Old 01-02-2006, 10:42 AM   #1
Andreas Miko
Member#: 42738
2004 WRX STI
Default Just need some opinion on STI Pink springs and STI Pink 4 way adjustable shocks for 0
Ok I got a 04 STI and I am upgrading the suspension. I do not want coil overs. So I have been looking at getting the combo lised below.
STI Pink Springs
STI Pink Shocks or ( Ohlins 25 way adj shocks )
Racecomp Eng Camber Plates
STI Rear Hardened Strut Top Mounts
Now my question is I was told by the guy at Racecomp Eng that the STI pink shocks cause a bouncey ride, I just want to know if ths is true from the guys who have used the Pnk shocks. I want the Pinks shocks as I am trying to keep everything original Subaru stuff but if the are bouncey then I will go with the Ohlins shocks.
Andreas Miko is offline   Reply With Quote
Old 01-02-2006, 10:54 AM   #2
Rail
Member#: 38287
2005 Honda S2000
NFR
I haven't noticed a ton of bounce with my Arais(apart from the seat microbounce, but that's another issue entirely). Be sure to run the appropriate matching springs with them, though(the Rev C pink springs that everyone uses with the stock STi struts will more than likely be too soft), but I'm sure Myles told you that already.
That said, if you're buying new(not takeoffs/secondhand) for everything I'd just go ahead and get the Ohlins struts - they'll give you a lot more flexibility to fine-tune your setup. I'd probably be running them if I had the cash.
Rail is offline   Reply With Quote
Old 01-02-2006, 02:04 PM   #3
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
i have the sti pink springs, but jdm, they do create a bouncey ride, but then again they are pretty stiff as well
but yes they are bouncy
Thran is offline   Reply With Quote
Old 01-02-2006, 03:27 PM   #4
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
The PINK springs DONT make the STi stock struts bouncy. The OEM Sti stock struts ARE bouncy without any help. The Pinks help remove the bounciness.
The PINK STI JDM struts with 4 adjustment clicks are inthe same respect as OEM Sti struts,..............bouncy. As ALL JDM Japanese coilovers and struts are. HOWEVER, they are still good, but dont have the same behavior as say a Bilstein, or a OHlins, or a AST, or a KW, or a Whitline would. ALL the european brands take a different approach to suspension tuning due to the wider range of tarmac conditions for the roads and tracks in Europe. Most of the tracks and roads in Japan are smooth, so the rebound can be very high and it not be an issue.
Thats what I meant.
So different stroke for different fokes. In a nutshell.
For specific set up advice, call 410-730-7223 ask for Myles.
Racecomp Engineering LLC.
GTWORX.com
GTWORX.com is offline   Reply With Quote
Old 01-16-2006, 08:28 PM   #5
sshus924
Member#: 61172
2006 WRX STI
Rally Blue
What about Tein Coilovers? Adjustable and height adjustable.
sshus924 is offline   Reply With Quote
Need some opinions on progress so far, and future plans. CalcVictim Member's Car Gallery 15 08-08-2004 11:53 PM
Just in brand new Sti pink springs and Sti sway bars subaruxtra.com Suspension/Brakes/Handling 0 07-16-2004 10:43 AM
STI 4 way adjustable struts for new WRX jmott Brakes, Steering & Suspension 7 08-09-2002 05:04 PM
need some opinions on fog and headlights dijay Interior & Exterior Modification 2 04-29-2002 04:22 AM
WTB: RS Exhaust and might need some opinion on ticket! SONofSAM Bay Area Impreza Club Forum -- BAIC 13 04-13-2002 12:29 AM
