Old 01-11-2007, 10:39 PM   #1551
VIR EURORALLY
Member#: 53517
STi Outback STi
Originally Posted by Sypher View Post
WEll just bought this Front mount kit should be here in a week, Ill take some pics while Im installing it and possibly do a write for a 06wrx if I dont get lazy . Was gonna go for the APS but! my paycheck didnt let me haha.
You should have it in at least 2 more days. I had mine in 3.
VIR EURORALLY is offline   Reply With Quote
Old 01-11-2007, 10:58 PM   #1552
knucklesplitter
Member#: 64246
Originally Posted by joeymdz View Post
do you have any data on your magical "air straightener".. i can understand the theory behind that idea of the honey comb but you are creating a new turbulence over the existing one
I'm not sure what new turbulence you are meaning. Many wind tunnels and many mass airflow sensors have flow straighteners, and many of those are of honeycomb construction. The guy that sold me the honeycomb commented afterwards that one of the largest uses of honeycomb aluminum (besides structural stuff) is flow straighteners for wind tunnels to ensure laminar flow. Ideally you want the cell length to be at least 6X the cell diameter to completely kill the turbulence.
In about a month I will have flowbench data on this and other intakes with and without honeycomb and different honeycomb sizes/lengths. I will be measuring pressure drops across it too if I can (as it may be less than 1"H2O or 1/28th of a psi which is the smallest my manometer can measure)
knucklesplitter is offline   Reply With Quote
Old 01-12-2007, 01:14 PM   #1553
bugeyed702
Member#: 98018
06 WRX TR
Steel Grey
Originally Posted by 02WRXSTiImpreza View Post
/\ /\ /\ /\ /\ /\ ---very nice indeed....well i just went to their website and their now selling them for 700 bucks......crap-ola. I should have bought it back when it was still cheap.....has anyone got for cheaper?
http://cgi.ebay.com/ebaymotors/SCOOB...78184231QQrdZ1
Here is a link directly to a fresh one........ Keep tabs on it and you shouldnt have any problems
bugeyed702 is offline   Reply With Quote
Old 01-12-2007, 03:41 PM   #1554
DaRealGMan
Member#: 59296
2004 WRX
hey, great minds think alike! About the same time, I made my own air straightener. Here's the thread:
http://forums.nasioc.com/forums/show....php?t=1176889
Originally Posted by knucklesplitter View Post
Here's a kewl little mod I did with the MAF housing that came with the SSAC FMIC. I bored it out to 70mm making it basically a big MAF good for about 400awhp (with tuning), then counterbored it for a honeycomb air straightener I had for another project. This air straightener will eliminate any turbulence and the resulting idle and drivability problems normally associated with short rams. I also epoxied the MAF mounting plate to the housing in addition to the screws to make sure it was firmly attached and sealed for good. Oh, and I polished the housing too.
DaRealGMan is offline   Reply With Quote
Old 01-12-2007, 03:44 PM   #1555
DaRealGMan
Member#: 59296
2004 WRX
just a few pages back (page 59) scroll halfway down:
http://forums.nasioc.com/forums/show...909584&page=59
also check out my latest mod to this same intake:
Originally Posted by WRBSTI12 View Post
Is there any way to make this intercooler fit with a cold air intake. Thanks.
Old 01-12-2007, 05:17 PM   #1556
knucklesplitter
Member#: 64246
Nice... my main goal is to solve the problem of the Subaru (Denso MAF) blow-thru MAF issues which I believe are due to turbulence, but it will most likely spill over into short rams and CAI's. Theoretically without flow straighteneing you need a straight pipe before the meter at least 6x the ID of the pipe to properly measure flow, but 10x is better. That's why the honeycomb is so useful for wind tunnels - 10 x 10' would be 100' long.
Old 01-15-2007, 03:59 PM   #1557
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Originally Posted by Mannyfreezeee View Post
First off Id like to thank the guy who started this thread. A good intercooler kit that yes is a knock off but is worth your money. I dont have one yet but im planning to pick one up soon. Okay now heres my noob question. I know space is very limited in the front bumper and u have to cut just to fit the intercooler but my question is, is it possible to modify or cut the bumper support to get it to fit? Has anyone installed the bumper support and intercooler?..... if im being stupid, Please someone correct me. Thanx
I don't know of anyone who cut their stock bumper support since it comes with the bumper beam. But if I had to guess, and based off other FMIC's I would think you could but it would be a lot of work.
WRX-ERROR is offline   Reply With Quote
Old 01-15-2007, 04:24 PM   #1558
AspenGC8
Member#: 62280
2011 WRX Sedan
How much coolant should be in the SSAC black pipebomb overflow container?
IE, whats considered adequate and need to add coolant!
AspenGC8 is offline   Reply With Quote
Old 01-15-2007, 06:34 PM   #1559
Freon
Member#: 88322
2009 BMW 135i
You fill the coolant reservoir that is next to the turbo, not the overflow. If you overfill the reservoir the overflow will start to collect fluid. If you check the overflow on a hot day on a hot engine it may have some fluid in it as well, which is normal. When you add coolant add it to the reservoir, not the overflow.
Freon is offline   Reply With Quote
Old 01-15-2007, 07:28 PM   #1560
JiveMasterT
Member#: 116666
2011 STI Limited
Looks nice, plays dirty
I'm very interested in seeing how this works. Theoretically you could use this badboy to do a blow through setup if you stuck it in-line with the IC piping nearer to the intake mani. Good luck and be sure to post the results!
JiveMasterT is offline   Reply With Quote
Old 01-15-2007, 11:10 PM   #1561
sicknickb
Member#: 123598
2006 Saab 92x
Has anyone ran this IC with a 06 wrx on the stock turbo? If so did you have a hi pitched noise under boost that sounded like a leak but there was not one to be found? I just installed mine and had no use for the hoses and t fittings that came in the small box, I thought it was used if you had not kept your stock bov. If I am wrong than if someone could give me some advise it would be greatly appriciated!
sicknickb is offline   Reply With Quote
Old 01-16-2007, 12:07 AM   #1562
modaddict
Member#: 95840
sold to a good bud
awaiting next car
If you have a high pitched noise under boost....you most likely have a leak.
the hoses and t-fitting are for your crankcase breather system. look at pics in this thread previously...and you will find out. Its really not an option if you have the stock system. My system with the Crawford Air/Oil separator is completely different though....
modaddict is offline   Reply With Quote
Old 01-16-2007, 12:11 AM   #1563
mikzcha
Member#: 111439
2006 WRX tr
did you pressure test everything? the piping isn't a great fit on the 06 so u want to make sure.. there are a couple of places i had to hammer to get the piping not to scrap on part of the car.
mikzcha is offline   Reply With Quote
Old 01-17-2007, 12:46 PM   #1564
ScoobyDooo
Member#: 98891
2006 WRX TR 392 WTQ
20G w/FMIC
Hey guys I hope you dont care that i post this here i know its susposed to be in the "For Sale" forums but i figured since the parts are for this install it would help to have it here. I purchased two peices that i ended up not needing for my SSAC FMIC install and just wanted to know if anyone out there needed them... they are
1. 90 degree silicone elbow for the BOV SOLD!!!
2. Adapter flange for your stock BOV or other BOV'sSOLD!!!
3. Turbo/DP and Turbo/Uppipe Gaskets
Let me know if anyone is interested, i'll shoot you some prices.
By the way i installed this on a 2006 WRX TR if anyone would like some pics of need any questions answered shoot me a PM...
Also, has anyone else had a problem with they idle after this FMIC install???
Let me know,
THANKS GUYS,
CHRIS
WV 26847
ScoobyDooo is offline   Reply With Quote
Old 01-17-2007, 12:48 PM   #1565
ScoobyDooo
Member#: 98891
2006 WRX TR 392 WTQ
20G w/FMIC
I forgot to mention the rough idle is before it has been tuned waiting for that next week...i would assume this is normal bc the EM is still running for the stock TMIC
CHRIS
EDIT: IM RUNNING THE COBB SR INTAKE
Old 01-17-2007, 02:22 PM   #1566
knucklesplitter
Member#: 64246
CHRIS
I would think this is more likely due to the intake you're running. At idle I don't think the ECU would know what IC you're running. What intake is it anyway? Did you change to it when you installed the FMIC?
Old 01-17-2007, 05:27 PM   #1567
brranger
Member#: 99197
2006 WRX 6 speed
so to confirm, how many of you were able to use the spt intake on 2006 wrx, planning to make an order and I know I need the stock BOV adaptor, 90 degree elbow and just wanting to see which intake I am going to go with
brranger is offline   Reply With Quote
Old 01-17-2007, 05:54 PM   #1568
chlnOrSlpn?
Member#: 97785
2015 WRB STi Limited
EFI Logics/CTSUBIE
I am running the SPT intake as of right now and am looking into getting this FMIC in the next few months. I have yet to get a response with a picture to back up that it works. I think it should fit, but not 100%.
chlnOrSlpn? is offline   Reply With Quote
Old 01-18-2007, 10:36 PM   #1569
Dynasty336
Member#: 103561
2006 STi
Just receive mine. Ordered it Monday and received it today, $295 shipped to my door. This thing LOOKS great! i cant wait to get it put on which will probably be on sun or mon, Im still debating over rather or not i want to paint it black or not though. Ill post up some pics once it goes on. Ill be using my k&n typhoon with it.
Dynasty336 is offline   Reply With Quote
Old 01-18-2007, 10:47 PM   #1570
STL WRX
Member#: 88304
05 VF34 Aspen WRX
how did you get that thing for 295 shipped when its 299 + 58 shipping? 399 buy it now?????
STL WRX is offline   Reply With Quote
Old 01-18-2007, 10:53 PM   #1571
Dynasty336
Member#: 103561
2006 STi
All you have to do is email ssautochroms and ask them for the prics of 295 shipped and they will give it to you no prob
Old 01-18-2007, 11:00 PM   #1572
bgod
Member#: 100274
If anyone needs I have a brand new ssac fmic I'm not using. I thought I needed it for parts but didn't.
Let me know if someone wants it for cheap.
thanks.
bgod is offline   Reply With Quote
Old 01-18-2007, 11:22 PM   #1573
Aspen_Sti
Member#: 110665
05 STi
just recived mine in the mail today. its awesome! you really can not beat it for $295 shipped! unbelieveable.
like stated above, just email them and say that you have seen there kit on ebay going for 295 shipped and tell them you'll buy through them if they can give you the same deal. worked for me.
Aspen_Sti is offline   Reply With Quote
Old 01-19-2007, 07:37 PM   #1574
ScoobyDooo
Member#: 98891
2006 WRX TR 392 WTQ
20G w/FMIC
Default 2006 WRX TR w/ SSAC FMIC PICS
ok guys i'll get you some pics if someone can expalin to me how to add a pic in here...i now feel stupid
CHRIS
Old 01-19-2007, 07:43 PM   #1575
Dynasty336
Member#: 103561
2006 STi
go ti imageshack.us and upload it there. its self explainatory after that
FMIC piping made from silicone only subypal Newbies & FAQs 14 12-11-2009 03:43 AM
Ford Mustang Made From 5000 Beer Cans AVANTI R5 Non-Subaru News & Rumors 16 08-04-2007 02:00 AM
I just made coffee with 6-month old Folgers from an open can beachbum Off-Topic 15 01-19-2006 01:46 PM
New e-bay FMIC...not made from Burmese Soda cans. Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 546 12-16-2005 11:36 AM
New bumper and new FMIC = new pics (56k do not try) GottaREX Member's Car Gallery 87 10-12-2005 07:01 PM
