Old 01-04-2006, 11:41 PM   #1
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Default Best way to switch fuels at an event
I don't have a dedicated trailer car, so my question is what's the best way to switch fuels. I'd like to run C16 next year but I would like to be able to drive on pump gas to the event and switch there to save $$$.
What is the best method to switch to race fuel?
I have thought of 2.
1. - Drain gas tank with bolts on bottom of tank on each side for draining into containers at the event (messy, cumbersome, etc..)
2. - Run the fuel pump to drain tank in some fashion (keep the amount in the tank low the so fuel pump doesn't have to do that much (may wear out fuel pump)
Well? Thanks in advance for any advice.
Justin
crystalhelix is offline   Reply With Quote
Old 01-04-2006, 11:43 PM   #2
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Take the fuel return hose and drop it in a gas can. Start car and run it till the car dies.
Your pump doesn't do any more then it does during normal idle.
-Tom
trhoppe is offline   Reply With Quote
Old 01-04-2006, 11:46 PM   #3
jvcastillo21
Member#: 14321
2002 GT35rrrrrrr
Imprezzzza
What if you have your pumps set @ 100% all of the time?
jvcastillo21 is offline   Reply With Quote
Old 01-04-2006, 11:54 PM   #4
chapstien
Member#: 68284
1988 Corolla SR5
0-points
Bring another larger pump that you can use to pump your gas out into a can, then prime with the new fuel. re-attach pump on car.
chapstien is offline   Reply With Quote
Old 01-05-2006, 12:01 AM   #5
DILLIGAF Racing
Member#: 29440
2015 WRX
I think they make hose's that drop down into a tank of a car that do just this. I remember looking at one at Gander MT. for some reason.
DILLIGAF Racing is offline   Reply With Quote
Old 01-05-2006, 12:21 AM   #6
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
-Tom
tom,
I never thought of using the return and running the car, awesome.
should make things easier because I would be able to do the same thing to make sure the fuel has reached the engine before switching maps.
DILLIGAF - I have tried to use a hose that goes into the gas tank, I ran into all kinds of problem trying to get it properly down into the filler neck.
Old 01-05-2006, 12:24 AM   #7
DILLIGAF Racing
Member#: 29440
2015 WRX
I don't know how this thing works or not. I will ask my dad. I think it pretty much works as a syphon, that you don't have start yourself.
Old 01-05-2006, 12:24 AM   #8
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
I would think tom's method would work still.
Old 01-05-2006, 12:25 AM   #9
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
Originally Posted by DILLIGAF Racing
I don't know how this thing works or not. I will ask my dad. I think it pretty much works as syphon, that you don't have start yourself.
tried one from advance auto, still couldn't get fuel back out of the filler neck...but let me know anyways although I think I will go with the return method.
J
Old 01-05-2006, 12:42 AM   #10
gregr01
Member#: 49333
04 STi
java pearl black
I don't have a map (UTEC) for C16, but I do have one for 100. I just time my fuel level so I arrive at the track with less than 2 gallons of 95 (a mix I normally run) in the tank, then add 5 or 10 gallons of 101.
Pumping out the existing fuel has never been an option I've considered. Too PITA, and it's easier to do the fuel level timing method. Then again I don't have a tune for C16--if I did I might investigate and use Tom's trick.
gregr01 is offline   Reply With Quote
Old 01-05-2006, 12:43 AM   #11
TIO-150 Vegas
Member#: 100873
manage your fuel prior to the event.
If it means getting a gallon at a time of pump gas during the few days before the event, then so be it.
Make it to the event on fumes. Then fill er up.
TIO-150 Vegas is offline   Reply With Quote
Old 01-05-2006, 12:52 AM   #12
DILLIGAF Racing
Member#: 29440
2015 WRX
wow, it sounds 10x easier to just tow the car to the event
Old 01-05-2006, 12:59 AM   #13
TIO-150 Vegas
Member#: 100873
its what I do and I never miss an AX event. I don't ever get a gallon at a time, I start managing about a week prior
Best Way to Drain Fuel Tank? beaviscih Texas Impreza Club Forum -- TXIC 13 09-03-2007 06:26 PM
Best way to check fuel trims w/UTEC on custom map.... Project Rex STi Engine Management & Tuning 4 07-12-2005 09:01 PM
The best way to test fuel pressure! jid2 Normally Aspirated with bolt-on Forced Induction Powertrain 2 12-04-2003 07:47 PM
best way to go fast on an exit ramp: IggDawg Off-Topic 25 12-04-2002 07:29 PM
Best way to replace fuel filter WRXVII Service & Maintenance 4 05-11-2002 06:35 PM
