Old 01-02-2006, 12:21 AM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default Can an O2 sensor read only lean?
My O2 sensor, which I am monitoring through a Perfect Power 6, never ever ever dips below 13.1. And thats if I feed it enough fuel it almost bogs.
It has no problem jumping up to the 20s when I let off the gas. And it reads perfect 14.6-14.7 when cruising.
But when under hard and not so hard accelleration, it barely, if ever, drops below 14.0.
I have run it on a dyno with a wideband, and the wideband showed I was getting down to the 11s. But I was unable to compare to the laptop at the time.
So, basic question.....Does your standard O2 sensor tend to suck? This sensor is less than a year old, but I have run tolulene and Torco through it daily.
Old 01-02-2006, 08:25 AM   #2
quazimoto
Member#: 70395
It depends on what sensor your reading off,the front or the rear one.But neither of those sensors are a true wideband.You need to purchase a wideband 02 meter that has a 5v outlet for the Perfect Power.Most do i believe,have a 1v and a 5v but just check before you buy.
quazimoto is offline   Reply With Quote
Old 01-02-2006, 11:48 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
duh
narrow band 02 sensors won't read below 13.2 at all
and are inacurate every where except 14.7
basicly what a narrow band will tell you is if you are above or below stoimetric but the numbers are worthless
Old 01-02-2006, 05:50 PM   #4
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
WolfPlayer is offline   Reply With Quote
Old 01-02-2006, 06:02 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
intersting ... something huge missing from that though did you log the front o2 (not narrowband) or the rear
reddevils is not a wideband at all
Old 01-02-2006, 10:19 PM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Watched it today for a little bit after the wagon had been sitting for a few hours.
It is a single front unit by the way, a Bosch on a 90 legacy.
It dropped a few times down to 12.1 when I would let up on the gas, so it does read lower. But obviously its not a wideband that reads more accurately.
Old 01-03-2006, 07:28 AM   #7
WolfPlayer
Member#: 65054
2005 STI (CGM)
Oh, definitely the front. The rear one is even more useless.
t
Can anybody do an o2 sensor test? JeffyLube SCIC Private Classifieds 12 09-19-2009 11:13 PM
HELP!!! Problem with 2nd O2 sensor running a lean code? JTS88 Newbies & FAQs 7 05-25-2009 08:35 PM
Can I find an O2 Sensor Locally? iLuveKetchup Tri-State Area Forum 7 03-20-2009 08:11 PM
Can you clean an O2 sensor? svxr8dr Newbies & FAQs 8 10-25-2003 12:05 AM
W/W an O2 sensor to read slow & inaccurate? Niloc Normally Aspirated Powertrain 9 11-14-2001 07:55 AM
