Old 12-31-2005, 12:23 PM   #1
Burton4g63
Member#: 85779
2005 2.5 RS Sport
Default Does playing in the snow kill your tires?
Hello everyone,
Ive had my car since June and ive put 8k miles on it, but yesterday I noticed something kinda odd. My front tires (Still RE92) have almost no tread left, but my back tires look worn normally for 8000 miles. Im not a crazy driver but it did snow twice and I had a little fun but nothing that would shave my tires. My family thinks I go around and just spin my tires like some a hole eventhough I tell them thats kinda hard with an AWD Stock 2.5 RS . I dont know whats going on, maybe someone switched them when I went into get serviced? My dads making me buy new tires now and im Pissed!
Burton4g63 is offline   Reply With Quote
Old 12-31-2005, 12:26 PM   #2
solbey11
Member#: 89234
I would take it to a dealership and tell them whats going on. You may have an alignment issue. 8000 miles on tires is ridiculous. The tires should have their own warranty on them as well. It won't be covered under the Subaru Warranty. But the dealership should be able to help you out in getting this situation solved.
solbey11 is offline   Reply With Quote
Old 12-31-2005, 12:31 PM   #3
Anub1s
Member#: 81106
2014 Baby Mobile
Whitey White
Dealership for sure. Your car has more power going to the rear wheels than the fronts, so that would logically mean your rear tires would crap out first if it were because of spinning, not always the case, but most often.
Are the tires wearing funny? Or is it just straight up tire wear?
Anub1s is online now   Reply With Quote
Old 12-31-2005, 12:34 PM   #4
express_wagon
Member#: 68346
2001 M5
2013 Abarth Cabrio
take high res pix of tread and post em here, probably can give you a better answer
we need to know if its shoulders, inside...etc
could be alignment, over or under inflation
express_wagon is offline   Reply With Quote
Old 12-31-2005, 12:34 PM   #5
911-3.2
Member#: 71421
2005 Sold - WRX
Salty Gray Metallic
Definitely have the alignment looked at and check your tire pressures too. 8,000 miles is way too short for relatively normal driving. I have almost 36,000 on mine and they are still very legal. I'll admit they have mostly highway mileage, but you should still get at least 20k out of yours. Once you do get new tires be sure to rotate them every 7500 miles or so too. Also, when you say they have no tread, are they wearing more on the inside or outside of the tire or evenly?
911-3.2 is offline   Reply With Quote
Old 12-31-2005, 12:40 PM   #6
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
Driving style and a bad alignment might be it, mine looked to be about 50% or less on the front side walls.
dingobite is offline   Reply With Quote
Old 12-31-2005, 02:02 PM   #7
REX8
Member#: 24038
What????
Old 12-31-2005, 02:09 PM   #8
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
Also, when it's dry, are you braking really hard?
bl_easy is offline   Reply With Quote
Old 12-31-2005, 05:13 PM   #9
REX8
Member#: 24038
On a RWD car, maybe, but not on his car. His car DOES NOT have more power going to the rear. In fact, he should wear his fronts out first. They do double duty, getting (at least half) of the torque (depends auto/manual) AND the steering duty.
Old 12-31-2005, 05:23 PM   #10
sha_zapple
Member#: 41012
1998 Legacy L
Snow is not going to wear down your tires, front or back. Think about it. Friction causes wear, and the whole reason why you can slide around on snow is because theres very little friction, therefor very little wear.
Sliding around on pavement will demolish your tires and so will hard driving. Since your fronts are worn more than your backs im going to assume you love to go fast around corners (or that theres something wrong with your alignment)
Im also going to go ahead and call BS on either the amount of miles these tires have, or the amount of treadwear (again, unless theres something wonky with your alignment)
sha_zapple is offline   Reply With Quote
Old 12-31-2005, 05:23 PM   #11
DeKaP
Member#: 90627
2005 Impreza WRX
Obsidian Black Pearl
Originally Posted by Burton4g63
Hello everyone,
i dont think its from the snow, maybe alignment so tires wear quicker? i just assume its Awd and the tires should wear equally or am i just stupid right now?
DeKaP is offline   Reply With Quote
Old 12-31-2005, 05:55 PM   #12
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Wow people. There is so much misinformation in this thread.
It's normal for front tires to wear more than rears on our Subarus. Mine did on my RS and mine do on my STi. It's called steering. You've been driving hard and cornering hard. You'll probably deny this, but the fact that your tires have almost no tread left after 8000 miles make it pretty evident. I'd bet if you look closely the outer tread blocks are worn more than the inner blocks of the tires due to the lack of negative camber in the stock suspension geometry. Post a pic.
I wouldn't call you stupid...just misinformed and making what seems like a logical assumption.
Neek is offline   Reply With Quote
Old 12-31-2005, 06:17 PM   #13
Bman
Member#: 64351
2005 Legacy GT
Well if you slide on a thin layer of snow your tires will end up sliding on the pavement, causing a lot of wear. I know today I was drifting in about an inch of snow and when I stopped I could smell burning rubber.
Bman is offline   Reply With Quote
Old 01-01-2006, 05:21 PM   #14
Impresario
Member#: 344
2004 Impreza WRX
Java Black Pearl
Sliding on snow = little to no traction --> very little tire wear.
Are you sure that wasn't the odor of burning clutch ?
Impresario is offline   Reply With Quote
Old 01-01-2006, 05:23 PM   #15
Bman
Member#: 64351
2005 Legacy GT
Yea it was definatly rubber, there was only a tiny bit of snow, that I burned right through once the tires were spinning.
Old 01-01-2006, 07:06 PM   #16
Back Road Runner
Member#: 60082
2004 Forester STI
8000 miles on a tire with a tread wear rating of 160 doesn't suprise me. I'm just glad my Forester didn't come with any It's not that hard to wear down a set of tires if you drive agressive. The REs are especially prone to fast wear due to their design. You'll find almost no tire tha wears faster or has a lower tread wear rating than those tires other than a track tire. Most tires, even cheapies, start at a rating double that.
As far as the fronts wearing first, that's normal. Like what was already said, they're doing triple duty. They have to steer, provide power to the ground, and do most of the braking work. Your car is also a little front heavy and make the front tires work harder to move that extra weight around a corner. They will wear faster. A fwd will wear the fronts a lot faster than the rear. A rwd would wear the rear first if you're remotely heavy on the throttle. An awd can be pretty even with wear, but the weight balance would have to be more even, have a more rear biased torque balance, or have more rear braking bias. Basically, the wear balance would have to be better.
Oh, the burning could be a few things. It can be rubber if you're doing a lot of spinning. Low friction doesn't necessarily mean no wear. You can't do much damage in snow, but on ice, you'll still have a roughness that can chew at the tires some, especially if you're moving 10mph with the speedo at 80mph, lol, think sand paper. Depending on your clutch work, you may run a bit of clutch slip switching between gears, or you may even be playing with the brakes a lot or running ABS a bit where you may get some brake smell.
Old 01-01-2006, 10:42 PM   #17
montana_slim
Member#: 57169
2002 WRX (MBP)
07 Tacoma; 96 Impreza LX
I'd be more worried about the clutch and the diffs when playing hard in the snow as opposed to the tires.
7 inches of untouched snow + empty lot = sooo much fun
montana_slim is offline   Reply With Quote
Old 01-01-2006, 11:57 PM   #18
HomerJay
Member#: 1135
2005 WRX WAGON
RE92's are a pile of ****. Also, if you are hard on your tires, you should rotate more often and make sure you have your tires properly inflated. I rotate my tires w/ oil change, basically every 3k.
HomerJay is offline   Reply With Quote
Old 01-02-2006, 02:08 PM   #19
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
since we are on the topic of RE92, what is anyone's opinion of it in an environment of -40c winter? should I change a set of tires?
ImprezaTs is offline   Reply With Quote
Old 01-02-2006, 04:29 PM   #20
boxxxer
Member#: 84647
-40 C? That's cold. Maybe too cold to produce snow in any accumulation so the RE 92 might be o.k. If there is snow on the ground most of the time I would go with a dedicated winter tire.
boxxxer is offline   Reply With Quote
Old 01-02-2006, 05:14 PM   #21
mch
Member#: 30039
2002 wrx wagon
dirt slvr
The burning smell is your clutch/differntials. When traction is low, tires have limited grip which means as you drive aggressively your differentials / clutch are probably doing MUCH more work than normal - hence the smell.
8000 miles on RE92s is about what I'd expect with a bad alignment and agressive driving. Did you ever check your tire pressure?
Did any of you guys pass high school physics?
cheers.
mch is offline   Reply With Quote
Old 01-02-2006, 05:44 PM   #22
davis10
Member#: 70011
Its def not from playing in the snow because your tires are not biteing on the pavement.
davis10 is offline   Reply With Quote
Old 01-02-2006, 07:25 PM   #23
bowenx
Member#: 6439
2002 Impreza WRX
the RE92's should last WAY more than 8k miles.
heck, i had them on my car for the first year and that included a few autox's...then the next year with a few autox's as well. I now use them as the in-between tires from my summers to winters.
Mine are in no means great shape...but they still have tread on them that would still pass the the Penny test with ease.
I'd look into an alignment.
bowenx is offline   Reply With Quote
Old 01-03-2006, 04:15 AM   #24
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
The place I am going to has snow on the ground for the good 5 months. It doesn't snow much but the temp stays around that area and most of the roads are not plowed at all by snow plow but by daily drivers.
Old 01-03-2006, 08:02 AM   #25
Siper2
Member#: 1134
2007 BMW 328xi wagon
Holy crap another person from my area. I work in Camp Hill.
Cool!
=Chris
Siper2 is offline   Reply With Quote
girls in 2.5RS playing in the snow. coolllll rice h8r Off-Topic 27 12-13-2005 10:36 PM
played in the snow for the first time :) EntrustXXX North West Impreza Club Forum -- NWIC 3 02-07-2005 02:07 AM
Anyone in SJ wanna go play in the snow? joefocker20 Tri-State Area Forum 3 02-18-2003 01:37 AM
Anyone want to play in the snow? BlueScooby New England Impreza Club Forum -- NESIC 0 03-09-2001 06:15 PM
video clips of you playing in the snow? post links here M a t t General Forum Archive 5 12-06-2000 12:09 AM
