Old 12-28-2005, 04:00 PM   #1
VajraTLR
Member#: 13156
2004 WRX
JBP
Default quick question, do you really need to drain the coolant when intall turbo?
im in the middle of the install, seems like a hassel to drain the coolant.
thanks,
VajraTLR is offline   Reply With Quote
Old 12-28-2005, 04:04 PM   #2
SAINTSOFSPEED
Member#: 40596
03 WRX
MBP
Use a bucket and drain enough coolant to remove the lines without any hassle.
SAINTSOFSPEED is offline   Reply With Quote
Old 12-28-2005, 04:04 PM   #3
TheLegacy
Member#: 47615
2007 BMW 335XI
Saphire Black
I would... I did my turbo and tranny at 30k... So i did the whole 30k work, oil, coolant, new clutch
it just came out better and cleaner that way
TheLegacy is offline   Reply With Quote
Old 12-28-2005, 04:04 PM   #4
VajraTLR
Member#: 13156
2004 WRX
JBP
coo...thanks!
Old 12-28-2005, 04:11 PM   #5
hondaeater69
Member#: 60324
don't forget to burp!
Old 12-28-2005, 06:43 PM   #6
whittleman
Member#: 14873
2002 WRX Wagon
I just plugged the coolant line once I disconnected it. I only had to add a little, and burp.
whittleman is offline   Reply With Quote
Old 12-28-2005, 07:50 PM   #7
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
NO you don't. I just clamped off the coolant lines, and remove the oil lines last. The oil lines will leak a little, but not much. You will also loose a little coolant from the turbo.
Just top off both fluids when finished with project and you should be cool.
-jason
jmussetter is offline   Reply With Quote
Old 12-28-2005, 10:13 PM   #8
Rickyh
Member#: 40453
I didn't drain anything. Just clamped em off as soon as I unhooked em. I've swapped turbos 3 or 4 times and never drained anything.
Rickyh is offline   Reply With Quote
Old 12-28-2005, 10:16 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....i found some small, black, rubber, plugs at ACE that fit the lines perfectly....plug 'em as soon as ya pull 'em and ya might loose a few ounces.....mostly out of the turbo itself.
Old 12-29-2005, 12:20 AM   #10
Davenow
Member#: 23676
I have never drained the coolant at all when doing a turbo swap. Hell I barely spill any. I dont even usually have to top it off. But I have teh secret weapons against coolant loss (line clamp pliers)
Wideband Question: How often do you really need to view? BeBop86 Engine Management & Tuning 6 12-24-2009 04:26 AM
Do you really need to bring your :toning: dog to the office?? skifree1260 Off-Topic 26 07-31-2009 08:56 AM
If you own a 04+ you really need to try the 9011 HIR bulbs BIGSKYWRX Interior & Exterior Modification 11 10-11-2004 09:21 AM
Do we really need to run the engine during daytime? sabelt Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 09-16-2004 06:36 PM
do I REALLY need to replace the flywheel? racerwad Transmission (AT/MT) & Driveline 8 11-01-2001 08:06 PM
