Old 01-01-2006, 11:28 PM   #1
hubsnake
Member#: 103363
2006 Impreza WRX
WR Blue Pearl
Question Bolt pattern Conversion worth it?
Ive searched but found a lot of old info on this. Traded my RSX in and got an 06 WRX. I was going to sell my 18 x 7.5 Gram Lights but I see that the Sti has the 5 x 114 pattern. Now on the 06 Wrx would it be just a simple hub swap or is it the majority of the suspension. If it is easy to do I would love to keep these wheels but if it is to involved I dont want to deal with the headaches.
hubsnake is offline   Reply With Quote
Old 01-01-2006, 11:38 PM   #2
Silver571
Member#: 88361
I'm not sure the answer to that question.. BUT, if you swapped the bolt patter with an 05-06 STi then wouldn't you want to keep the STi brakes? Infact, I think you would have to, or try and make the 04s fit. Either way you end up with the STi brakes and im not sure... but I don't think your wheels are going to clear the brakes. Regardless, its going to be expensive. Best bet would be to sell your wheels and either get the same ones or find a differnt set you like. Best of luck to ya.
Silver571 is offline   Reply With Quote
Old 01-01-2006, 11:58 PM   #3
Jim Lewis
Member#: 92551
2005 Saab 9-2X
You mean the Gram Lights fit the RSX? You have offset problems, then, not just bolt pattern issues.
Jim Lewis is offline   Reply With Quote
Old 01-02-2006, 12:53 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....buy the right wheels......really
Old 01-02-2006, 01:15 AM   #5
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
You will easily spend more money converting than you would just buying the same wheels with the right bolt pattern and offset.
THAWA is offline   Reply With Quote
3.0 conversion...worth it? suex Subaru Conversions 10 12-07-2014 08:34 PM
Is the sedan fender conversion for the wagon worth it? kenny08 Interior & Exterior Modification 8 05-16-2005 11:43 AM
STI 2.5 shortblock bolted into 02 WRX with 2.0 heads Worth it? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-24-2003 11:00 AM
Rear camber adjustment bolts worth it on stock suspension? Tex-WReX Brakes, Steering & Suspension 2 11-08-2002 09:47 PM
Subaru 4POT Brake Conversion- Worth it? SoLiDbReAkZ Brakes, Steering & Suspension 10 01-01-2002 03:14 PM
