Old 09-12-2001, 04:01 PM   #1
myko011
Member#: 3500
Default How bad is it if my car is knocking?
The dealer claims my car was knocking but also claims that there should not have been any internal damage unless it has been driven like that for a long time. Is there any way to check to see if there was damage? like a compression test or something?
myko011 is offline   Reply With Quote
Old 09-12-2001, 04:03 PM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
leak down and compression test is a start yes...
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 09-12-2001, 04:27 PM   #3
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
Default WRX?
if it is a WRX, get it checked out ASAP. boost and rod knock do not mix very well...
ChrisW is offline   Reply With Quote
Old 09-12-2001, 05:38 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
myko011, tell the service technician that your car's been knocking at least since early May (to refresh your memory, see http://www.i-club.com/forums/showthr...threadid=39868). You probably shouldn't mention your "serveral stoplight races with launch" (see http://www.i-club.com/forums/showthr...563#post751563). Did you ditch the BOV before taking it into a dealer this time? What, ultimately, was the problem with your engine and how did they fix it?
Jon [in CT] is offline   Reply With Quote
Old 09-12-2001, 05:43 PM   #5
myko011
Member#: 3500
Is misfiring the same as knocking. Because what the tech and I confirmed as clicking noises coming from the engine at higher rpms was the knocking sound. However, the misfiring codes I have had fora long time and have not heard of any sounds coming from the engine whatsoever. The knocking noise is a recent thing, maybe 3 weeks. Before taking it to the final dealer, I ditched all modifications , but they knew about all of them, as they were still in the car, just not hooked up. The tech agreed that I was being pushed around by other dealers. The problem was that my EGT sensor went bad somehow. My precat melted, cuz the car was getting too hot, clogging up my exhaust gases. This high temp in my car also cause my engine to knock... as I guess it combusting from the temps instead of the spark. The tech was very good about diagnosing my car as I told him that you could really notice the difference at 6500 rpms. he asked if I have been up at this range before, and I said yes and 90% confident that it did not feel the same. I actually got to go help diagnose the car on the highway at the high rpms, as he hooked a comp to my car and a boost gauge to monitor everything and collect data. I await a new cat.
Old 09-12-2001, 10:38 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
myko011 wrote: "The problem was that my EGT sensor went bad somehow."
I think you're confusing cause and effect. The are only two problems a bad EGT sensor can cause: it can break off in the exhaust stream and damage the turbocharger's compressor impeller or it can turn on the MIL. A bad EGT sensor could never CAUSE excessively high EGT.
Old 09-12-2001, 11:25 PM   #7
en3d
Member#: 5238
GGA Black
does knocking trigger a CEL? how about misfires?
en3d is offline   Reply With Quote
Old 09-13-2001, 04:31 AM   #8
myko011
Member#: 3500
yeah.. I think I did mix it up, cuz that was the story one of the other dealerships gave me. The EGT sensor failed, hence my turbo did not get enough oil and coolant or someting, which is my why turbo was overheating.
how i can tell if my car is 'stage 2' or not? bugeye829 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 01-10-2010 12:22 AM
how bad does it hurt the car when you stall? 3gp Off-Topic 15 08-25-2006 12:15 AM
If my car is running rich, how many MPGs am I wasting? linux>windows Normally Aspirated Powertrain 6 11-17-2005 03:38 PM
How do I know if my shock is bad? lethargicman Brakes, Steering & Suspension 6 07-01-2003 02:49 AM
How Do U Know if Your Car is Running Lean? Xscreamer General Forum Archive 7 08-29-2000 09:45 PM
