Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Interior/Dressup/Audio & Security
Old 01-03-2006, 05:04 PM   #1
Audiomotive
Vendor
Vendor Sales Rating: (8)
Member#: 100227
2005 STi
Default **Audiomotive Gruppe** - Xenarc 700TSV (Black) VGA CarPC Touchscreens - Special $359
XENARC 700TSV
7" TFT LCD Touchscreen Monitor w/ VGA & Optional AV inputs
Now with 5-Wire Resistive Touchscreen!
Xenarc Technologies Corp. is one of the first LCD manufacturers to introduce a 7" LCD screen with VGA input and Touchscreen. In-Car computing is the next step in computing technology, and we are committed to serving this up and coming technology sector.
This popular product incorporates the innovation of our VGA 7" models along with a 5-wire resistive Touch-Screen panel. Use the convenient touch-screen as your input device, control your mouse cursor or the mini on screen keyboard that comes with your operating system. The touch screen utilizes the USB port as the interface. You can connect several 700TSV monitors to your computer and the touchscreens would work simultaneously through the multi-monitor support.
These monitors come included with an instruction manual, a copper monitor stand, an AC adaptor, a connection cable, cigarette lighter car adaptor, and touchscreen drivers for DOS, Windows, Linux, and Mac OS.
Features
For In-Car Computing, PC, Server, GPS, and various VGA Use
5-wire resistive Touch Screen (USB) *New*
Multi-Monitor Touchscreen Support
VGA Input (15 pin D-SUB) x 1 (700TS) or VGA Input x 1 & Video Input x 2 (700TSV)
Audio Input / Built-in Speaker (700TSV)
NTSC / PAL Multi-System (700TSV)
16x9 Aspect Ratio
High Resolution Display - up to 1600 x 1200
Auto detects 800x480 resolution
Upgraded High-Brightness CCFL Backlight
Adjustable backlight level for night-time use
Pixelworks High Performance Video and VGA Processor
High Quality Scaling & Anti-Aliasing
16:9 / 4:3 Scaler settings *New*
Last Input memory (700TSV) *New*
Last Power setting memory *New*
IR Remote Control (700TSV) *New*
Auto power-on upon signal detection
Automatic display adjustment
On Screen Display Control
Metallic Silver or Black Casing
Copper Stand: 360 / Height Adjustment
20-Pin heavy-duty connector
Anti Glare Coating
Supports 11V DC ~ 24V DC
"E" Mark Certified for Automotive use
Compare Features
Specifications
Model #: 700TS / 700TSV
Screen Size: Diagonal 7" (16:9)
Physical Resolution: 800 (H) x 480 (V) WVGA
Supported Resolution: 640 x 480 ~ 1600 x 1200
Dot Resolution: 2400 x 480 = 1,152,000 (dots)
LCD Brightness (w/o Touchscreen)*: 400 cd/m
Display Brightness (w/ Touchscreen): 330 cd/m
Touch Screen Interface: USB port
Operating Voltage Range: DC 11V ~ 24V, 1A
Power Supply: DC 12V
Power Consumption: <8W
Operating Temperature: 23F ~ 158F
Dimension (in): 7.75W x 4.75H x 1.38D
Weight (lb): 1.28
FCC, CE, E13 Certification
18 Month Warranty
Available in Silver or Black
30 days No dead Pixel Guarantee
*LCD Panel Manufacturer's test result based on specific test environment. Number corresponds to maximum output and should not be confused with typical output. Typical output has to compensate for different factors and is also reduced to prolong the life of CCFL.
5-Wire Resistive Tochscreen Advantage:
5-wire resistive analog technology is superior to 4-wire, 8-wire and resistive matrix technologies
Most durable resistive analog - drift-free operation even when exposed to temperature fluctuation
Life span of 35,000,000 touches versus 1,000,000 touches from 4-wire resistive
Increased optical clarity equals higher brightness and a sharper display
Greater touch point density means better accuracy
Faster response time and increased speed
No external electronic correction needed
All this means, our great product gets even better while the price stays the same. While others are constantly cost cutting by switching to cheaper, inferior components, Xenarc is constantly working on bringing you the best products with the most advanced technologies
Special $359 plus shipping. PM or email [email protected] for questions or odering.
Audiomotive is offline   Reply With Quote
GA- 7" liliput carpc touchscreen screen with subaru impreza bazel attached nsvwrx Interior/Dressup/Audio & Security 11 06-13-2008 02:06 AM
7" liliput carpc touchscreen screen with subaru impreza bazel attached nsvwrx Interior/Dressup/Audio & Security 10 06-07-2008 10:23 AM
Custom CarPC Xenarc LCD Bezel for another WRX CarPC Audiomotive Car Audio, Video & Security 22 02-03-2006 03:52 PM
Where can i get a bezel to fit a XENARC 700TSV 2002bugeye Car Audio, Video & Security 2 12-12-2005 11:22 AM
any pics of a XENARC 700TSV in dash??? 2002bugeye Car Audio, Video & Security 12 12-11-2005 10:37 PM
