Old 12-31-2005, 10:31 AM   #1
DMOR319
Member#: 102353
1993 IMPREZA L
WHITE
Unhappy 1993 Impreza wont start
I can't find my original question. But hear is the problem. My 1993 Impreza 1.8 with 105499 miles won't start. The car stopped after I returned home from work. I had been having a problem with coolant temp. sensor, the fan would start running as soon as the key was turned on. The coolant temp sensor was changed,the fan problem cleared up.before any codes were retrieved needless to say I have no codes. The crank and cam shft sensors were changed. also the PCV. A timing light was used and my friend who is a mechanic said there seems to be 2 sparks from the #1 cylinder when the key is turned. The timing mark is very small and hard the see on the crank. The engine is at 10 degrees is this correct or is the timing off. We tried spray stil doen't start. We seem to have fuel and pulse. Is ther any where I can get a schematic of the timing belt and its marks. Any help greatly appreciated.
DMOR319 is offline   Reply With Quote
Old 12-31-2005, 12:45 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Original post
It really sounds like the timing is off (especially since it sounds like it pops through the intake and was fine until it was turned off last).
I would really followup on that track. Get the crank timing mark set up, pull TB covers and then chack the timing marks versus the marks on the belt.
Oh, forgot to mention.
I clicked on your profile, and then "find other posts by this person" or whatever it said. The next thread found was your original.
Last edited by Charlie-III; 12-31-2005 at 12:46 PM. Reason: Info on finding thread
1993 Impreza L WILL NOT START HELP!!!! BPLax21 Normally Aspirated Powertrain 13 08-23-2008 01:17 AM
1993 Impreza L WILL NOT START HELP!!!! PLEASE BPLax21 Service & Maintenance 2 08-20-2008 10:53 AM
1993 Impreza tranny wont go into reverse when hot. jeryst Transmission (AT/MT) & Driveline 1 02-24-2008 11:55 AM
1993 Subaru Impreza Won't Start! animestore Service & Maintenance 2 09-15-2004 09:54 AM
Weird starting problem--1993 Impreza KUgrad Normally Aspirated Powertrain 8 03-07-2003 10:07 AM
