Old 09-22-2006, 05:56 PM   #1126
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Freon nice setup but it's gotta be said.. CLEAN YOUR DAMN ENGINE BAY.
WRX-ERROR is offline   Reply With Quote
Old 09-22-2006, 06:22 PM   #1127
kenny08
Member#: 79907
02 blue wagon
18g goodnesss
freon can u explain what u did with your intake setup? seems like a perfect spot to pull in cool air...
kenny08 is offline   Reply With Quote
Old 09-22-2006, 06:38 PM   #1128
Bolster
Member#: 22290
2002 WRB WRX Wagon
I don't think he did anything with the setup. That's how the Perrin rotated kit is.
Bolster is offline   Reply With Quote
Old 09-22-2006, 06:45 PM   #1129
kenny08
Member#: 79907
02 blue wagon
18g goodnesss
wow im blind, usually perrin rotated kits look alot bigger..
Old 09-23-2006, 01:23 PM   #1130
JiveMasterT
Member#: 116666
2011 STI Limited
Looks nice, plays dirty
Originally Posted by cdvma View Post
Yea but putting it on the hot side of the IC could expose it to really high temperatures. If you are going to use the IAT sensor for speed density that is a really poor place for it. It needs to be on the cold side.
It's fine. I know of a few people with setups like that. Ideally, you want your MAF as close to the throttle body as possible so you get the most accurate reading EVEN with boost/vac leaks. That means you can also vent your BOV so you don't dump air that has been previously heated by the turbo back into the intake tract.
If your intake temps are high enough to affect the MAF then you need to start looking at why they are so high and fix that.
JiveMasterT is offline   Reply With Quote
Old 09-23-2006, 07:06 PM   #1131
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Read the post; its not the MAF I'm talking about! Its the IAC attached to the MAF that should not be on the hot side. The intake temps on the hot piping is WAYYYY higher than it is on the cold side. There is no problem with that, its just what happens. If the temps were appropriate for intake on the hot side you wouldn't need an intercooler!
Speed density relies on a very accurate temperature measurement and the hotside is not ideal. A 30*C difference can result in a density difference great enough to induce serious error.
cdvma is offline   Reply With Quote
Old 09-23-2006, 09:04 PM   #1132
Bolster
Member#: 22290
2002 WRB WRX Wagon
This is precisely why I was talking about moving the MAF to the cold side. I could "un-reverse" the flow of my piping and then get one of those thermo-tec sleeves I guess, but I think I like it how it is.
Old 09-28-2006, 10:56 PM   #1133
purreplayya69
Member#: 113379
2005 STi
crystal gray/Gold
what intakes work with this kit???
purreplayya69 is offline   Reply With Quote
Old 09-28-2006, 10:58 PM   #1134
tasq
Member#: 62362
2005 wrx
CGM
tasq is offline   Reply With Quote
Old 09-28-2006, 10:58 PM   #1135
purreplayya69
Member#: 113379
2005 STi
crystal gray/Gold
theres to many pages to even look lol
Old 09-28-2006, 11:25 PM   #1136
purreplayya69
Member#: 113379
2005 STi
crystal gray/Gold
anyone know what shortys work with the kit??
Old 09-29-2006, 12:02 AM   #1137
tasq
Member#: 62362
2005 wrx
CGM
Do you expect to be spoon fed? Search the thread for "intake"
Why are people so lazy these days?
Old 09-29-2006, 12:10 AM   #1138
Bolster
Member#: 22290
2002 WRB WRX Wagon
Unfortunately, the only shorty intakes that work with this kit are manufactured in Burma. As you probably have guessed, they are made from recycled soda cans there. There is only one shipment each year coming on a very slow boat, which usually arrives in December. Once it clears customs, the only distributer (SuperTyteRacing) puts them on ebay, where bidding wars often bring the price to over $5000! Sometimes you can find them for sale here in the classifieds. Just do a seach for "SuperTyteRacing intake".
Old 09-29-2006, 12:12 AM   #1139
tasq
Member#: 62362
2005 wrx
CGM
Old 09-29-2006, 10:26 AM   #1140
kite_tmr
Member#: 83912
1998 BD STi
10cm DOM3
I know tasq was loving this one...LOL
kite_tmr is offline   Reply With Quote
Old 09-29-2006, 11:14 AM   #1141
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
lots of pages here...
Will this work with a VF39, STi injectors, and the VF34 maps from Cobb? I know it says stock intercooler and VF34, but I don't see how the FMIC should adversely affect the tuning, and as for the 34/39 thing, I have read they are about the same in power, just a few slight differences...
Matth3w is offline   Reply With Quote
Old 09-29-2006, 11:15 AM   #1142
tasq
Member#: 62362
2005 wrx
CGM
You answered your own question
Old 09-29-2006, 11:16 AM   #1143
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
dont be a dickhead. it has also been stated within the first 7 pages that adding the FMIC to the stage 2 wouldnt cause a problem at all, except maybe a bit of lag. so i was asking about with the new turbo/injectors.
Old 09-29-2006, 11:20 AM   #1144
tasq
Member#: 62362
2005 wrx
CGM
You going to trust them or cobb? It also says stock intake... Can you use the stock intake with a FMIC? NO.
It's your car bro! I wouldn't run an OTS map with different mods than it was created for. If you had done any research at all you'd agree. The short ram and front mount change the tune quite a bit.
Do it right or don't do it at all.
Old 09-29-2006, 12:47 PM   #1145
benw
Member#: 103320
1998 swapped
Forester L
it's funny you say that because I was looking at IAT scaling, and the front mount works so well, combined with an open air filter, the car is surely going "WTF" from the 150+ temps going past the MAF then ambient temps going into the TB. Retune for sure.
benw is offline   Reply With Quote
Old 09-29-2006, 03:57 PM   #1146
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
edit:nm
Old 09-29-2006, 07:14 PM   #1147
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
got a better link for the adapter? i keep getting a page not found
Old 09-29-2006, 08:50 PM   #1148
boozy04
Member#: 87034
08 Stg2 9.5's 275s
SSM
dont be a dickhead.
I thought that was a pretty reasonable answer?
boozy04 is offline   Reply With Quote
Old 10-01-2006, 07:55 AM   #1149
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
Originally Posted by BugeyeWagon View Post
anyone have problems with the couplers and clamps popping off when redlining ?
I was wondering if the OP can update this trick in the first post since it seems to be a bit of a frequently asked question (and as of page 8 I havent seen a really good answer):
When you are putting your IC pipes on and before you clamp them down, coat the pipe and the inside of the rubber withn aresol hairspray. This is the trick I used when I was putting together both of my turbo kits on my Mazda. The hairspray lubes it up but when it dries creates an excellant seal. When I took my turbo kit apart I had to damn near put the **** in a vice to get it off, and never once had IC piping pop off.
Old 10-01-2006, 10:27 AM   #1150
Bolster
Member#: 22290
2002 WRB WRX Wagon
I painted my tubing black, so maybe the paint has been helping to provide some "stick". The only times I had hoses blow off were immediately following the install. I think it was more a result of me not lining things up than a result of clamps not being tight enough. Now that it's all lined up, I'm hitting 17-18psi and not having any problems at all.
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 02:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 01:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 12:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 546 12-16-2005 10:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 06:01 PM
