Old 01-16-2006, 04:50 PM   #1
scrmblr2
Member#: 24631
2005 STI
Exclamation Help!
Ok, to make a long story short, I was installing my pink springs and rce camberplates, and one of the front struts on my 05, the threaded rod that holds the whole assembly together snapped!
I was wondering if you can swap the inserts between the 04 and 05 struts? If so, should I do both the front struts so the car is even? Should I do all 4 sturt insers?
I have a great deal on a set of 04 units,less than a new replacement for my 05 from the dealer.
scrmblr2 is offline   Reply With Quote
Old 01-16-2006, 08:06 PM   #2
BlkTS02
Member#: 50142
2002 2.5TS
MBP
I'd imagine they're very similiar, although I would get confirmation on this. Why not ask your dealer?
Go easy with the impact gun, those nuts don't need to be super tight (40 ft/lbs IIRC)
BlkTS02 is offline   Reply With Quote
Old 01-16-2006, 08:19 PM   #3
scrmblr2
Member#: 24631
2005 STI
Dealer will always say no, that way you have to buy new.
Only one of 3 I had a problem with!
As a solution I ended up having to order a new one. Unless someone has a used driverside front strut for an 05 sti they want to get rid of cheap>
PM me if u do.
