Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-03-2006, 11:57 AM   #1
tcr04
Member#: 102871
2006 wrx
Default i want to lower my car but also want to have even tire wear.....
Would this be possible if i just buy springs for the car or do i need to buy coilovers (spring and struts). I thought about getting maybe an sti strut and springs since it's stock and will keep my tire wear evenly. Suggestions please, thanks.
tcr04 is online now   Reply With Quote
Old 01-03-2006, 12:08 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
you can get even tire wear with most drops. you just have to have it aligned corectly.
shane
PARANOID56 is offline   Reply With Quote
Old 01-03-2006, 12:13 PM   #3
tcr04
Member#: 102871
2006 wrx
well when i had a civic, i had adjustable struts and coilovers and the tire wear was never even. I inside would always wear out no matter how they align it. They said they couldn't get it back to factory specs. I just don't know if it's the same with wrx. I'm new to all this.
Old 01-03-2006, 01:19 PM   #4
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
As long as you get springs without too much of a drop (if using stock suspension components elsewhere) and a good alignment, I see no reason why you shouldn't be able to get even tire ware.
boundy3 is offline   Reply With Quote
Old 01-03-2006, 01:31 PM   #5
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
You don't have a civic anymore.
THAWA is offline   Reply With Quote
Old 01-03-2006, 02:42 PM   #6
platinum_sti
Member#: 100025
96 Impala
I got my tein s-techs as soon as i got my car brand new and 23000 miles later I'm still riding on my stock bridgestones and they're wearing even as if there was no drop get an alignment as soon as you do the drop, maintain the right air pressure and rotate and balance your tires and you'll be fine
platinum_sti is offline   Reply With Quote
Old 01-03-2006, 02:46 PM   #7
keaniegenie
Member#: 94494
2005 Element 92x
If you're looking for a more aggressive drop, all you need is the camber adjusted. You can ether buy the kits or have somebody make custom camber kits.
keaniegenie is offline   Reply With Quote
Old 01-03-2006, 03:14 PM   #8
hikeeba
Member#: 89165
Poop Stuck Survivor
-=C=- & subari87 FOREVER!
And as long as you stay with a tire that is close to the stock 205 width, you'll be ok. My car is lowered close to 1.5" in front, and after running my summer 225s for 6 months, I can just ever so slightly see evidence that the inside shoulder (front tires) is wearing a little faster than the rest of the tire. I haven't seen the problem with the 205 snow tires I am running now. My car is within factory alignement specs without the use of cam bolts or camber plates.
hikeeba is offline   Reply With Quote
Old 01-03-2006, 03:27 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....there is no 'kit'...'kits' are hunduha.....
ya got a subaru and ya got 3 ways to do it...
1..... camber or 'crash' bolts(usually rear, can be used on front)
2.....adjustable strut tops(front or rear)
3.....adjustable lateral links(rear)
....so pick one or a combination of them.....some tops adjust caster(front) as well....and the adjustable rear lateral links can adjust track and toe, too.
...and it is toe, out of spec, that usually eats tires....NOT excessive camber....dropping( slamming) alters toe as well as camber and THAT is what usually kills tires.
'0' toe is good
Old 01-03-2006, 04:04 PM   #10
tcr04
Member#: 102871
2006 wrx
so what you're saying is that i can't just drop the car and align it. I have to do one of the 3 to fix the toe.
Old 01-03-2006, 04:31 PM   #11
BlkWRXWag
Member#: 31821
2015 DS WRX
"One of the 3 things" applies to camber.
You can drop it and align the toe just fine. Just don't drop it too much. Do a search on springs and do some reading.
BlkWRXWag is offline   Reply With Quote
Old 03-06-2006, 09:22 AM   #12
STix66
Member#: 104433
2016 Mercedes - GLE
past cars-06 STI /13 WRX
I just got Cobb Springs (Drop is 2.0 in the front 1.5 in the back on stock STI springs).
Will I need a camber kit...does this constitute too much drop?
According to Cobb the stock 06 STI springs are not ideal.
Just asking....
STix66 is offline   Reply With Quote
Old 03-06-2006, 12:21 PM   #13
BlkWRXWag
Member#: 31821
2015 DS WRX
Just put the springs on and get an alignment. Max camber up front and zero toe all round. No "camber kit" required. We do not have camber kits on Subaru's, just camber bolts. The fronts have bolts already - the rear does not, but you shouldn't need to adjust it unless you are looking to do something unusual with your car.
Old 03-06-2006, 01:03 PM   #14
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Correct.
-Biggly
DrBiggly is offline   Reply With Quote
Old 03-07-2006, 04:24 AM   #15
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
'0' toe is good
And that would have to be one hell of a SLAMDROP to get the toe to go out of spec. . .
nhluhr is offline   Reply With Quote
Old 03-07-2006, 04:33 AM   #16
jamal
Member#: 71875
98 Legacy GT
my wheels fit
http://wrx.dicknogs.net/suspension/bumpsteer_sti.gif
woah neat. Does one of those exist for camber as well?
Edit: right there in the same folder. Sweet!
jamal is offline   Reply With Quote
Old 03-07-2006, 04:33 AM   #17
jamal
Member#: 71875
98 Legacy GT
my wheels fit
For some reason I only make accidental double posts on nasioc.
Old 03-08-2006, 02:46 AM   #18
Seamless_Linc
Member#: 109240
788 of 800
Barcelona Red Metallic
Default Tein S-Tech
Hey there guys! i got a 2006 wrx and i'm thinking of lowering it, but not too low. just so it would give my car a more agressive look. i'm loking in to some Tein S-tech's lowering springs, how low are they? 1.5?2.0? and no need for camber bolts with this drop right? just alignment? if there's anyone in here who has picS and experience with them that they can show will be muchly appreciated! thanks!
just a friendly subaru enthusiast!
Seamless_Linc is offline   Reply With Quote
Old 03-08-2006, 05:54 PM   #19
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Dude, search for s-techs. Lots of bad things to be said about them in these parts.
waktasz is offline   Reply With Quote
Old 03-08-2006, 06:05 PM   #20
FUJITSTIBO
Member#: 85135
easiest fix.
1 get new camber bolts (check out oakos automotive), the fronts are fine just need them for the rear.
2 get aligned with 0, ZERO toe and you'll be fine.
FUJITSTIBO is offline   Reply With Quote
Old 03-08-2006, 08:21 PM   #21
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Quick fix for what? No need for camber bolts unless you need them to get some specific camber settings for racing or something. You car will be fine with lowering springs and an alignment afterwards.
I want to lower my car....suggestions? chaoskingb Rocky Mountains Impreza Club Forum -- RMIC 28 11-22-2008 04:38 PM
I want to drop my car, but how? ROCKMIKES Newbies & FAQs 23 02-23-2006 02:14 PM
want to lower my car, I live in San Jose,CA thetrickster9 Brakes, Steering & Suspension 6 10-04-2002 04:33 PM
Do I have to lower my car if I get 17's? WRX23 Brakes, Steering & Suspension 5 05-20-2002 06:57 AM
I want to lower my WRX but....... malelee21 Brakes, Steering & Suspension 0 12-06-2001 01:50 AM
