Old 01-16-2006, 08:56 PM   #101
yoojeankim
Member#: 69866
2005 WRX STi
CGM
can some1 post more fmic pictures on 04-05 wrx. or STi's cuz yeah i wanna see how much of the core shows on the 04-05's...
if it was on a sti wud help much for me cuz i got 1 ... thx =D
yoojeankim is offline   Reply With Quote
Old 01-16-2006, 09:22 PM   #102
Freon
Member#: 88322
2009 BMW 135i
There are lots of pics in the original thread (linked in post #1). Several 04-05's.
I found the source of the 7 count I saw. I maxed out my injectors. Whoops. I'm going to say in general the car is running "safer". I don't even see the occasional 1 count I used to get. I'm still running a bit rich (low-mid 10's), but I was before as well. And it's also winter here, thus colder air (although its been in the 40's the past few weeks). I haven't tried logged intake temps. I'm curious to see how bad they really get. I don't have any logs from before to really compare, anyway.
I do have a clunk I need to track down which I think is the IC pipes. I get it when I start the engine and if I spike the throttle at high rpm. I'm going to see how high up I can get the piping to run from the TB to the passenger side because I want to use the Perrin GT-R kit with it. Right now my IC piping would interfere with the intake that kit uses.
Freon is offline   Reply With Quote
Old 01-18-2006, 10:53 PM   #103
yoojeankim
Member#: 69866
2005 WRX STi
CGM
for those who got the FMIC, and are u using stock BOV. what do u need?
Old 01-19-2006, 08:02 AM   #104
Bird61780
Member#: 58967
You need to buy a TurboXS style BOV flange, bolt it backwards to the bypass valve, then get a hose to connect the outlet on the I/C pipng to the inlet on the flange that you bolted to the bypass valve.
Bird61780 is offline   Reply With Quote
Old 01-19-2006, 11:52 AM   #105
Freon
Member#: 88322
2009 BMW 135i
yoojeankim: have you read this thread? I think it might be a good idea... I posted pretty detailed pictures of my BOV setup which should answer all your questions. TypeC also posted pictures of his BOV setup which also uses the stock piece.
Here's the link again, writeups and pics, etc.:
http://freon.shackspace.com/car/fmic
I'm curious, did anyone else have problems with the MAF housing? My screw holes did not line up. I had to very slightly bore out the two small screw holes in my factory MAF doohickie to make it screw into the included shortram/MAF adapter. Someone in the old thread mentioned this (rather, PMS'd about it), so I'm assuming its just off on all or most of the kits. It is not bad, as there is a washer on the screws and the screws don't create the seal (there is an O-ring on the shaft). But, it is worth mentioning so you don't get too surprised when it doesn't fit perfect out of the box.
Old 01-19-2006, 12:36 PM   #106
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
ok, if i am running a Cobb stage 2, will it be safe to hook up the FMIC?? or do i need to wait till i get a street tuner and get it dyno tuned??
Twiztidunreal is offline   Reply With Quote
Old 01-19-2006, 12:52 PM   #107
elucas730
Member#: 42714
'07 BMW 335i E90
I put on a new turbo and the fmic at the same time and ran cobb stage 2. Granted, I stayed out of boost as much as possible and never went above 5 psi. So, yes, it can be done.
elucas730 is offline   Reply With Quote
Old 01-19-2006, 05:23 PM   #108
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Yes, I had to drill out the hole just a HAIR (maybe 1mm).
You will be fine. The AFR didn't change much (thanks to MAF).
TypeC is offline   Reply With Quote
Old 01-21-2006, 03:01 AM   #109
yoojeankim
Member#: 69866
2005 WRX STi
CGM
yeah i read all pages... trust me
im just trying to make sure before i buy =) KK? cant ppl double check =D
Old 01-21-2006, 03:10 PM   #110
Freon
Member#: 88322
2009 BMW 135i
Two more pics. I added some sticky back gasket material to keep the intake from hitting the fender and the IC piping. I had a clunk whenever the engine was torquing.
http://freon.shackspace.com/car/fmic/intakebuffer1.jpg
http://freon.shackspace.com/car/fmic/intakebuffer2.jpg
I also raised the passenger side IC piping higher to get a feel for how it will work once I get my rotated kit. I moved all the wiring and vacuum hoses below the IC pipe, raised it up a bit, and retightened the clamps to help hold the pipe higher.
Old 01-21-2006, 11:20 PM   #111
yoojeankim
Member#: 69866
2005 WRX STi
CGM
can't wait to get it =)
Old 01-23-2006, 08:41 PM   #112
JayZ28
Member#: 90590
2005 STi
Quick shot of my "stealth" fmic core:
This is going on an OBP STI so it'll be well hidden, but still thinking about screening on a large pink STI logo in the middle though.
-Jay
JayZ28 is offline   Reply With Quote
Old 01-24-2006, 09:13 AM   #113
mooserider
Member#: 79655
Hey stealth buddy. OBP wagon here.
mooserider is offline   Reply With Quote
Old 01-24-2006, 09:32 AM   #114
STI_FFY
Member#: 37519
2004 STi JBP/Gold
Helix DP, SMC, Cobb AP
Default Photo details of bumper removal etc?
My 04 STi was in an accident about a year ago, and I swear the shop did not put something together right in the front bumper area. I was wondering if one of you who has done this FMIC conversion might have a detailed photo record of the process which would show me all the support bracketry and what not that's supposed to hold the bumper to the body?
Thanks in advance, and sorry for the hijack...
STI_FFY is offline   Reply With Quote
Old 01-24-2006, 09:41 AM   #115
mooserider
Member#: 79655
I might have a high res pic at home... if nobody else posts one, I will see if I can dig it up tonight.
Old 01-24-2006, 10:11 AM   #116
yoojeankim
Member#: 69866
2005 WRX STi
CGM
moose what u paint ur FMIC with to get it black
and also do u have more pics of it complete with bumper on
Old 01-24-2006, 10:13 AM   #117
yoojeankim
Member#: 69866
2005 WRX STi
CGM
o and just wondering has any1 contacted deedee lately? im not receiving any emails back.
Old 01-24-2006, 04:46 PM   #118
ravi
Member#: 37597
2004 STi w/fp green
shameless plug- i have a bov (turbxs rb34 knockoff) that will fit the Ic piping for cheap. also 2 intakes that will work with the fmic, pm me if anyones interested
BTW- the connectors that they give you with the kit are crap, they are too short. I replaced all of them with much longer silicone sections... no blowouts!
ravi is offline   Reply With Quote
Old 01-24-2006, 10:46 PM   #119
yoojeankim
Member#: 69866
2005 WRX STi
CGM
also... if any1 has 1... and was thinking bout selling it ! pm me
SSautochrome is out of stock rite now
Old 01-25-2006, 01:41 PM   #120
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
No, I think your install is crap. They all fit perfectly fine for me. You don't want to have any gaps between hardpipes inside of the coupler. They are long enough to join the pipes and have at least 1" beyond the clamp (which is set after the pipe bead). The couplers are reinforced and very good.
Old 01-25-2006, 02:07 PM   #121
Freon
Member#: 88322
2009 BMW 135i
All my hoses worked fine. I left a small gap (1/4-1/2") between the pipes in the hoses so they wouldn't hit each other due to some minor flexing. They are plenty long, that's for sure.
Old 01-26-2006, 12:30 AM   #122
srxboy
Member#: 80351
2002 subaru wrx
I agree, all my hose worked perfectly and I also left a little gap between pipes. Is ssautochrome really out of these kits again? Glad I bought mine when I did. Last time they were out for like 2-3 months.
On the painting topic if you want to paint your intercooler black you have to use a radiator type paint that is made to transfer heat, regular paint will trap the heat in and defeat the porpuse of your new intercooler. Just my o2.
srxboy is offline   Reply With Quote
Old 01-26-2006, 12:47 AM   #123
20Sti05
Member#: 92657
2008 I GOTZ MEEZ A
PICKEM UP TRUCK!!!
so if i got one of these before i did any other mods (intake and 3" catback is all i have right now) would i get any adverse effects? just wondering so i would have room to upgrade later
20Sti05 is offline   Reply With Quote
Old 01-26-2006, 09:35 AM   #124
srxboy
Member#: 80351
2002 subaru wrx
20sti05, You will have more lag but other then that you won't notice to much of a different. That is kinda the same route I am going. I have Intake, 3.5 turboback, and a utec. Just piecing things together until I can afford a gt30r. You gotta love cars, they are never fast enough and never seem to have enough money to do want you want to them.
Old 01-26-2006, 11:39 AM   #125
narenji
Member#: 12727
Its got internal
combustion ftw!
man i wish i had seen these before i got the turboxs... i had some issues with fitment, with the left endtank piping pushing so much on the bumper that it was hard to put back on... these kits seem to have much better fitment.. the pictures i've seen look like the bumper is on there really nice.
narenji is offline   Reply With Quote
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 02:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 01:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 12:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 546 12-16-2005 10:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 06:01 PM
