Old 01-03-2006, 08:00 PM   #1
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
Default windows XP dual monitor question...
i'm usually the one to answer these questions, but now i'm asking one
in winxp (MCE if it matters to you) is there a way to have the task bar be on both monitors? ideally have the stuff that's on the left monitor on the left task bar and the same on the right, but i'll settle for having half the task bar on one, and the other half on the other.
how do i do it?
nomadtw is offline   Reply With Quote
Old 01-03-2006, 08:01 PM   #2
banman
Member#: 12408
2006 Legacy GT
I think you need third-party utilities to do that. I don't think WinXP will do that natively.
banman is offline   Reply With Quote
Old 01-03-2006, 08:03 PM   #3
Hazdaz
Member#: 14611
~SUBSCRIBE~
If you find a way, let me know. Been running dual-monitors for ages, but have always has the taskbar on only the main one.
Hazdaz is offline   Reply With Quote
Old 01-03-2006, 08:04 PM   #4
banman
Member#: 12408
2006 Legacy GT
Originally Posted by Hazdaz
~SUBSCRIBE~
How about this?
http://www.realtimesoft.com/ultramon/
If you often have multiple applications open at the same time, the Smart Taskbar will help you manage them efficiently, by adding additional taskbars for each secondary monitor.
You can choose between two modes:
Standard: each taskbar only shows applications from the monitor it is on, so you won't have to search for an application after activating it. If you move an application to a different monitor, its taskbar button will be moved to the corresponding taskbar
Mirror: each taskbar shows all tasks, allowing you to quickly switch tasks on any monitor
UltraMon does not replace the Windows taskbar, it simply adds one or more additional taskbars. For example, you can use the Windows taskbar on the primary monitor, and UltraMon taskbars on your secondary monitors.
EDIT - Another option:
http://www.mediachance.com/free/multimon.htm
Old 01-03-2006, 08:13 PM   #5
StuBeck
Member#: 19546
2009 Honda Fit
Yea, ultramon is what I used when I was running dual monitors
StuBeck is offline   Reply With Quote
Old 01-03-2006, 08:16 PM   #6
nimblegimbal
Member#: 91120
06 WRX ImpWag
Batmobile Black
Hrm... I got ultramon, but my taskbar on my secondary monitor is usually just a solid color, until something is opened on that monitor?
h4xorz on teh my pc?!? Or should i try multimon?
nimblegimbal is offline   Reply With Quote
Old 01-03-2006, 08:17 PM   #7
StuBeck
Member#: 19546
2009 Honda Fit
That's what its for, there might be an option to set it up to use both monitors. I haven't run it in a few years.
Old 01-03-2006, 08:19 PM   #8
happasaiyan
Member#: 37731
what kind of video card?
most driver control panels support it.
happasaiyan is offline   Reply With Quote
Old 01-03-2006, 08:29 PM   #9
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
well i could have sworn that the ATI control panel had a setting for it... but i can't find it anywhere, i haven't run dual monitors since the original radeon series
Old 01-03-2006, 08:54 PM   #10
Captain Choad
Member#: 66572
2010 Legacy
No, XP does not support that natively. You need something like ultramon to stretch it across. I've been running 3 monitors for years. Ultramon is the best out there if you want to save some time and just get the best.
Captain Choad is offline   Reply With Quote
Old 01-03-2006, 09:27 PM   #11
emorphien
Member#: 83039
2005 LegacyGT Ltd 5m
ಠ_ಠ
If you use more than one monitor you should be using Ultramon.
emorphien is offline   Reply With Quote
Old 01-03-2006, 09:47 PM   #12
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
wow this ultra mon thing rocks
i'm glad i asked OT
Old 01-03-2006, 09:56 PM   #13
happasaiyan
Member#: 37731
yeah, ATi doesnt have it. matrox and nvidia have it as an option. glad ultramon helped.
Old 01-03-2006, 09:58 PM   #14
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
i think they used to. like i said i haven't had dual monitors since before ati had the unified drivers
Old 01-03-2006, 09:58 PM   #15
emorphien
Member#: 83039
ಠ_ಠ
I still prefer Ultramon to nVidias approach since it gives so many nice features and good control over them.
Old 01-03-2006, 10:54 PM   #16
ShortThrow
Member#: 92607
Slightly OT, How do you guys run your set ups? I have one M and one F output on my comp. Do I have to buy a dual output plug for the one im currently using or can I buy or are there such things as M to F converters and would that work for me?
ShortThrow is offline   Reply With Quote
Old 01-03-2006, 11:45 PM   #17
ShortThrow
Member#: 92607
upup?
Old 01-04-2006, 01:11 AM   #18
ShortThrow
Member#: 92607
anyone?
Old 01-04-2006, 01:27 AM   #19
banman
Member#: 12408
2006 Legacy GT
I don't think I've ever seen a video card that has mixed-gender outputs for video. Are they both DVI? D-SUB? Or are they different types?
If they're the same type, I'd suspect that one is an input rather than an output.
Old 01-04-2006, 01:33 AM   #20
aod
Member#: 7121
I know that you have found a solution already, but I use multimon. It sets it up so the other task bar only shows what is open in that window, which is the way I prefer it actually. It also has a multi clipboard which is nice. One other thing that it does is it puts an extra button in the top-right corner of your windows that allows you to snap the window from one monitor to the other. Pretty nice feature set.
aod is offline   Reply With Quote
Old 01-04-2006, 01:38 AM   #21
ShortThrow
Member#: 92607
They are both D-sub but I cant tell if one if both or output or what. The symbols written next/above them are the same tho....
Anyone else have an idea?
Also are there any free programs for dual screen? lolz
Old 01-04-2006, 01:49 AM   #22
resident1155
Member#: 92659
2002 Impreza RS
ultramon is the only one with a usable task bar I think. I have the cracked version of course. Thats how we roll.
resident1155 is offline   Reply With Quote
Old 01-04-2006, 03:00 AM   #23
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
ati used to have this. It was a PITA though. It treated multiple monitors as one big monitor. The task bar went all the way across, but windows and system messages popped up spanning two monitors, and there was no way to easily maximize to just one monitor. Very poor implementation.
Midwayman is offline   Reply With Quote
Old 01-04-2006, 12:15 PM   #24
banman
Member#: 12408
2006 Legacy GT
I'd suggest getting a cable and trying it out . . . no harm done. Or find the manual for your video card.
Dual monitor question about Windows. ToddZ199 Off-Topic 15 01-16-2008 10:41 AM
Dual Monitor question before I buy another monitor.... volkl23 Off-Topic 8 01-25-2006 12:11 AM
Windows XP Gurus: Login Question nepawrx Off-Topic 11 01-25-2005 11:09 AM
Windows XP Pro Upgrade Question SteveKerr Off-Topic 4 03-08-2004 09:27 AM
Windows XP hard drive question StuBeck Off-Topic 4 07-23-2003 11:46 PM
