Old 01-04-2007, 08:46 AM   #1501
chlnOrSlpn?
Member#: 97785
2015 WRB STi Limited
EFI Logics/CTSUBIE
any word on that SPT intake pic?
chlnOrSlpn? is offline   Reply With Quote
Old 01-04-2007, 11:35 AM   #1502
Team optimum#5
Member#: 114724
I have an 06 wrx.
I wanted to install this FMIC kit but do I have to take that plastic black piece out of my front bumper.
I was planing on puttting a grillcraft grill in there and you need that plastic piece for it to fit.
Does anyone have a pic of this?
Team optimum#5 is offline   Reply With Quote
Old 01-04-2007, 12:39 PM   #1503
chlnOrSlpn?
Member#: 97785
EFI Logics/CTSUBIE
Originally Posted by Team optimum#5 View Post
I have an 06 wrx.
If your talking about the black plastic pillar and all in the gap of the bumper, then that gets cut out to fit the fmic....
Old 01-04-2007, 03:03 PM   #1504
STL WRX
Member#: 88304
05 VF34 Aspen WRX
We need SPT pic's.... That guy's user name really speak's for itself "Im Slow"
STL WRX is offline   Reply With Quote
Old 01-04-2007, 04:11 PM   #1505
chlnOrSlpn?
Member#: 97785
EFI Logics/CTSUBIE
Old 01-04-2007, 04:34 PM   #1506
WRX-ERROR
Member#: 83211
2002 WRX - stg4
I have an 06 wrx.
Thats actually part of the bumper and would need to be cut off to fit this FMIC.
WRX-ERROR is offline   Reply With Quote
Old 01-04-2007, 07:37 PM   #1507
Bolster
Member#: 22290
2002 WRB WRX Wagon
I have an 06 wrx.
I used cable ties to put my grillcraft grill on and it works fine.
Bolster is offline   Reply With Quote
Old 01-05-2007, 01:24 PM   #1508
Team optimum#5
Member#: 114724
No, sorry if I was vague.
I meant if you are looking at the 06 wrx.sti there is a horizontal piece of plastic that has 2 "slits" cut into it.
I realise that you have to cut out the other plastic inside the bumper.
I am just trying to find a way to put a grill over my FMIC so it doesnt get damaged by debris.
The grill craft one will cover everything but the top inch of the fmic.
pics for reference.
If you remove that plstic part for the FMIC and then install the grill there would be a gap where the grill doesnt go.
I want some way of putting a grill over the whole FMIC( like evos have it covered).
Thanks hope I went into more detail.
Old 01-05-2007, 03:19 PM   #1509
WRX-ERROR
Member#: 83211
2002 WRX - stg4
That piece normally does get cut off.... BUT you could trim the bumper to keep that piece if you needed to.
Old 01-05-2007, 03:22 PM   #1510
Team optimum#5
Member#: 114724
Im just debating on if it stays there how much it will effect the air flow.
Old 01-05-2007, 10:25 PM   #1511
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I left mine on to keep it more sleeper. Here are some pics of my car and then what I am going for after:
Going for:
Crystal_Imprezav is offline   Reply With Quote
Old 01-06-2007, 01:48 AM   #1512
mikzcha
Member#: 111439
2006 WRX tr
ok i installed the fmic yesterday.. encountered a few problems, but it's all in and working. here's the pics i took.
i had to bend my fuel lines a little as you can see here
ok here are the final pics of it on..
mikzcha is offline   Reply With Quote
Old 01-06-2007, 04:20 AM   #1513
billfromtr
Member#: 96554
2005 STi
URGENT! What is that bung in the hot side for???? I'm 90% completed and that is one of my main issues besides cutting the bumper.
billfromtr is offline   Reply With Quote
Old 01-06-2007, 08:11 AM   #1514
chlnOrSlpn?
Member#: 97785
EFI Logics/CTSUBIE
^^the bung by the fuel lines is just a mounting point. I believe the kit should come with an "L" bracket that mounts to the two holes where the old tmic bracket mounted.
mikzcha: Was it impossible to fit the washer tank back in?
Old 01-06-2007, 11:25 AM   #1515
xrdriver
Member#: 119633
10 SWP STI
15 CGM STI
It's too bad the hole is so wide in the 06 bumper....
It needs a wider core but then you would not be able to keep the fogs.
At least my car is black so I can paint the IC and it won't look so small.
xrdriver is offline   Reply With Quote
Old 01-06-2007, 12:29 PM   #1516
mikzcha
Member#: 111439
2006 WRX tr
you might be able to get the washer tank back in, but i didn't want to try.. fitment was extremely tight in that area.
also i forgot to mention.. the blitz intake does not work with this kit. i thought it would because the blitz intake i have is from the blitz fmic kit. so right now i'm using the ssac intake arm w/ a 3 inch filter. i resealed the spot where you mount the maf to the arm.
Old 01-06-2007, 02:16 PM   #1517
chlnOrSlpn?
Member#: 97785
EFI Logics/CTSUBIE
cool, thanks!
Old 01-06-2007, 03:19 PM   #1518
AmolaitoPR
Member#: 38609
2004 STI
There should be a L shaped bracket that secures the hotside piping to the intake manifold. This helps hold the piping in place and prevents rubbing on the hood, battery, and oil spout.
Like this...
AmolaitoPR is offline   Reply With Quote
Old 01-06-2007, 10:41 PM   #1519
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I dynoed today with the FMIC....
Since I am supercharged, I get what I get for boost levels, and any interuption in the flow, I lose boost....
So, I WAS at 12-13 psi with my smaller FMIC and 190 whp and 201 torque.
The new FMIC dropped me to 11-12 psi, but I dynoed at 192 whp and 212 torque. I did retune it, but I am confident the drop in boost was due to efficiency, not blockage!
Old 01-06-2007, 11:27 PM   #1520
modaddict
Member#: 95840
sold to a good bud
awaiting next car
congrats reddevil!
modaddict is offline   Reply With Quote
Old 01-08-2007, 06:26 PM   #1521
Santa STi
Member#: 130405
2005 WRX STi
i installed this intercooler and the second to last pipe (the one that goes through the passenger side fender) squeks as the engine moves side to side over bumps and sometimes it squeks even when i just rev it... anyone know of real fixes instead of just styrofoam?
Santa STi is offline   Reply With Quote
Old 01-08-2007, 08:03 PM   #1522
STL WRX
Member#: 88304
05 VF34 Aspen WRX
are many of you doing the buy it now option on ebay or trying to win bids... i think i may just do the buy it now option when i am ready to buy since im impatient and hate waiting for the auction to end and at the last minute get outbid by someone... lol!
Old 01-08-2007, 08:35 PM   #1523
AmolaitoPR
Member#: 38609
2004 STI
I had the same issue. I used an old intake TB to TMIC coupler I had in my parts bin and wrapped it around the IC pipe. It doesn't make a sound any more. The coupler is wire reinforced, so it should be a while before the sheetmetal eats through it.
Old 01-08-2007, 08:42 PM   #1524
benw
Member#: 103320
1998 swapped
Forester L
mine definitely has a squeak at idle, when the motor harmonics shake it more. Once revved, it goes away. I think mine is hitting on the hole on the driver's side where the piping makes a U-bend.
benw is offline   Reply With Quote
Old 01-09-2007, 10:00 AM   #1525
Team optimum#5
Member#: 114724
How many hours does it take to install this.
(For reference I have a 2006 wrx if that helps.)
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 02:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 01:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 12:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 546 12-16-2005 10:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 06:01 PM
