Old 09-12-2001, 01:15 PM   #1
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Default Adjustable Cam gears for SOHC
sooo.. we have been hearing rumors that aem will make them ...
is this usefull..with adjustable gears on a SOHC exaust and intake be retarded/advanced at the same time ...
help here little lost?
-j
Old 09-12-2001, 06:59 PM   #2
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
typically retarding the cam will increase peak power, and move the peak higher in the revs (not a good thing unless you can increase the rev limit safely, ie better valve springs etc) advancing the cam does just the opposite. could be usefull for eliminating lag on a turboed car
yamarocket630 is offline   Reply With Quote
Old 09-13-2001, 10:56 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ooookay ...
so what would it do for a N/A engine
- it seems from their (AEM) web site that they are in fact not making cam gears for he 2.5 but for the DOHC wrx instead .. which i understand.
Old 09-13-2001, 12:39 PM   #4
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
It has the same effect on a N/A or Turbo engine. As yamarocket630 mentioned, retarding cam timing moves the power band up (resulting in more peak bhp but hurting the bottom end.) Advancing cam timing moves the powerband down, which results in more low end at the expense of the high end.
Since the SOHC ej25's powerband begins to drop off well before redline, a small amount of retard could probably increase performance without a need to increase the rev-limiter.
AllWheelDrift is offline   Reply With Quote
Old 09-13-2001, 12:40 PM   #5
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Are you sure about retarding adds more power?
By advancing the cam you are making all the ports open and close earlier in the cycle. In case you don't know, cams are usually timed such that the inlet port is open before the engine hits top dead center (TDC) and closes after bottom dead center (BDC). Yes, this is correct, the intake port actually closes after the pistons has begun its travel back up the cylinder. This causes the potential for some air/fuel mixture to be pushed back out of the cylinder, decreasing power.
By advancing timing you aleviate this somewhat by having the intake port closer earlier on the upstroke, lowering the potential for air/fuel to be expelled back out. More air/fuel = more power.
Also, the exhaust valve is timed to open shortly after combustion on the downstroke of the piston. This is done so that the piston does not have to push the gas out of the cylinder, this would reduce power. Instead the pressure of the gasses inside the cylinder are utilized to help the evacuate from the cylinder, which is why the exhaust port opens up well before BDC on the combustion stroke.
By advancing the timing of the exhaust valve you can potentially allow more gas out of the cylinder before the next upstroke, leaving less for the piston to push out and increasing power. Obviously you don't want to do it too early or you'll rob the cylinder of its gasses that are expanding to push the piston down too early.
Also, by closing the exhaust port earlier, you decrease the amount of exhaust gas that may be sucked back into the cylinder for the next cycle. This gas is high-temp and so would encourage detonation, and also ocupy volume that incoming air/fuel mixture could take up.
So advancing cam timing should provide performance gains assuming the manufacturer hasn't already pushed the envelope, which I don't think many have. I think that retarded cam timing helps emissions (possibly by "reburning" more exhaust??), which seems to be more important to most manufacturers than top performance.
Comments, questions, flames? I think I'm right in my reasoning here...
iodine23 is offline   Reply With Quote
Old 09-13-2001, 04:02 PM   #6
jeffg
Member#: 2958
2001 WRX (GC8)
Also, not sure if this is true or not, but doesnt the ECU take the timing measurement for the spark from the cam position? would this also move the spark in relation to piston position?
jeffg is offline   Reply With Quote
Old 09-13-2001, 04:21 PM   #7
ImprezedRS
Member#: 2771
2003 BMW Z4
I know Unorthodox racing is developing them now for our 2.5 lt engine.
http://www.unorthodoxracing.com/subaruts.html
ImprezedRS is offline   Reply With Quote
Old 09-13-2001, 04:31 PM   #8
jeffg
Member#: 2958
2001 WRX (GC8)
That has no information... just that they are making a subaru app. I bet it will be EJ20.
Old 09-13-2001, 04:31 PM   #9
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
I'm guessing that if the spark is cam triggered, it's probably done from a sensor on the cam gear itself. The adjustability would come from moving the camshaft in relation to that gear.
So the gear would be installed such that the spark even thappened at the correct time relative to piston position, and then you could adjust the camshaft to provide the advance/retard that you want.
I guess you could probably also use the adjustable cam gear to dial up ignition advance/retard if you wanted to. Just install the cam gear advanced or retarded from the crank gear, then dial in the camshaft adjustment to account for that too.
Of course all of this is if the spark is cam triggered. I seem to remember something about a crank trigger, but I could be thinking of a TEC-II.
Old 09-14-2001, 12:10 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
oook
still confused .. sounds like every one is...
i understand the theroy of opening intake valve early ...
but if you also opened the exasut valve early woun't that be bad ...
ok where are the experts?
Old 09-14-2001, 04:10 AM   #11
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Like I said, it actually helps to open the exhaust ports somewhat early. That way you use the pressure of the gas to let it expel itself from the ports rather than having the piston do the work of pushing it out. The piston is rising both from it's rotational energy, but also from another firing cylinder. So you'd be using some of that other cylinder's combustion energy to push gas out of the previous cylinder in the firing order rather than push the wheels faster.
At some point you'd advance too far and rob the current cylinder of its energy to drive the piston because you'd just be blowing the inital rapidly expanding gases out the exhaust rather than using them to drive the piston.
If you retard too far you end up blowing more of the air/fuel mixture out of the late-closing inlet valve, robbing the engine of power.
BTW, I'm getting a lot of my information from "Modern Engine Tuning" by A. Graham Bell. It is a very good book about the effects different tuning parts can have upon an engine. It is kind of dated, though... so some of the information may not be quite up to snuff.
Old 09-15-2001, 12:20 AM   #12
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
Sean I was unaware you were so informed. I can see where his logic is at.....I thought Alex said the gears were going to be available for the RS also
Andres
ATX25RS is offline   Reply With Quote
Old 09-15-2001, 05:01 PM   #13
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
I've been doing a little bit of reading lately.
I want to be sure that I know exactly what's going on before I go and get crazy tuning the car. For like $50 you can get Modern Engine Tuning and Maximum Boost from Amazon and learn a lot of stuff like this.
And then you don't have to rely on coming to the i-club and having people say "I thought it did this" or "I think it does that." It also lets you see through any of the smoke that some shadier vendors may try to blow your way. Though it seems like most of the subie people are good folks and aren't gonna jerk you around.
adjustable cam gears for the exhaust side of AVCS heads tino Built Motor Discussion 19 09-20-2009 07:14 AM
Adjustable cam gears for an EJ25 DOHC? pete wood Normally Aspirated Powertrain 4 09-20-2005 12:06 AM
Adjustable Cam Gears for GC8 Required David_Wallis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-07-2004 07:46 AM
AEM Adjustable Cam Gears For WRX Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 05-07-2002 07:55 AM
Adjustable cam gears for DOHC? Tangmere Normally Aspirated Powertrain 4 01-07-2002 10:52 AM
