Old 12-30-2005, 06:34 PM   #1
emyselfandi
Member#: 83701
Default cam o ring
can someone tell me what/where the cam o ring goes? I don't see any info on it in my book. I have a 95 2.2L. thanks, tim
emyselfandi is offline   Reply With Quote
Old 12-31-2005, 08:52 AM   #2
John*G
Member#: 19562
95 coupe
red
Rear camshaft covers have O rings. I think there is also one on the drivers side front, inside the section that sticks out from the head, but it has been a while.
John
John*G is offline   Reply With Quote
Old 12-31-2005, 06:13 PM   #3
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
http://forums.nasioc.com/forums/showthread.php?t=907579
http://forums.nasioc.com/forums/show...light=oil+leak
The passenger side cam o-ring is accessed easily by removing two (2) 12mm bolts. The driver's side cam o-ring can only be accessed by removing the timing belt cover on the driver's side. Both are not a big deal, but the one on the RH side is easier.
Check your Private Messages.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 12-31-2005, 09:05 PM   #4
avk
Member#: 17252
'06 WX8
59E
On the left side, you have to remove the sprocket, back cover, and camshaft support.
avk is offline   Reply With Quote
Old 01-01-2006, 10:07 AM   #5
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Two years ago when I changed my timing belt and related components you told me to change the cam o-rings. I wish I would have changed the left side when I had it all tore down.
If you remove your cam sprocket the torque spec on that bolt is 58 ft-lbs, IIRC. It would be nice to have someone hold the cam sprocket with a strap wrench while you loosen and tighten that bolt.
-Charles-
Stock Sti Cams, Pistons, Rods And Rings, VALVES, SPRINGS, INTAKE MANIFOLDS Lroc130 Engine/Power/Exhaust 14 06-10-2010 03:27 PM
part number for cam angle sensor o ring methaddict Built Motor Discussion 4 04-20-2009 09:14 PM
Oil Pump o-ring Location? and Cam Swap questions? Skidd Normally Aspirated Powertrain 9 07-19-2006 03:37 PM
RH Service Hole Cam O-ring ImprezaVA Service & Maintenance 2 12-25-2005 10:56 AM
