX
Member#: 206256
03 WRX
Yellow
anyone running this with a stock td04?
I'm planning on upgrading turbo next year.
tC2WRX is offline   Reply With Quote
Old 07-16-2009, 08:34 PM   #4153
SuperDuper
Member#: 131101
2004 AW STi
I've had an XS Power/ SSAC FMIC kit for about 2 1/2 years and its worked great..at my current power level with an 18G but now its time to upgrade to a v7 ej207 and a 35r so im looking at options to replace just the core. I have a these 2 in mind;
-Hyperflow 9"x29"x3.7"
-TurboXS 9.5"x29.5"x3.5"
Anyone else have any others that will fit on the SSAC bumperbeam and the piping?
SuperDuper is offline   Reply With Quote
Old 07-16-2009, 10:13 PM   #4154
chlnOrSlpn?
Member#: 97785
2015 WRB STi Limited
EFI Logics/CTSUBIE
can you get those cores from the manufacturer without buying the whole kit? I tried contacting TXS and no luck.
I found a Treadstone Core that would most likely fit as well as a Spearco core...
Treadstone: http://www.treadstoneperformance.com...10+Intercooler
Spearco: (need 2 reducer couplers)http://www.turboneticsinc.com/produc...&category_id=9
chlnOrSlpn? is offline   Reply With Quote
Old 07-17-2009, 12:12 AM   #4155
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
I run an SSAC FMIC on my EJ207 with a GT3076R CHRA bolt-on and it does the job for me. I'm not sure why you want to change out the core as it doesn't cause too much pressure drop across the core (which it doesn't, unless you see less than 1psi as a problem) and it keeps the charge air cool (which it does).
This kit is great value and has been used on a number of 400+whp cars now, and apart from a few fitment issues on various models (which are easy enough to fix) and the need to use the SSAC intercooler mount/support bar or cut your bumper beam, all is good.
If you want to increase cooling efficency, buy a $25 hobbs switch to activate a water spray that sprays the core whenever you pass a specific boost threshold
Unless you are going to spend top dollar on a custom FMIC kit with a high flowing bar and plate core that is highly efficent, then I wouldn't bother as the performance benefits of going to another cheap core will be marginal at best.
Leslie.
wrxsti.l is offline   Reply With Quote
Old 07-17-2009, 01:44 PM   #4156
TracktionControl
Member#: 216732
Wait until you get you get a bigger turbo^. I run a fp20g with an ssac fmic.Works good. Boost kicks in @3700rpms. People spend good money on big turbos, so why not protect your investment with a fmic? Tmic's=heat soak.Last i checked this is bad for the turbo correct? The key to all this is a good tune by a good tuner.
TracktionControl is offline   Reply With Quote
Old 07-17-2009, 05:58 PM   #4157
SuperDuper
Member#: 131101
2004 AW STi
Leslie.
Im not really concerned with the pressure drop on the SSAC fmic, i'm mostly concerned with the cooling ability of it, have you taken a look inside? The fin density compared to other units, for example the TurboXS unit, is half. So if your running one and making 420whp its posible you could be at 435 or more with a better unit.
I guess I could get an intercooler sprayer as a band-aid to make up for cooling efficiency, but thats not what I want.
Old 07-17-2009, 07:50 PM   #4158
chlnOrSlpn?
Member#: 97785
EFI Logics/CTSUBIE
Get Meth that is what I plan on doing...if it doesn't hold up then well, I'll source a core.
I'm at 355/362 with a 30R .63 a/r on a Mustang Dyno....hoping to break 400 with meth.
Old 07-17-2009, 08:02 PM   #4159
SuperDuper
Member#: 131101
2004 AW STi
Meth will be part of my setup...and maybe E85
Old 07-18-2009, 09:07 AM   #4160
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
First thing I did when I got it - but it does it's job perfectly fine and that is all I really care about.
Just because one core has more fins, DOES NOT mean it will allow you to make more power. In actual fact, the higher the fin density, the more restriction there is and the higher the pressure drop across the core.
I'm not saying more fins is a bad thing, as it could increase cooling efficieny and possibly allow you to run more boost safely - but rather the higher the fin density the higher the pressure drop is across the core.
Also, even if I did get a turbo xs core, I don't see it is being able to increase my whp as you suggest if boost remains the same
lol, nice twist of words. As I said, many ppl use the SSAC on cars making well over 400whp, some with their GT35s too - and none need a water spray lol.
I only suggested a water spray as a cheaper alternative to a full custom intercooler using a top quality bar and plate core, not as something that is required if you buy the SSAC fmic kit.
Leslie
Old 07-18-2009, 02:50 PM   #4161
TracktionControl
Member#: 216732
I just don't think people can get over the fact that ssac works great and is hella cheap.My main issue with this product is that i had to spend a lil extra to get the pipes to fit right.And I had a heavy duty bracket made, because the one it came with is a flimsy peice of ***t.
Old 07-18-2009, 10:54 PM   #4162
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Yeah, if the manufacturer isn't plastered all over their fav JDM suby or found as a decal in Forza or Need for Speed, then it must be crap .
It has been pointed out all through this thread that there can be a few fitment issues between models, but the kit is cheap and the fitment issues are nothing a home handyman couldn't sort out.
Old 07-20-2009, 06:42 AM   #4163
06WRBScoob
Member#: 182439
Has anybody heard of any for sale, been trying to get the "nasioc special" for a while now.
06WRBScoob is offline   Reply With Quote
Old 07-20-2009, 08:36 AM   #4164
eatus ravenous
Member#: 26068
without looking at this entire thread . can anyone give opinion of fit on a 07 wrx ? also what is the nasioc price ? thanks
eatus ravenous is offline   Reply With Quote
Old 07-21-2009, 07:19 PM   #4165
06WRBScoob
Member#: 182439
any of these available anywhere?
Old 07-21-2009, 07:54 PM   #4166
vms150
Member#: 172917
2004 WRX
there is a huge wait on these. Just look a few pages back and there is contact info for who in the company to order with.
vms150 is offline   Reply With Quote
Old 07-21-2009, 11:17 PM   #4167
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
I have helped install a few and there were minor fitment issues. They did however work. Call me a brand whore if you like but I still wouldn't run one my car.
I can say a lot of the locals have ebay parts, and usually more "parts" than me, yet I always seem to be faster..... hmmmmm.
Thats not to say you couldn't use pipe work, downpipes etc. I just dont trust anything more complicated than bending some pipe to the knock off shops. IC cores & turbos? No F'in way.
As always YMMV.
BVM is offline   Reply With Quote
Old 07-22-2009, 01:21 PM   #4168
Dizzuque
Member#: 98699
2007 SWP WRX
Yes it will fir the 07 wrx with no problem because i had one on my 07. I think the nasioc price is somewhere around 300 shipped.
Dizzuque is offline   Reply With Quote
Old 09-13-2009, 02:44 PM   #4169
oly kenji
Member#: 211299
2005 STi
going into 2001 gc
what sort of power are people making with this kit? anyone in the 350 range?
oly kenji is offline   Reply With Quote
Old 09-14-2009, 02:10 AM   #4170
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Using one of the cheap big ass FMIC.
Using this K probe device....
Ambiant temp was 82 degrees @ 9pm......
Cruising the pre IC temp is about 95ish, post is 85ish....
Get on the loud pedal.....
100, 110,120,130,140,150,160,180,------ At 4500 rpm the temp goes over 200 and I forgot to set it to read higher.
But Post IC? Highest was about 95.
Thank goodness for the intercooler!!!!!!
I drove around today with just 1 probe in the INLET to the turbo. Just the air entering the turbo was 150 degrees or warmer!!!!! If I would get off boost and the BOV would vent, then the temp would bump up to 170ish from the burst of air out of the turbo.... I really really want to reroute my IC pipes so I can get the cone filter OUT of the engine bay and into the fenderwell!!!!!
At the track tonight I compared the two.
Hotside of turbo = 370 f!!!!!!!!!!!!
Throttle body = 96!!!!!!
Later I was hiting much higher temps coming out of the turbo, like 400-500f! But post IC was just 110 or so....
Old 09-14-2009, 11:05 AM   #4171
mls1
Member#: 167607
2008 WRX
Good info.
mls1 is offline   Reply With Quote
Old 09-21-2009, 09:24 AM   #4172
Dstretch33
Member#: 157211
2k4 stg. 2 WRX sti
I'm buying a used kit. Are all the ic pipes and required couplers show here?
Dstretch33 is offline   Reply With Quote
Old 09-21-2009, 11:21 AM   #4173
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
That doesn't look like SSAC piping mate.
If it is, then it has been cut in a few places, so I'd make sure those places where it has been cut have had the lip rolled again.
Also, not one of my piping pieces had a weld on it, they were all bent to the shape required and had couplers for joining - I notice that one of the pipes in the pick has been cut and rewelded!
Leslie
Old 09-21-2009, 05:06 PM   #4174
torinalth
Member#: 141720
2005 LGT 5MT Sedan
Satin White
correct me if I am wrong, but it looks like it was redone to do a counter clockwise flow.... notice the sharp bend at the bottom of the one pipe with the sharp radium coupler... looks like the reverse style of the slow boy racing FMIC.... but yeah... it is not stock SSAC, pipes.
T
torinalth is offline   Reply With Quote
Old 09-21-2009, 09:34 PM   #4175
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Possible, but I still doubt it is an SSAC fmic kit.
The SSAC piping can be installed for clockwise and counter clockwise flow without the need to cut any pipe - it is a simple as disconnecting the the pipe piece that connects to the throttle body at the throttle body coupler end and moving/twisting it to the turbo comp outlet coupler and then moving/twisting the pipe that connected to the turbo comp outlet coupler over to the throttle body coupler.
I still think it is a different piping kit.
Leslie
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 03:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 02:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 01:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 546 12-16-2005 11:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 07:01 PM
