Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 12-31-2005, 05:45 PM   #1
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Default Started some pics
http://tinyurl.com/8tbmt
Second album in.
I just started putting pics there, only a very few so far. I was all set to take some pics of the whole car and a huge flock of birds was swarming around my house. I had to pull the car in because I was getting bombed I will do a bump when I get more added.
Peaty is offline   Reply With Quote
Old 01-02-2006, 02:51 PM   #2
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Birds gone added more pics...
Gauge needle sweep on start up:
Old 01-02-2006, 08:43 PM   #3
VSB XT
Member#: 45034
12' WRX Limited
That dark grey color
Very noice! Still fighting myself on not getting one.
VSB XT is offline   Reply With Quote
Old 01-04-2006, 07:22 PM   #4
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Got some goodies on the way. Front end protector (aka bug guard), splash guards and all weather mats. All OEM stuff. I plan on doing scoobymods pages for anyone interested. Hope to have the stuff soon.
Peaty
Old 01-05-2006, 12:05 AM   #5
3rdsub
Member#: 104064
09 Tribeca 7P SE
Newport Blue
Got my splash guards today. Rears look like a no brainer. Fronts require drilling and there are 9 steps. With the NJ weather the lower body is covered with spray from the fronts.
3rdsub is offline   Reply With Quote
Old 01-05-2006, 12:07 AM   #6
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Do you think it can be done with the wheels on or do you suppose they have to be removed? My guess is for the fronts you can at least turn the wheel for room. Not sure about the back clearence.
Old 01-05-2006, 12:15 AM   #7
3rdsub
Member#: 104064
09 Tribeca 7P SE
Newport Blue
The instructions say to turn the fronts for installation, nothing about the rears. I can't tell from the illustrations if you do the drilling horizontally or vertically into the bottom. There is a paper template for the hole location.
Old 01-05-2006, 09:17 AM   #8
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Thanks for the follow up, looks like my stuff will be here Friday so I'll do it this weekend and post the page shortly
Old 01-05-2006, 09:50 AM   #9
3rdsub
Member#: 104064
09 Tribeca 7P SE
Newport Blue
Great, weather permiting I'll at least do the rears. The Tribeca really needs the splash guards. My 99 OB came with them and my 03 GT wag never seemed to need them.
My upgraded Valentone One should be here Fri and I'll definitely be wiring it. Thanks for the heads up on the power choice!
Any thoughts about the shock sensor install?
Old 01-05-2006, 11:06 AM   #10
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
I will be doing that eventually, I'm waiting on my 500 subaru bucks I have coming to me The stuff I'm doing this weekend I didn't think could wait for since it protects the finish.
For the shock sensor, I understand that there is a harness under the passenger seat you just plug into. However, then the security system needs to be reprogrammed and AFAIK only the dealer can do that I want to call my dealer and check what they will charge for that. I'll let you know what I find out. I think they need all the keys too for the programming.
Peaty
Old 01-07-2006, 11:33 PM   #11
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
Took some more today after installing the front end protector and mud flaps.
Old 01-08-2006, 02:42 AM   #12
zaarin
Member#: 95404
2002 WRX Wagon
What color is bird crap?
Nice shooting! I really like that last one a lot. The one at the top of the headlight cluster is nice too. You must have an insane lens to get that kind of ... whatever the technical term is for fisheye view.
zaarin is offline   Reply With Quote
Old 01-08-2006, 05:34 PM   #13
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Mudflaps look good although a little small.
I didn't think the front end could look any worse but I guess I was wrong.
Mike Wevrick is offline   Reply With Quote
Old 01-09-2006, 10:29 AM   #14
3rdsub
Member#: 104064
09 Tribeca 7P SE
Newport Blue
Don't care much for the hood deflector either.
How did the splash guard install go? It was too cold here to even think about trying.
Old 01-09-2006, 11:09 AM   #15
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
I'm not crazy about the looks of the front end protector either but it serves a purpose. It would look better on a dark car that's for sure. It would be less noticeable like the one on our Black OB was.
The mud flaps were kind of tricky. Lots of those plastic fasteners to remove and replace. The inboard ones were hard to get at as it was pretty tight quarters. Not difficult but time consuming. I was able to do it w/o taking the wheels off though. The fronts involved drilling two holes in the plastic rocker panel material. A 7 and 10mm sized hole which were easily located with the templet that came with the directions. In order to get the drill under there I had to jack up the front. I did it one side at a time using the tie loop on each side as the spot to jack it up with a big floor jack (mine has a rubber pad)
The rear looks like a puzzle at first with this bracket you need to mount. It becomes more obvious when you are there with the parts though. The hardest part for the rear install was the inside fastener, I used a very long Phillips screw driver to turn the head. A 1/4 turn and the head pops out enough for you to grab it then pry it out. The mud flaps are not very big, or at least they do not stick down very far. They integrate into the body work so much you'd be hard pressed to notice them after the install.
I say wait for warmer weather or find someone's garage to use, you will need a fair amount of manual dexterity to work with the fasteners. If you lived closer I'd do it for you. Now that I've done it once I think I could do it a lot faster.
Old 01-09-2006, 12:35 PM   #16
3rdsub
Member#: 104064
09 Tribeca 7P SE
Newport Blue
Thanks,
Really appreciate your sharing. Wasn't surprised about the jack for the front. A really long phillips? How long? Can't get to it with a really short one?
Old 01-09-2006, 01:26 PM   #17
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
For the screwdriver first I tried a small right angle ratchet type and that will work but you need to get your arm up in there to push on the top to keep it in the fastener. I have what I think is a 18" screwdriver, I'm sure you can use something shorter but the longer one gave me a better angle. I'm not a big guy but my forearms are kind of big and I could not get up in there in back of the tire. It was easier for me to work from around back of the tire on the inside of it by the brakes.
Old 01-11-2006, 07:47 PM   #18
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Finally, some pics of a "modded" Tribeca. I have been waiting for someone to start adding goodies to theirs.
Tkacik is offline   Reply With Quote
Finally the weather is starting to calm down, shot some pics. evohuntinwrx Member's Car Gallery 28 05-10-2007 07:48 AM
Some pics of the 22B that some of you asked for rsquire_downunder Member's Car Gallery 39 11-10-2004 11:48 PM
Some pics of my car and some random Flyn'Rex Member's Car Gallery 20 08-27-2004 10:22 AM
Some pics.. all clean and got some wheels drunkguy Member's Car Gallery 11 06-08-2004 02:11 PM
Some pics from the Dragon.. some of the flip.. watcher in the sky South East Region Forum 6 06-13-2003 01:10 PM
