#1 |
Member#: 102467
Vehicle:2004 WRX Silver |
Last night my check engine light came on during a drive home. I turned off the car, started it up, and it didn't come back on. Today, the same exact thing happened. I've only had my car for a few weeks and haven't had time to install any of the new parts yet. I did, however, throw a K&N panel filter in two nights ago. I can't see how that could trigger anything, but thought I would mention it. Any thoughts?
#2 |
Member#: 102467
Fine. I'll just take it into the dealer.................
#3 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
...too much oil on the filter coats the MAF and makes it throw a code.....also, if ya didn't get the airbox top back on right---it is a PITA sometimes to get back on.....THAT can cause a CEL....or your gas cap could be loose......or....
...without the exact code, as in "Pxxxx" we are pissing in the wind. ...and the stock paper filter is better than that K&N junk |
#4 |
Member#: 102467
Why do you say that the stock filter is better than the K&N? very curious here. Thanks for the thought on the airbox. I'll check it out in the morning.
#5 |
Member#: 16200
Ya loose power with the k&n over the stock filter.
Proof....dyno proven proof. It has been posted here...back to back dyno runs.....and don't forget, they don't filter as well, either. |
#6 | |
Member#: 55011
Vehicle:2002 |
#7 |
Member#: 102467
I checked it out again today. The filter didn't seem to be seated properly, so I took off the MAF hose to get a better seat. We'll see what happens.
UncleScotty-do you happen to have a link to these charts? I'm not trying to be confrontational, again, I'm just curious. Thanks for the input guys |
| Thread Tools | |
| Display Modes | |
| Check Engine Light Help | Topshelf | Normally Aspirated Powertrain | 6 | 12-13-2004 12:45 PM |
| check engine light HELP!!!! | subarublu | Factory 2.0L Turbo Powertrain | 2 | 08-26-2004 02:27 PM |
| Check engine light-Help | tm999xxx | Tri-State Area Forum | 5 | 06-22-2003 11:55 PM |
| Check Engine Light Help | HpiRally | Normally Aspirated Powertrain | 1 | 03-01-2002 12:15 AM |
| check engine light !!! help! | jhoffmann | Technical Forum Archive | 2 | 08-13-2000 12:17 AM |
