Vancouver Impreza Club
Old 01-06-2006, 03:46 AM   #1
Fleek04
Member#: 56738
2014 Scion FRS
Asphalt
Default Rims are bent, but are tires ok?
Alright, so I bent my rim, (story is here
and afterwards, it's still drivable.
I went to get a claim form from the city, and got a estimate on the rim. Went to Greens Automotive, and said it cost around $250-$300 to fix the damage, and recommended me to get a new rim instead (new is $325).
So I think I might just get a new rim. But here's the question. If my rims are bent like that, would my tire still be ok? Or am I better getting it replaced as well?
What would you do? I don't know if the tire is still good or not. I didn't measure the PSI of it yet, and I don't know how the inner is.
Should I replace the tire or should I just use it?
Fleek04 is offline   Reply With Quote
Old 01-06-2006, 03:51 AM   #2
Predwolf
Member#: 54292
Do all 4 tires still have good tread?
If so, I'd make sure there are no cracks/slow leaks, and if not, use them
If it does have cracks though, swap it out.
Predwolf is offline   Reply With Quote
Old 01-06-2006, 04:03 AM   #3
Fleek04
Member#: 56738
2014 Scion FRS
Asphalt
Three of the four are brand new tire. However, 1 new tire has a huge metal piece stuck on, which explains why that tire was loosing air.
But normally, if the impact can damage the rim like that (there's pictures near the bottom of the page) should the tire be damaged too? Or is it possible that it may not be damaged at all?
Old 01-06-2006, 10:07 AM   #4
tora
Member#: 5851
09 Forester XT
+ NA Miata
Hard to tell tire damage with those pics. But I would wager that you should NOT keep the tire. If there is metal sticking in it AND the fact that your rim was bent the tire very well has internal damage. But you will find out when you take it off the rim (if it can be taken off without damaging it).
tora is offline   Reply With Quote
Old 01-06-2006, 02:23 PM   #5
tony_subaru
Member#: 22742
Bring it to a tire shop or two and get their opinion. They have the best knowledge there. Tires can withstand a lot. But then again, Tires are cheap for something that could save your life.
tony_subaru is offline   Reply With Quote
Old 01-06-2006, 03:56 PM   #6
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Good thing your tires are mostly new, because if they were worn down, you'd need to get a new set of 4 tires to keep the diffs happy, which might be tricky convincing the city to reimburse you for...
Necromancer is offline   Reply With Quote
Old 01-08-2006, 01:44 AM   #7
civilone
Member#: 92473
1997 WRX STI
If you have time, you can try this. Take out the tire with the metal on, and then put it in a big enough bucket of water. If there is bubbling, that means there is a leak.
civilone is offline   Reply With Quote
Old 01-08-2006, 01:51 AM   #8
feiron
Member#: 62327
2005 WRB STI
[S600BY]
or you can just get a new tire and shave it to match the other 3
feiron is offline   Reply With Quote
Old 01-08-2006, 02:05 AM   #9
lummer shawn
Member#: 71484
02 2.5 RS
BRP
even easier it to take a spray bottle and put water in it and spray it on, or take a rag with soapy water and rub the tire, either way, it way, it will bubble without having to find a bucket big enough for the whole tire
lummer shawn is offline   Reply With Quote
Old 01-08-2006, 12:33 PM   #10
EJ20(GDB)
Member#: 85507
1995 WRX STI
how is the driving's feels like when you notice your rim bent?
EJ20(GDB) is offline   Reply With Quote
Old 01-09-2006, 02:03 AM   #11
Fleek04
Member#: 56738
2014 Scion FRS
Asphalt
I guess I will head to a tire shop to get their advice.
There was no difference at all.
Old 01-17-2006, 08:52 PM   #12
turbowrx82000
Member#: 50049
No:( 05WRX Wagon RIP
02 Bugeye :..( FXT :..(
interested in selling two bent rims?.....my insurance company wont help me (was in a bad accident) and had aftermarket rims on....i dont care how bad of shape there in as long as they hold air, please im me if you want to get rid of your destroyed rims, do they have run down tires as well?
turbowrx82000 is offline   Reply With Quote
Are stretched tires ok? Pssshhhhh! Tire & Wheel 3 10-12-2008 03:30 AM
Ok..stupid question, but are the STIs spraying washer fluid on their Intercooler? magillaTheGorilla Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 04-20-2004 12:26 PM
Tire looking flat but pressure is OK? BatWrx Tire & Wheel 12 04-26-2003 01:05 PM
17x7 silver UK WRX rims w/Potenza S03's w/2k miles on them, one rim slightly bent annointed Tri-State Area Forum 4 01-26-2003 11:50 PM
Is it ok if the intercooler fins are bent or damaged? minisiu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-21-2002 03:44 AM
