Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 01-02-2006, 03:44 AM   #1
jlee8196
Member#: 22211
Default Hydra cold start tune help
I have own a hydra EMS for a year now. I have notice that the car's cold starts
differently with the temp. for some reason when the weather is warmer (60+) the car is having hard time to start, or sometime dies right after starts. But works fine with it's colder during the winter time.
For summer time or warmer weather the car needs about 3+ trys to starts. And Backfire occurs in the exhaust. Which I heard is bad for turbo's health. Any idea on how to tune this.
I guessing there is too much fuel cuz of backfire or too much retard in timing.
How do I tune timing on start up and where should I cut fuel, post or enrich?.
jlee8196 is offline   Reply With Quote
Old 01-02-2006, 05:20 AM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
Did you ask Phil at elementtuning.com for help yet?
supermarkus is offline   Reply With Quote
Old 01-02-2006, 06:50 PM   #3
bboy
Member#: 56468
04 Improved STI
Dirty White
There's a lot that can be done to help you. Several maps impinge on the start up characteristics. There's no reason you should have to try 3 times to start. I'm reluctant to give you specific advice since each of the maps has slightly difference effects.
I'd likely focus on the "Cranking Enrichment" map in the 10C and 20C columns, but it's hard to tell without more knowledge of how YOU start your car.
Are you turning the key completely off each time when you do your "3 try" starts? Or do you turn to the ON position only once?
Do you allow the fuel pump to prime when starting, or just twist to start?
Does it afterfire only multiple start attempts?
You speak of air temp when you have trouble starting. Do you also have trouble starting after the car has been run and then sits for awhile? In other words, this is a coolant temp related problem more than an air temp one.
Old 01-02-2006, 11:59 PM   #4
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
If it starts easier when really cold you probably have your cranking enrichment too high.
When the 2.5 version of the Hydra becomes available you might want to look into the upgrade. It's going to have much improved cold start routines.
no-coast-punk is offline   Reply With Quote
Old 01-03-2006, 02:59 AM   #5
jlee8196
Member#: 22211
So when does the new version comes out?
well, Once the engine is been started once it has no trouble restarting, even after it started for 1min. and shut off it'll restart fine. It more like leaving it overnight or 4+hr.. then is hard to start next day.
I do let the engine to prime on the first try, like wait 3 second in the start then crank. but not after, like turn to off position then to start and crank, just recranking it 2&3 trys. Only does it on it warmer days. The only way I can start the car first try is to pump the gas peddel while cranking it. But that gives backfires.
I have try crank enrichment, but doesn't seem to work. And It kinda hard to tune is. cuz if I can started once after like 3trys. It'll restart fine.
It's weird.. I did change from a tmic to fmic.. but not sure that's effecting the starts.
Old 01-03-2006, 01:10 PM   #6
bboy
Member#: 56468
04 Improved STI
Dirty White
Try raising or lowering cranking enrichment at the coolant temp where you experience trouble. If your FMIC install coincided with the start trouble, I might check your BOV for sticking.
Old 01-04-2006, 09:41 AM   #7
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Read this as it covers tuning the start cycle:
http://www.elementtuning.com/technic...ningguide3.htm
I suspect if it starts better when cold then some of the settings are too lean when warm. If you have leaned out your entire fuel map this may be the cause so you can either add fuel back in to the start areas of the fuel map or follow the tuning guide and readjust the start settings.
Thanks,
Phil
Element Tuning is offline   Reply With Quote
cold start up help SubaruImpreza_power Normally Aspirated Powertrain 7 02-16-2010 07:09 PM
Help E-85 cold start 32 bit sti ecu tuning!!!!!! Cone Klr Open Source Reflashes 4 10-28-2009 08:49 PM
Rough to no idle idle at cold starts?? Please help! Clzay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-11-2007 12:33 AM
Best injectors for STi in terms of idle/mileage/cold start when tuning with UTEC only RossWRX Engine Management & Tuning 1 12-26-2005 03:11 PM
850cc's lean cold start diagnosis help Macabre Engine Management & Tuning 67 11-01-2005 01:52 PM
