Old 12-29-2005, 02:17 AM   #1
Crump
Member#: 72305
2006 Sti
SGM
Default 30,000 check
what do you have to check for when you reach 30,000 (fluids changes)
Crump is offline   Reply With Quote
Old 12-29-2005, 02:20 AM   #2
psuknak05
Member#: 38651
2004 WRB WRX
EVOIII
I always thought it noted all of that in the back of the owner's manual...
psuknak05 is offline   Reply With Quote
Old 12-29-2005, 02:27 AM   #3
sdogg3kgt
Member#: 38397
2002 Lovemachine
Oh it does.
sdogg3kgt is offline   Reply With Quote
Old 12-29-2005, 02:53 AM   #4
sdogg3kgt
Member#: 38397
2002 Lovemachine
If you don't have a manual (just responding to your PM), then you should say so right away because otherwise it's understandable why we responded the way we did.
At 30k you need to:
Tranny Fluid
Rear diff fluid
Coolant
Oil and filter
Air filter
PCV Valve
Fuel Filter
and some other miscellaneous things. I'd really recommend going to the dealership and find out exactly what you need. Other than that, if you have 2 working hands, do NOT have the dealer do it. It costs $250+, all of which you can do yourself for about $100.
Old 12-29-2005, 03:16 AM   #5
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
I'd also add:
Brake fluid
Clutch fluid
Old 12-29-2005, 03:20 AM   #6
sdogg3kgt
Member#: 38397
2002 Lovemachine
Originally Posted by armand1
I'd also add:
Brake fluid
Clutch fluid
Brake fluid I forgot
Clutch fluid isn't necessary and not in the manual, but can't hurt to do it.
Old 12-29-2005, 07:02 AM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
www.subaru.com has the BEST advice. It's the LATEST info on what needs to be done and it's advice trumps that of your manual.
Old 12-29-2005, 11:11 AM   #8
CrashTestRacer
Member#: 66394
2004 WRX Wagon
Don't try to do the PCV valve. It's non-serviceable on the '04 WRX. Whatever you do, don't try to get it out of the plastic T fitting, it's not threaded. Almost like I know this from experience...
CrashTestRacer is offline   Reply With Quote
Old 12-29-2005, 06:26 PM   #9
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
I think you just replace the whole thing, including the plastic part. There was a thread about this within the last month.
30,000 Check Up Question meprntr1 Service & Maintenance 4 09-03-2008 11:06 AM
15,000 Mile Check up OR 30,000? Parkerl Service & Maintenance 1 05-21-2008 05:36 PM
Who's Had 30,000 Check-up? gstien Baja Forum 19 02-21-2006 09:49 PM
30,000 Mile Check-up gstien Baja Forum 4 09-05-2005 10:45 PM
30,000 mile check-up SupaScooby Newbies & FAQs 4 03-05-2001 05:52 PM
