Old 12-30-2005, 07:13 PM   #1
USF97J4x4
Member#: 83035
Default Hella Supertone Install Question
I just installed some supertones on my car and i had a question:
Each of the 2 stock horns has a wire that connects it.
When using the relay supplied by Hella, there is only Tab where you use the stock horn plug
Did you make a wire connecting the 2 stock horn wires into the one tab on the hella relay? Or did you just connect one of the stock horn wires to the tab on the hella relay and just not use the other?
I used just one of the stock horn wires, both of the horns chirp when i use my keyless entry (i can feel them vibrate) but they dont seem all that loud on the road... Definitely not "7 times louder than stock"
Anyone have any input?
Also for the record i used 12 awg wire throughout.
USF97J4x4 is offline   Reply With Quote
Old 12-30-2005, 07:51 PM   #2
Bman
Member#: 64351
2005 Legacy GT
Well they are directional horns so they will not seem louder in the cabin. Try to make your panic go off and stand in front of the car, see how loud they are from that position. Or have some else honk them.
Bman is offline   Reply With Quote
Old 12-30-2005, 07:52 PM   #3
tacomaprime
Member#: 70572
2005 Tacoma
be careful doing that, I hurt my ears one time doing that.
tacomaprime is offline   Reply With Quote
Old 12-30-2005, 07:53 PM   #4
tacomaprime
Member#: 70572
2005 Tacoma
that is correct.
Old 12-30-2005, 07:54 PM   #5
D fresh
Member#: 95459
the activity level
of AutoX is > than F1
Yep, if ya have someone else honk 'em you may wanna get close to the grill, maybe even open the hood and lean in like you're checking oil. They are'nt that loud.
D fresh is offline   Reply With Quote
Old 12-30-2005, 07:57 PM   #6
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
You only need 1 of the stock horn wires connected to the relay. The other can be left dangling or you can leave one of the horns plugged in and have 3 horns.
Old 12-30-2005, 08:01 PM   #7
WrxWonderWagon
Member#: 67265
04 35r Sti meth
What Spelluring?
i just wired them up with the stock wireing harnest i used 8g wire tho they seem loud to me then again i got 2 other hella trumpits in the engine bay
WrxWonderWagon is offline   Reply With Quote
Old 12-30-2005, 11:14 PM   #8
USF97J4x4
Member#: 83035
Psy, yea i mean all that wire has to do is send the signal to the hella relay that the horns need to fire, i cant see needing both. I think i may just tape it off for now...
So... i did the panic thing... christ... what huh hello? i cant hear you.
Old 12-31-2005, 04:37 AM   #9
Blk_on_Blk_Wgn
Member#: 95659
2005 WRX Wagon OBP
Ridin' Dirty...
You did not use 8 gauge!!!! post a pic of that if you really did haha..that would be ridiculous.. if you truly did I bet you had a great time bending it...8 Gauge
Blk_on_Blk_Wgn is offline   Reply With Quote
Old 12-31-2005, 10:17 AM   #10
USF97J4x4
Member#: 83035
8 gauge is a bit ridiculous, i was having all sorts of complications using 12 gauge (stupid radio shack was out and it was the only time i had to do the install)
09 wrx hella supertones install question punjabi408 Newbies & FAQs 21 08-23-2010 01:28 PM
Hella Supertones install question thunder_lizard_1976 Electrical & Lighting 5 03-27-2008 11:52 PM
hella supertones install question krambte79 Electrical & Lighting 8 04-17-2007 11:30 AM
HELP....another hella supertone install question wrxsown Electrical & Lighting 6 07-25-2006 01:44 AM
Got question about Hella Supertone installation in a GC8 edkwon Mid West Subaru Owners Club Forum -- MWSOC 17 09-10-2002 01:11 AM
