Old 01-03-2006, 11:56 AM   #1
eightants
Member#: 79242
Default 2002 wrx - is there a glow ring around your ignition?
Sup guys, I saw some pics of a WRX the other day, and it had a glow ring around the ignition switch. I looked at mine, and it's not there. It actually looks like the ignition has been messed with (there's a uneven amount of space around the the actual key switch and the adjacent plastic). So is it just my car (second hand) or are all 2002 rexes like that?
thanks
eightants is offline   Reply With Quote
Old 01-03-2006, 11:57 AM   #2
Pat L.I.
Member#: 20498
2006 WRX TR
my 02rs doesnt have it
Pat L.I. is offline   Reply With Quote
Old 01-03-2006, 12:02 PM   #3
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
The 02 wrxs don't get the glow ring
Worxman02 is offline   Reply With Quote
Old 01-03-2006, 12:05 PM   #4
eightants
Member#: 79242
doh.
ok, good that nobody fscked with it, bad that it don't get one.
shrug.
thanks guys.
Old 01-03-2006, 01:23 PM   #5
Bort
Member#: 27075
03 WRX, 98 OBS,
05Leg, 95Leg
It was new for 03.
Bort is offline   Reply With Quote
Old 01-04-2006, 02:54 AM   #6
killerfly128
Member#: 104287
can you fit a glow ring on a 02' if you get the hardware off a 03' ??
killerfly128 is offline   Reply With Quote
Old 01-04-2006, 04:55 AM   #7
hpracingwrx
Gone... But not forgotten
Member#: 16772
2003 R6
i miss my rex....
if u look at an 02 and 03 ull notice a lot of subtle differences, i.e. the glow ring, bolts where there used to be screws, different parts #s, etc.
hpracingwrx is offline   Reply With Quote
Old 01-04-2006, 12:42 PM   #8
Jfrankon
Member#: 20254
2010 VW GTI
2010 Outback 3.6R
02 is/was so ghetto compared to the later years....its the little things really.
Jfrankon is offline   Reply With Quote
Old 01-04-2006, 02:44 PM   #9
StealthfishWRX
Member#: 57473
04' REX
mines has it, its like green? don't really notice it tho, so you're not missin much.
StealthfishWRX is offline   Reply With Quote
Old 01-04-2006, 09:58 PM   #10
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
with the exception of the trim ring, the 02 and 03 interiors are identical (in mid-02 they changed some things - little stuff like the ridges between switches on the drivers door and stuff like that) - I think comparing a late 02 to an 03, the trim ring is the only difference. In 04 they changed the color of the painted trim to be a little darker, moved the tach to the middle, and changed to the integrated headrest seats (which aren't as well bolstered, imho) with that funky waffle fabric. The first major change (trying to go to the "integrated" looking center console) was in 05... I like the darker trim in the 04, but the seats are better in the 02/03... realistically, none of the WRX's are really all that fancy inside...
I am not sure what screws were changed to bolts as suggested above, or why bolts are even necessary or better in those applications (if it's low torque, there's really no benefit to a hex head bolt over a phillips head screw, assuming the threaded part is the same...)
Old 01-11-2006, 10:52 PM   #11
ousd2ndbncdr
Member#: 74538
Default i have a glow ring
I drive an 2002 WRX and i have a glow ring? maybe the previous owner put it on?
ousd2ndbncdr is offline   Reply With Quote
Old 01-11-2006, 10:58 PM   #12
subiedude03
Member#: 92599
ill guess a late model 02
subiedude03 is offline   Reply With Quote
Old 01-11-2006, 11:00 PM   #13
kaisersouse
Member#: 85900
2001 Forester S
possibly the OP has a model made in late 01 vs early 02. the later built ones may have gotten the ring as they shifted to manufacturing the 03. I know the 95 blazer....some are odb1 and some odb2 cause thats the year they switched.
edit: subiedude beat me
kaisersouse is offline   Reply With Quote
Old 01-11-2006, 11:13 PM   #14
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
mine was built the month before 03 production began and doesn't have the glowing trim ring - I remember when the 03's came out, that was one of the few differences which were pointed out.
Old 01-12-2006, 12:36 PM   #15
RexInvader
Member#: 104745
2006 Black STi
2002 Silver WRX
Mine doesnt have one either
RexInvader is offline   Reply With Quote
Old 01-15-2006, 08:33 PM   #16
hpracingwrx
Member#: 16772
2003 R6
i miss my rex....
if u got the car in 2002 it is probably an 03
most of us 2002 owners purchased the car in early 01
Old 01-15-2006, 08:48 PM   #17
Rallycarperson
Member#: 53971
#35 2.5RS Rally Car
MAP-RALLY.com
Subaru started producing the ignition ring in 03 and up WRXs. It was not in 02s...that was the only interior difference in 02-03 WRXs.
I'm sure SOA has a part number for it.
~Mark
Rallycarperson is offline   Reply With Quote
Old 01-15-2006, 09:43 PM   #18
02redwagone
Member#: 87067
02 Old but tasty
SRP
<----proud to not have a glow ring. No missing the hole here.
02redwagone is offline   Reply With Quote
Old 01-15-2006, 10:36 PM   #19
wrxsubaruwrx
Member#: 60415
2012 WRX
Yeah you don't want to miss the hole .
wrxsubaruwrx is offline   Reply With Quote
the glowing ring around the key fob k_duraman Interior & Exterior Modification 4 01-18-2008 11:07 AM
why is there a perfect ring..... immigrant Off-Topic 18 03-01-2007 10:19 AM
Is there anything like Meijers around here? sherifx Southern California Impreza Club Forum -- SCIC 3 09-20-2003 06:19 PM
is there any decent gas around lake forest? mlambert Southern California Impreza Club Forum -- SCIC 2 03-31-2003 12:32 AM
Is there an o-ring..... Karl New England Impreza Club Forum -- NESIC 3 02-08-2003 08:42 AM
Message Board Statistics All times are GMT -4. The time now is 09:24 AM.
