Old 11-21-2006, 07:25 PM   #1301
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
So, trimming the bumper. Is it just trial and error? Just cut some then see if it fits.....cut some more....try to fit.....etc?
I'm Slow is offline   Reply With Quote
Old 11-21-2006, 07:37 PM   #1302
benw
Member#: 103320
1998 swapped
Forester L
basically. You'll be able to see where it's hitting, and keep trimming until it fits.
benw is offline   Reply With Quote
Old 11-21-2006, 07:56 PM   #1303
Deranged
Member#: 42999
2004 sti
blue
Does the APS 70mm Intake fit with this fmic?
Deranged is offline   Reply With Quote
Old 11-21-2006, 07:58 PM   #1304
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
sounds like fun
Old 11-22-2006, 01:43 PM   #1305
Silver '02 REX
Member#: 27963
2014 ATS
No, they both go through the same fender hole.
Silver '02 REX is offline   Reply With Quote
Old 11-22-2006, 05:47 PM   #1306
StiPete
Member#: 96164
2005 STi - SOLD :(
'00 Impreza 2.5rs
I wish.
StiPete is offline   Reply With Quote
Old 11-22-2006, 09:08 PM   #1307
Deranged
Member#: 42999
2004 sti
blue
So whats the best intake to use if one is going with an FPGreen turbo.
Old 11-23-2006, 12:41 AM   #1308
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
Did you guys get a cap for the radiator overflow replacement tank?
Old 11-23-2006, 01:31 AM   #1309
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
Mine arrived today by the way, looks really good and above my expectations
Old 11-23-2006, 02:12 AM   #1310
kenny08
Member#: 79907
02 blue wagon
18g goodnesss
are people getting the correct 90 degree elbow (turbo to pipe) now?
kenny08 is offline   Reply With Quote
Old 11-23-2006, 02:17 AM   #1311
AmolaitoPR
Member#: 38609
2004 STI
I'm using my stock cap. Make sure you poke a tiny hole thru it so it will not pop off under pressure. Dummy-cord it as well.
AmolaitoPR is offline   Reply With Quote
Old 11-24-2006, 08:50 AM   #1312
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
Actually the overflow tank comes with a 1/4 inch hole in it now right next to the cap
Old 11-24-2006, 08:50 AM   #1313
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
Yes, just got mine and it had the correct elbow
Old 11-24-2006, 08:56 AM   #1314
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
THe one flaw I founfd on the kit and seems to be common ifs the MAF Sensor housing they give you. the MAF sensor bracket is just spot welded and glued on with gasket sealer. The gashket sealer has little holes in it which will leak air. I am not using this piece but I bet there are a lot of people running this and don't realize they are leaking boost.
Old 11-24-2006, 12:07 PM   #1315
StiPete
Member#: 96164
2005 STi - SOLD :(
'00 Impreza 2.5rs
And that is as simple as picking up a 2 dollar tube of silicone and making a seal around that area.
Old 11-24-2006, 12:36 PM   #1316
simplebirdy
Member#: 102996
2009 Legacy
just ordered mine, then when I get it the pipes are getting coated and wrapped. No more heatsoaked tmic for me.
simplebirdy is offline   Reply With Quote
Old 11-24-2006, 04:53 PM   #1317
benw
Member#: 103320
1998 swapped
Forester L
+1, I noticed that immediately on mine. I scraped off all the old red stuff, dremel polished the aluminum bare again, and used ultra-black RTV.
as for what intake to use with FP green, you'll probably need a BigMAF. I did, and I'm on a 20G.
Old 11-25-2006, 10:34 AM   #1318
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
does everyones overflow can have a hole in it next to the cap? Is this for a hose or just to prevent pressure build up?
Old 11-25-2006, 08:17 PM   #1319
DrakeV
Member#: 112502
2005 WRX STi
CGM
the hole is to put the overflow hose in, without the hose it would be useless. you re-use your stock cap, it fits perfectly.
DrakeV is offline   Reply With Quote
Old 11-25-2006, 08:41 PM   #1320
tasq
Member#: 62362
2005 wrx
CGM
omgz im leaking boost before the turboz!11 o teh n03z!
tasq is offline   Reply With Quote
Old 11-25-2006, 09:13 PM   #1321
modaddict
Member#: 95840
sold to a good bud
awaiting next car
LOL you saw that too!!
i didn't say anything though...
modaddict is offline   Reply With Quote
Old 11-26-2006, 01:34 AM   #1322
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
lol, oops! You know what I freakin mean though. Still losing air at the MAF sensor so it may be reading one amaount of air and another actually makeing it into the motor. Also, anyone use the L shape piece that comes with the Bumper beam hardware?
Old 11-26-2006, 12:24 PM   #1323
az03wrx
Member#: 106220
Just wondering if anyone ever ordered the XS Engineering CAI and verified fitment? I saw the home made pep boys one but really don't want to run the plastic setup. If no one else has I may guinea pig this for everyone.
Originally Posted by benw View Post
Update: Since I dont feel like running a short ram hot air intake, and don't want to shell out $220 for the XS Engineering CAI that "might work" I'm going to attempt to make a cold air intake using some individual pieces off eBay. Probably an assortment of bent pieces and straights, hopefully I will be able to use 2 of them and a cone filter to mate up with the included MAF housing and my silicone inlet tube.
az03wrx is offline   Reply With Quote
Old 11-26-2006, 12:29 PM   #1324
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
^do it
Old 11-26-2006, 02:00 PM   #1325
DashboardCon
Member#: 109878
2001 Aprilia RSVR
I couldnt find a use for the L shaped bar. No need for it anywhere on mine.
DashboardCon is offline   Reply With Quote
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 03:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 02:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 01:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 546 12-16-2005 11:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 07:01 PM
