Old 08-20-2006, 10:55 PM   #926
Bolster
Member#: 22290
2002 WRB WRX Wagon
Originally Posted by EmsTrauma
Ok im about to order mine and there are 900+ post what i need to know is with an 03 wrx what 90 degree is wrong. Where can i get the adapter so i can run the stock BPV( for now) and what is everyone using for intakes. and are you keeping the fog lights on an 03.
Yes i rel;ize it was already covered somewhere in the 900 post but help me out with the cliff notes version and also if anyone else happens to come in at the end.
TIA
The elbow in question is the 90 degree elbow coming off the compressor to the hot-side of the piping. It's too big on the turbo-side, but some have managed to clamp it down with standard hose clamps.
Bolster is offline   Reply With Quote
Old 08-20-2006, 11:03 PM   #927
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
Originally Posted by subieracer18
update:
The ssAuto Fmic works on the 06 wrx! We installed the fmic kit on my friends 06 yesterday and has been running fine ever since. The fuel line part is a tight squeeze but with some coaxing it works. We're going to start trimming the bumper tomorrow and we'll post some pics during the process.
Great newS!!!!!!!
PLease post those pics and let us know how you got around the fuel line issue.
UndertoW101 is offline   Reply With Quote
Old 08-21-2006, 12:35 AM   #928
WRX-ERROR
Member#: 83211
2002 WRX - stg4
TIA
Try checking out my 1st post.. It's a FAQ with all the info you need.
WRX-ERROR is offline   Reply With Quote
Old 08-21-2006, 01:57 AM   #929
shortyswrx
Member#: 107390
2006 WRX
update:
sweet! been wondering if its gonna fit. i know they had problems with the turbo xs fmic. like to see pics of how you guys fit it around that trouble spot ... high pressure lines.
shortyswrx is offline   Reply With Quote
Old 08-21-2006, 01:49 PM   #930
epaplia
Member#: 91076
2006 WRX
<<<<<<<<<<<<<<< This guy did
epaplia is offline   Reply With Quote
Old 08-21-2006, 02:18 PM   #931
subieracer18
Member#: 72904
the problem with the high pressure line is that it site too high. All we did was bend the lines down a little bit and the pipe fit. NO there are not any fuel problems or anything. I'm sure if you wanted to you could but some extra fuel line and make it fit better.
subieracer18 is offline   Reply With Quote
Old 08-22-2006, 01:43 AM   #932
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
You should post some info/pictures on this thread
http://forums.nasioc.com/forums/show....php?t=1057944
"The Turbo XS FMIC, which comes with black and white photocopied instructions (using pics of the bugeye model), needs more room for the piping than the 06 has. The fuel lines, which the instructions say to move arenít flimsy like in the older models, they are solid fuel lines that canít be moved. There was no way to fit this piece in"
post # 10
http://forums.nasioc.com/forums/show...8&postcount=10
Old 08-22-2006, 10:56 AM   #933
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Its going to be a tight fit but I'm pretty sure I can fit a CAI with in the fender well. I'm going to make my own and it should cost less than $20 (plus $25 filter).
BTW- This FMIC is awesome! Everything fits perfect and I'm very pleased the way it turned out.
R0DENT is offline   Reply With Quote
Old 08-22-2006, 08:38 PM   #934
shortyswrx
Member#: 107390
2006 WRX
bump ... for pics on the 2006 wrx
Old 08-22-2006, 10:21 PM   #935
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
Bump for LOTS of pics of it on the 06 wrx
Old 08-23-2006, 01:00 AM   #936
bgod
Member#: 100274
Does anyone have any issues with the coolant reserve tank. I looked at my stock unit and there is no air bleed hose which most cars do have. Now my cap on the provided reservoir seems to be leaking a bit because of possibly too much heat/pressure???
Has anyone tapped a hole and line into the reservoir or is everyone running just what they provided.
Any help would be appreciated.
bgod is offline   Reply With Quote
Old 08-23-2006, 01:02 AM   #937
bgod
Member#: 100274
Btw guys.
I've had the fmic installed for a couple of weeks now. Car turned 360whp at 22psi and 380wtq with my 20g on my 05 sti. Car runs fantastic.
However, the upper pipes do heat soak. There is no avoiding this with this kit. If I experience it I know others must as well.
Hopefully some wrap will cure the problem or at least help. If not, I'll be replacing the upper pipes in the engine bay with aluminum units.
Old 08-23-2006, 01:14 AM   #938
modaddict
Member#: 95840
sold to a good bud
awaiting next car
avoided:
Originally Posted by bgod
Btw guys.
modaddict is offline   Reply With Quote
Old 08-23-2006, 01:29 AM   #939
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Just punch a small hole in your cap. Other people have done this and it resolved this issue.
Old 08-23-2006, 06:03 PM   #940
kite_tmr
Member#: 83912
1998 BD STi
10cm DOM3
I ordered two of these kits. The box came and all that was in it was two cores, nothing else. Very dissapointing. I just emailed them to find out whats up. I hope they are not gonna try and scam me. I'll post the results...
kite_tmr is offline   Reply With Quote
Old 08-23-2006, 11:31 PM   #941
benw
Member#: 103320
1998 swapped
Forester L
you should have gotten two large boxes, each one containing 2 boxes, one is the core and one is the tubes and other parts. sounds like an easy mix-up to make.
benw is offline   Reply With Quote
Old 08-24-2006, 05:34 PM   #942
Scoobafied
Member#: 122211
2005 Wrx Sti silver
1998 BMW 5series 5mt
Default SSAUTOCHROME fmic
Just got mine in on WED. Ordered on sunday. Got all the parts except there was no stoke bov adapter, no big deal got it from ebay for 15 bucks.
Scoobafied is offline   Reply With Quote
Old 08-24-2006, 09:52 PM   #943
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Yea none of them come with the adaptor.
BTW anyone have any hood clearance issues? I found out I couldn't shut my hood this evening The hot pipe is sitting too high but is already as far down as it will go. Is the removal of the splitter required? I just thought of that after I got in for the evening. Here is a pic:
Also a note about removing the TMIC bracket on the drivers side: the two bolts that come off the intake manifold might BOTH go back on otherwise you might induce a vacuum leak. There are pin sized holes in the bottom that go all the way through on some intakes. You can see in the pic that I put both back in even though only one is used for the bracket.
I also noted a few things. Its not a perfect fit to keep the foglights in the bugeye but its not that far off. I also had no problem just lowering the fuel filter and I didn't have to use the hose that I bought. I got 1.25" ID hose for the BOV adaptor but I think someting like 1.175 would be more appropriate. Nothing else stands out in my head as being important.
cdvma is offline   Reply With Quote
Old 08-25-2006, 10:45 AM   #944
WRX-ERROR
Member#: 83211
2002 WRX - stg4
cdvma I wasn't able to use that L bracket and close my hood on my 2002. Once I removed the L bracket and lowered the fuel filter i was able to lower the pipe enough to clear the hood.
Old 08-25-2006, 10:53 AM   #945
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
After I took those pictures I removed the bracket. Still no luck but I only tried for about 30 seconds. It seems to have plenty of room around the fuel filter but not next to the oil cap/battery/ac line. I'll take a peek today or tomorrow and report back.
Old 08-25-2006, 10:58 AM   #946
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
Originally Posted by cdvma
Also a note about removing the TMIC bracket on the drivers side: the two bolts that come off the intake manifold must BOTH go back on otherwise you might induce a vacuum leak. There are pin sized holes in the bottom that go all the way through. You can see in the pic that I put both back in even though only one is used for the bracket.
Although I havent checked myself, I find it very hard to believe that there is a hole that passes through the intake manifold there... and the entire pressurized system of the car is reliant on a couple bolts being threaded in tight. That wouldnt make a seal regardless.
As for the L bracket, I cut the long end of mine a good amount shorter and redrilled a hole for it, so instead of a long side and a short side they are both just about the same size now. It helps to hold my IC piping down a bit over there and helped the piping clear my hood. Without the bracket the piping was definitely rubbing my hood and it took more effort to close my hood as well.
Bryan
TROLL is offline   Reply With Quote
Old 08-25-2006, 10:59 AM   #947
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Check it out then
Some of the holes on the intake manifold do have pinholes in them.
Old 08-25-2006, 11:17 AM   #948
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
so subaru wanted there to be a dozen or so extra places for potential leaks just because? i'll check it out but gotta tell you, i'm still really doubtful.
Old 08-25-2006, 06:25 PM   #949
benw
Member#: 103320
1998 swapped
Forester L
I finished my install last night. Everything went together like a dream. This thread contains all the info I needed except ONE thing. The crank case vent line comes with a T, which is fine. However I cannot figure out how you're supposed to connect their new line to the driver's side crank case vent without some kind of male-to-male connector.
Old 08-25-2006, 06:33 PM   #950
tasq
Member#: 62362
2005 wrx
CGM
You replace the drivers side with the new hose that came with your kit. It is long enough to reach the T
tasq is offline   Reply With Quote
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 02:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 01:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 12:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 546 12-16-2005 10:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 06:01 PM
