Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 12-30-2005, 06:38 PM   #1
flukewrx
Member#: 75081
2003 WRX
Question Aftermarket Timing Belts
I don't have to do it yet, but I have been thinking about getting my next Timing Belt for my car. Is there any recommendations on what Timing Belt to get? I know I want to start modding my car for more power, but how strong is the OEM Timing Belt?
I have seen the P.E. Super Strong Timing Belt & the Greddy Extreme Timing Belt. Any opinions on these or others? Pro's and Con's for these are appreciated. What are the positive's and negative's about switching to an Aftermarket Timing Belt?
Tim
'03 WRX Sedan WRB
flukewrx is offline   Reply With Quote
Old 12-30-2005, 06:55 PM   #2
Hayes
Member#: 11808
Stick with the OEM timing belt unless you've extesively modified the engine. The OEM belt is good for 105,000 miles. Several "high performance" belt suppliers recomend changing at 60,000 miles and they can wear the sprockets considerably faster.
Hayes is offline   Reply With Quote
Old 12-30-2005, 11:32 PM   #3
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
80% of the timing belt jobs done at the shop i work at are aftermarket.You would be suprised how many aftermarket belts are made by the same company's same name brand,they just don't have Subaru,Nissan,Toyota,etc.stamped on them.Some aftermarket belts don't have timing marks on the belt so you got too go by the marks on the gears,engine.Marks on the belt will line up with the marks on your gears making sure that it is in time on not a tooth off.
ajabobrut is offline   Reply With Quote
Aftermarket 2.2L Legacy Closed Deck Timing Belt options? mikescar Legacy Forum 2 08-10-2009 04:14 PM
aftermarket replacements for worn out timing belt idlers? rockethound Pre-2002 Factory Turbo Powertrain 10 07-27-2007 09:26 AM
oem vs aftermarket timing belt? IllNastyImpreza Built Motor Discussion 9 08-13-2006 03:24 PM
Timing belt - genuine or aftermarket? bugeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-15-2005 12:10 PM
can i use an aftermarket timing belt? White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 1 01-16-2004 01:36 AM
