Old 11-26-2006, 01:30 PM   #1326
AmolaitoPR
Member#: 38609
2004 STI
Originally Posted by DashboardCon View Post
I couldnt find a use for the L shaped bar. No need for it anywhere on mine.
Is this the L-shaped bracket in question? To the right of the BPV, securing the IC piping to the manifold.
AmolaitoPR is offline   Reply With Quote
Old 11-26-2006, 05:20 PM   #1327
Freon
Member#: 88322
2009 BMW 135i
I didn't get a bracket. I made one myself by bending and drilling a strip of aluminum.
Freon is offline   Reply With Quote
Old 11-26-2006, 06:23 PM   #1328
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I determined that bracket to be extra weight.
modaddict is offline   Reply With Quote
Old 11-26-2006, 11:21 PM   #1329
DashboardCon
Member#: 109878
2001 Aprilia RSVR
Nope, thats not the one I was talking about. I mean the one that is about 8-10 inches long that has a 90 degree bend on one end and then twists into a C shape. I dont have any trouble with the pipes moving, but it would be nice to know what its for.
DashboardCon is offline   Reply With Quote
Old 11-27-2006, 12:12 AM   #1330
gozway
Member#: 47462
05 STi
CGM
that one goes under the intake pipe. which i couldnt get to fit so i took my factory intake tube thing and deleted it with a hose coupler as seen here
Painted the front mount cuz i don't like bringing any more attention than the car brings now!
overall the install went pretty good on mine. the cold side pipes where the one that went through the hole and the one that goes to the cooler didn't want to line up for **** so force was given to fix that. i don't like that the 90 out of the turbo is touching the pitch stop mount thing. and the spool has slowed with it also but i knew that coming in ... just needed it to move on to a larger turbo.
did anyone else have problems with the inake sitting too high not letting the hood shut?
gozway is offline   Reply With Quote
Old 11-27-2006, 12:18 AM   #1331
AmolaitoPR
Member#: 38609
2004 STI
I trimmed about 1/2" to 3/4" off my 90deg elbow to avoid this same issue. Not a big deal since there's plenty of hose after the bend.
I have a K&N filter with my setup. It measures 6" at the base, but no problems getting the hood closed or rubbing on the underside of the hood.
Old 11-27-2006, 12:51 AM   #1332
gozway
Member#: 47462
05 STi
CGM
i think i just noticed that i need to rotat the cold side pipe at the throttle body downward and that will give me the clearance i was looking for and make the connection between the one that goes trough the fender to the one that attaches to the cooler a better fit
did you cut the 2" side or the 2.5" side of the 90?
Old 11-27-2006, 02:10 AM   #1333
AmolaitoPR
Member#: 38609
2004 STI
I cut the 2" side, just enough to help with clearance.
Old 11-27-2006, 12:28 PM   #1334
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
you got anymore front end pics? i'm having a hardtime finding good 04/05 pics with this fmic
vtecTHIS is offline   Reply With Quote
Old 11-27-2006, 12:39 PM   #1335
gozway
Member#: 47462
05 STi
CGM
i'll try to take some this week
Old 11-28-2006, 09:44 AM   #1336
az03wrx
Member#: 106220
Ordered the XS Engineering CAI. Updates to come...
az03wrx is offline   Reply With Quote
Old 11-28-2006, 11:57 AM   #1337
epaplia
Member#: 91076
2006 WRX
I had this same problem. 6" base for the cone filter. I had to squish it for the hood to shut. It doesn't give me problems...but it looks kinda tacky.
Oh well.
epaplia is offline   Reply With Quote
Old 11-28-2006, 01:47 PM   #1338
marcus.raw
Member#: 97675
93 Stroked LS3 FD
Launch Edition 2015 STI
anyone got a shot of an 04-05 with the fog lights and the fmic?
marcus.raw is offline   Reply With Quote
Old 11-28-2006, 01:48 PM   #1339
tasq
Member#: 62362
2005 wrx
CGM
You can't keep your fogs with 04+
tasq is offline   Reply With Quote
Old 11-28-2006, 03:32 PM   #1340
modaddict
Member#: 95840
sold to a good bud
awaiting next car
^^^+1
I had to cut the ish out of my foglight internal bracketry. Well, it's no longer left!
saves weight too
Old 11-28-2006, 11:33 PM   #1341
marcus.raw
Member#: 97675
93 Stroked LS3 FD
i was told by wrx-error that you can =/
Old 11-28-2006, 11:37 PM   #1342
tasq
Member#: 62362
2005 wrx
CGM
I demand proof then.
Old 11-28-2006, 11:57 PM   #1343
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Iam going to order one ths week let see how your come out buddy
subaru222 is offline   Reply With Quote
Old 11-29-2006, 12:36 AM   #1344
DrakeV
Member#: 112502
2005 WRX STi
CGM
i installed mine, i dont have fog lights but have one fog light housing and it fits fine. so there is no reason you can't have fogs. you just have to trim quite a bit of the housing. 2005 STi !!
DrakeV is offline   Reply With Quote
Old 11-29-2006, 01:24 AM   #1345
gozway
Member#: 47462
05 STi
CGM
Oh well.
i got mine fixed where i can run the factory intake elbow to the maf adapter now. just loosened the cold side from the throttle body and in the fender liner and pushed the pipes down... all it needed i guess! but the filter still rubs the hood and the hot side pipe is hitting the hood liner beside the oil filler cap
Old 11-29-2006, 12:32 PM   #1346
I'm Slow
Member#: 102748
HTA 35r-Gadiel tune
Don't tell that to this guy then.
Originally Posted by Ronnzi View Post
My links above weren't working. Here they are
I'm Slow is offline   Reply With Quote
Old 11-29-2006, 01:17 PM   #1347
marcus.raw
Member#: 97675
93 Stroked LS3 FD
thank you!!!
Old 11-29-2006, 01:53 PM   #1348
boozy04
Member#: 87034
08 Stg2 9.5's 275s
SSM
i knew i'd read in here that you could keep em, that's the reason i'm gettin one.
boozy04 is offline   Reply With Quote
Old 11-29-2006, 01:59 PM   #1349
WRX-ERROR
Member#: 83211
2002 WRX - stg4
You can as shown above.
I don't know much about the 06's but I know with 2002 to 2005 (2004 and 2005 I have only forum info on and haven't see it myself) you can keep your fog lights. For my 2002 I had to cut into the back of the light housing but it's behind the bulb so you can't see it. Not that it matters to me since I have fog covers.
WRX-ERROR is offline   Reply With Quote
Old 11-29-2006, 03:40 PM   #1350
boozy04
Member#: 87034
08 Stg2 9.5's 275s
SSM
I think there's a pic in this forum somewhere of an 06 with it's fogs still. I'm on dial up right now, or i'd search around.
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 02:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 01:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 12:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 546 12-16-2005 10:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 06:01 PM
