Old 01-02-2006, 10:05 PM   #26
MattNJ2.8
Member#: 59277
2005 2009 Outback
Mazda3, Miata
Originally Posted by kfoote
The Toyo RA-1's usually like 2-4 PSI more cold tire pressure than what you would run in the dry. Most (NOTE: NOT ALL) street tires like 3-4 PSI less than what you would run in the dry.
If the RA-1's have more than about 4/32nds of tread on them, unless you are driving through puddles, they will be faster than street tires.
Huh, interesting! In the wet, I've always!!! run them with lower pressures.
Any recommendations as to how to set them for wet autocrossing?
MattNJ2.8 is offline   Reply With Quote
Old 01-02-2006, 10:16 PM   #27
ewright
Member#: 68803
2004 WRX STi
Jim,
It was an absolute pleasure to meet you in person! I had a blast on the track and I look forward to sharing a track with you again in the future.
Ernie
ewright is offline   Reply With Quote
Old 01-03-2006, 01:06 AM   #28
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
I'll vouch for Jon K as he gets more excited about rain on a track than anyone else I know. He also tends to pass everybody in the rain with ease. (Cue OneLap '03 footage from the uber-wet day where Jon was something like 5th overall in a stock EVO.)
-Biggly
DrBiggly is offline   Reply With Quote
Old 01-03-2006, 01:08 PM   #29
kfoote
Member#: 39180
2004 WRB STi
Slash Ten - FBHIC
Keep in mind that the pressured I gave are cold pressures. Hot, the RA1's should be 3-4 PSI lower than dry, but because there is less pressure buildup because the tires aren't getting as hot, the net result for what you are after once everything reaches steady state is lower than hot.
I have less experience with autocrossing, but I would imagine that running RA1's in the wet you would want a 2-3 PSI lower tire presure than RA1's in the dry because there isn't any time to build up heat and the tire pressures.
kfoote is offline   Reply With Quote
Old 01-03-2006, 05:29 PM   #30
CiViCKiDD
Member#: 30211
2008 Acura TSX
Premium White Pearl
I've never done any type of track racing, but like an ass I like to push my crappy civic in inclimate weather. Like everyone else says, it's all about being smooth. Your driving should always be smooth, but you have to take the "smoothness" to a higher level to drive fast on slippery roads.
I feel so awkward typing this, for some reason I feel like an Initial D fanboi.
CiViCKiDD is offline   Reply With Quote
Old 07-21-2009, 01:15 PM   #31
20boxer
Member#: 179382
03 wrx
psm
What do you recommend for camber in the rain? More or less than in the dry?
I'd guess less, as you'll see less roll and compression in the corners.
Confirm?
20boxer is offline   Reply With Quote
Old 07-21-2009, 04:04 PM   #32
StuBeck
Member#: 19546
2009 Honda Fit
Go with less, you want as much rubber on the road to get as much grip as possible.
StuBeck is offline   Reply With Quote
Old 07-21-2009, 07:23 PM   #33
WillysPU
Member#: 25994
2003 WRX wrb stage 4
What would Scooby do?
Read: The art of racing in the rain by Garth Stein. It is a great story, tips on racing in the rain, and a cool dog named Enzo.
http://www.garthstein.com/
WillysPU is offline   Reply With Quote
Cheapest mod to shave time off for Autox/Track days! JnJassociates Interior/Dressup/Audio & Security 53 05-23-2008 08:43 AM
how to adjust the height for tein coil-overs? Advan_rex Brakes, Steering & Suspension 0 08-02-2005 06:52 PM
How to adjust Tein Flex for softest ride? Bubba Brakes, Steering & Suspension 2 10-05-2003 02:25 PM
Help..Need to borrow/rent wheels for upcoming track day. Ferg North West Impreza Club Forum -- NWIC 8 10-16-2002 08:34 PM
