Old 01-01-2006, 08:12 AM   #51
SolidSnake
Member#: 74034
2004 426whp 403wtq
Top Speed Tuned STi!
Originally Posted by TypeC
All done: INSTALLED PIC
Link doesn't work..
SolidSnake is offline   Reply With Quote
Old 01-01-2006, 11:57 AM   #52
complacent
Member#: 51370
a tostr, a yamie
DCAWD
Originally Posted by Bird61780
What did you use to paint it?
High-temp radiator paint. You can find it at almost any auto parts store. Just make several *reeeely light* passes so you don't over-cover any areas.
complacent is offline   Reply With Quote
Old 01-01-2006, 12:07 PM   #53
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Originally Posted by SolidSnake
Link doesn't work..
Sorry, the link has been fixed: INSTALLED PIC
That was a quick one at night, I'll take some day shots today.
TypeC is offline   Reply With Quote
Old 01-01-2006, 03:03 PM   #54
Freon
Member#: 88322
2009 BMW 135i
Originally Posted by garie
are the real turboxs fmics made in china too? I wouldn't be suprised if the fmics are made at the same factory, from the same supplier.
Nathan from TXS posted about this in the previous thread (see link in post #1). He said they are not from the same source.
Freon is offline   Reply With Quote
Old 01-01-2006, 07:55 PM   #55
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Ok, daytime:
Old 01-01-2006, 08:44 PM   #56
Freon
Member#: 88322
2009 BMW 135i
Looks great. Can you post a closeup of your BPV setup? I had to use a bent pipe to make mine fit. It works fine for me, but I'm curious how others solved the problem. Did you use the stock dump pipe (between BPV and turbo inlet hose?)
Old 01-01-2006, 09:28 PM   #57
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Yes, I reused the stock return pipe. I spun the BOV aroud. Here is a pic: BOV PICTURE
There are two more pics in that same directory.
Old 01-03-2006, 11:02 AM   #58
mooserider
Member#: 79655
Mine arrived while I was on vacation. Haven't had a chance to dig into it yet, but I am very impressed with the packaging and the apparent quality of the parts. Thanks to Freon for the writeup/pics; I ordered the BPV flange off ebay this morning since I want to reuse the stocker. Also found a 2.75-2.5 coupler for $14+ship there... can't wait to get it all together!
mooserider is offline   Reply With Quote
Old 01-04-2006, 05:00 AM   #59
WrXwaBBit
Member#: 33296
hey type-c where did you get your flange that bolts to the stock bov? i am planing on using the stock bov when i get this fmic.
WrXwaBBit is offline   Reply With Quote
Old 01-04-2006, 06:52 AM   #60
mooserider
Member#: 79655
I found the flange on ebay... it's a TurboXS one. Look in Freon's link, he has a text file describing what he did.
Old 01-04-2006, 08:08 AM   #61
mastershakewrx
Member#: 80120
2002 Wrx sedan
MBP
is the turboxs adapter plate made of SS or aluminum? im wondering if u can hav it welded on for a cleaner install.
mastershakewrx is offline   Reply With Quote
Old 01-04-2006, 09:36 AM   #62
STI_FFY
Member#: 37519
2004 STi JBP/Gold
Helix DP, SMC, Cobb AP
Those who've installed this FMIC - do you notice any increased lag as a consequence of all that extra piping and larger volume of the I/C - or does it seem to spool up at a similar rate to stock?
STI_FFY is offline   Reply With Quote
Old 01-04-2006, 10:05 AM   #63
complacent
Member#: 51370
a tostr, a yamie
DCAWD
On a 2.5l motor, it seems to spool up pretty darn close to stock (i.e. I don't notice the difference in spool at all). And even if you do trade maybe 200-300rpms for the increase in cooling ability - it's totally worth it imho. The amount of advance you can add (in addition to headroom for larger turbos ) is a solid win.
Old 01-04-2006, 10:40 AM   #64
STI_FFY
Member#: 37519
2004 STi JBP/Gold
I'm chemically intercooled, so there's not much advantage there for me. I am interested primarily because it would make it possible to eliminate the hood scoop and go stealthy.
Old 01-04-2006, 10:47 AM   #65
complacent
Member#: 51370
a tostr, a yamie
DCAWD
+1 for that idea. I've been looking into getting a JDM RS hood (Alminium AND scoopless) but it's pretty pricey.
Teh wallet is going to get pwnd again this year, I can already see it coming.
Old 01-04-2006, 03:32 PM   #66
Freon
Member#: 88322
2009 BMW 135i
Subjectively I have noticed a slower response with the stock VF39. I am working on retuning the car now and will post some logs and graphs once I'm finished.
Boost threshold in higher gears is about the same, but I do notice actual delay lag, even at high RPM. I think this is to be expected since the whole IC volume has to be pressurized. Total IC volume is easily 3-4x more. I also generally expect the car to be slower until I get a new turbo.
Old 01-04-2006, 06:16 PM   #67
WrXwaBBit
Member#: 33296
so what does the kit comes with? look at ebay for this item and doesn't list the parts it comes with. And what do i need to fit this on my wrx beside the 2.75 to 2.5 coupler.
Old 01-04-2006, 09:07 PM   #68
SolidSnake
Member#: 74034
2004 426whp 403wtq
Some sort of coupler for your BPV or BOV( I got a hose today for mine at Autozone), some minor screws and washers, and a 2.5"-2-75" coupler.
I STRONGLY SUGGEST NOT TO PURCHASE FROM: X02 RACING on Ebay, I was shipped the wrong size coupler, and they won't refund me or send me the right size coupler untill they recive the original one they sent me. It took 11 days just to get the wrong size coupler, and now they want me to ship it back at my expense .
Old 01-04-2006, 10:03 PM   #69
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
I had my welder fab and tig it up while I waited.
Old 01-04-2006, 10:07 PM   #70
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
The part throttle and daily driving response is exactly the same. I too am on VF39 and 2.5L, although I'm running higher CR (8.78:1) which helps. When I floor it from a low rpm in 4th and log the boost onset is just about the same (17psi at 2900-3000rpms).
There isn't any "lag" but there is a delay when going from vacume to WOT. You hear the turbo whine, wait a split second, then BAM it hits you in the back. It's pretty fun.
Old 01-05-2006, 10:58 AM   #71
mooserider
Member#: 79655
Well, I installed the short ram yesterday, and had to tweak the MAF hole on one side a bit for it to fit. Five seconds with a dremel, nothing worse.
While I am waiting for the 2.5-2.75 coupler and BOV flange to arrive, I was hoping to install most of the kit in advance... I noticed I am supposed to re-use the TMIC mounting bolts. Anybody have the specs on those handy so I can get a couple from the hardware store? If not, I'll pull one out and check thread pitch/diameter/length... not a big deal!
Old 01-05-2006, 11:07 AM   #72
SolidSnake
Member#: 74034
2004 426whp 403wtq
Use the TMIC bolt where?
Old 01-05-2006, 11:09 AM   #73
mooserider
Member#: 79655
Reading the instructions, it says to use the 2 bolts 'retained from step "remove factory intercooler"' to secure the FMIC... I haven't started anything yet so just going by the doc on their site.
Old 01-05-2006, 11:24 AM   #74
SolidSnake
Member#: 74034
2004 426whp 403wtq
Oh, I didn't get any instructions, or see a need for any bolts, except for the new radiator catch can to mount it.
Old 01-05-2006, 01:15 PM   #75
Bird61780
Member#: 58967
They want you to use the intercooler bracket bolts in the top of the core where that one rectangle with the threaded holes is welded on.
Bird61780 is offline   Reply With Quote
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 02:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 01:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 12:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 546 12-16-2005 10:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 06:01 PM
