Old 01-06-2006, 03:43 PM   #1
mrtrex
Member#: 12223
2005 WRX
Default Will 06 WRX Front and Rear Calipers fit on my 05 WRX?
Is this a direct bolt on? If not what else needs done?
mrtrex is offline   Reply With Quote
Old 01-06-2006, 08:31 PM   #2
BIGSKYWRX
Member#: 7958
09 GH B+
front golts right up, the rears require a new backing plate- the catch is the rear backing plates are pressed in- requiring new ones pressed in- a fair amount of labor- knuckle needs removed/reinstalled, new wheel bearings/seals, e-brake bits need removed/reinstalled, etc
you can save a lot of the labor costs by removing the knuckles and having the dealership press the backing plates in, you could save more $ if your comfortable swapping wheel bearings
Old 01-06-2006, 09:04 PM   #3
mrtrex
Member#: 12223
2005 WRX
Sounds like a pain. I might just go with the Rotora bbk for the front and rear.
Will a 2008 STi Tmic fit on MY 05 WRX 2.5 Hybrid?? enjoiwrx Subaru Conversions 0 05-04-2010 11:33 AM
installing front and rear door speakers on my 05 WRX g_$ Car Audio, Video & Security 7 04-23-2009 12:29 PM
Feeler: 06 STi Front and Rear Calipers/Rotors k3nj11 Suspension/Brakes/Handling 16 11-25-2008 05:09 PM
Will 06 sti front and rear struts fit on 04wrx?? altezza2impreza Brakes, Steering & Suspension 4 05-27-2006 02:08 AM
What is the size of the front and rear sway bar on a 05 wrx, and should I up grade? mrtrex Brakes, Steering & Suspension 4 08-14-2005 11:24 PM
