Old 12-30-2005, 11:51 PM   #1
crxtls2
Member#: 9511
2000 Impreza 2.5RS
Silverthorne Metallic
Default Couple of questions about Catalytic Converters
Got a couple of questions about the cats on my 00 2.5RS
1) What is the manufacturers warranty/responsibility on the emissions control devices
2) my car is throwing code c0420 , I'm pretty sure it is that code, and only that code which when looking it up on Snap-On's scan tool database says that if only this code is received that I should check for exhaust leaks, my car has none, and if none is found check the catalytic converters to see if they are damaged and if so replace the cats.
What constitutes a damaged catalytic converter and how can I visually inspect mine and determine if it/they are damaged?
3) If my cats are in fact damaged can anyone recommend a good inexpensive replacement for it/them
Thanks
Joel
crxtls2 is offline   Reply With Quote
Old 12-31-2005, 12:33 AM   #2
jpodlasek66
Member#: 62193
2000 Impreza 2.5RS
Default In the same boat
I have a silver 2000 2.5RS and got the same code up today too at the dealership. The car is at 113k, so I'm sure I'm beyond any manufacture recourse.
My big dilema is going OEM or doing a performance replacement. I have a Stromung catback system now, and someone replied to my initial post about getting a Stromung cat converter for $349. Best price I can get for the OEM is $457. If the Stromung is similiar in durability, I'd love to save the $100 and get some more performance.
John
jpodlasek66 is offline   Reply With Quote
Old 12-31-2005, 01:30 AM   #3
ten80
Member#: 53625
00 16' FXT
My stromong stainless cat looks 100x more durable than the rusty OEM piece I removed. the only reason not to go OEM is that an aftermarket cat will make your exhaust louder.
ten80 is offline   Reply With Quote
Old 12-31-2005, 08:56 AM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Your owners manual will state the warranty for emissions parts (which goes to 80K miles IIRC).
You can get then replaced (within the warranty period) if they break internally or clog.
I doubt you fall into either one of these.
Do you have any engine/exhaust mods? A different header usually pops the P0420 CEL.
Old 12-31-2005, 04:00 PM   #5
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Federal Warranty
Catalytic Converters are covered by the Federal emissions warranty for the first 8 years or 80,000 miles.
http://www.epa.gov/otaq/consumer/warr95fs.txt
-Charles-
ImprezaVA is offline   Reply With Quote
Old 12-31-2005, 06:39 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
If you or someone you know has welding experience you can save quite a bit on a diy project.
www.jegs.com
www.summitracing.com
www.jcwhitney.com
they all sell catalytic converters. Jegs and summit sell exhaust bends. A cat can range anywhere from 54$ to 150$. It's the welding part that most people can't accomplish.
Tim Sanderson is offline   Reply With Quote
Old 12-31-2005, 11:27 PM   #7
crxtls2
Member#: 9511
2000 Impreza 2.5RS
Thanks for the replies guys
I actually dont have any mods but my car is definitely out of the warranty period with 122k on it
Looks like I will be looking into buying an aftermarket cat and installing it
L8R
Joel
Couple of questions about the stock oil pressure sender... Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 6 06-26-2003 07:43 PM
Had a couple of questions about insurance and buying a WRX Dr.Puls Newbies & FAQs 3 09-28-2002 12:01 AM
A couple of questions about body kits. quickdraw Interior & Exterior Modification 4 01-05-2002 12:21 PM
('93-'01) Couple of questions about STi seats... fellfrosch7 Impreza Forum 1 10-11-2001 12:20 AM
A couple of questions about the up-pipe dannyboy7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-14-2001 05:05 PM
