![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 83412
2002 WRX Sedan. Can I put 225/50/16 tires on the stock wheels without any interference front or rear?
Thanks - Bill
#2 |
Member#: 86356
yes45
#3 |
Member#: 103183
The stock wheels at 6.5" are really to narrow for a 225mm tire. Wheels should be at least 7" wide or better still 7.5".
#4 | |
Member#: 24038
South East
... Anymore tips on double clutching??? Most 225 tires are well within specs to be run on a 6.5" rim. They are not too narrow. Many 225's can even be run on 6" wheels within manu. specs. You'll give up some turn in feel in exchange for added grip. But feel aside, most 225's on 6.5" wheels are PERFECTLY fine. Perfectly within the recommended range of the tire. Done by a lot of people... Last edited by REX8; 12-28-2005 at 09:05 PM. |
#5 |
Member#: 86356
To clarify...yes they will fit on the wheels and yes they will fit without rubbing and yes, people have run HARD (autox in stock class) using this size tire with no problems on those skinny 6.5" wheels.
#6 |
Member#: 95484
South East
Vehicle:1985 911/993 Cab silver |
I just finished up a set of BFG gforce KDWS 225/50/16 on the stock WRX wheel and never had any problems with rubbing although I think the extra tread made them a little squishy in very hard turns, but they were still adequate. The overall diameter of a 225/50/16 tire is very close to the stock 16" tire size.
#7 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
225/50-16 will fit with no issues
and the rim width range is 6" - 8" for that size |
| Thread Tools | |
| Display Modes | |
| Sticky for Rim sizes and tire sizes? | TomsSound | Brakes, Steering & Suspension | 8 | 02-01-2012 09:30 PM |
| Tire sizes and speaker sizes... | samtheblur | Legacy Forum | 9 | 06-03-2005 08:04 PM |
| Racing Tire Size to Street Tire Size | mav1c | Brakes, Steering & Suspension | 0 | 11-18-2002 03:16 PM |
| Interesting Tire Size/Contact Patch Size/Shape Info - aka why I don't have 18" wheels | rao | Brakes, Steering & Suspension | 6 | 06-19-2001 04:08 PM |
| Here is tire sizes chart. No more tire size Qs? Yeah, right! | 25psi | Brakes, Steering & Suspension | 18 | 04-18-2001 03:29 PM |
