Old 01-06-2006, 04:19 PM   #1
truwrxtacy
Member#: 84786
2011 STi
Default 2.5 swap
i've tried the search button but i am still confused. i have 2.0 wrx right now and if i wanted to swap it to a 2.5 and i would have to swap the wrx engine for a sti engine? becasue the sti engine is 2.5. or is it swapping somthing smaller to get the 2.5? because the sti engin runs about 4000. Can you run the 5sp on the sti engine? i know its not benefical but i just wanted to know. thx
truwrxtacy is offline   Reply With Quote
Old 01-06-2006, 04:52 PM   #2
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
perhaps.
swapstar is offline   Reply With Quote
Old 01-07-2006, 04:07 AM   #3
wswhatever
Member#: 102629
I believe quite a bit of people still running 5spds with even the sti engine. Though it's not the best setup, it can still hold a while if you don't abuse it
wswhatever is offline   Reply With Quote
Old 01-14-2006, 02:14 AM   #4
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Default 2.5
u know i searched around and talked to some people that had the s/b swap and this is what ive learned in the past couple months...
the swap is possible and u can use your 2.0 ltr heads on the sti block. if you have an upgraded turbo/injectors/fuel pump you'll see the 2.5's power and much more GEAR BREAKING TORQUE down low. if u have stock stuff then you'll proly see a bit more in the torque dept and some hp. the wrx clutch and fly are used b/c you'd still be running the 5spd tranny.
keep looking around for more info too... their are many who've done this swap and have more knowledge on it than i am.
i plan on doing the 2.5 ltr swap soon myself btw
oh ya, and u can use a legacy 2.5ltr block too, not just sti... but i would sti
-dave
All4bSpinnin is offline   Reply With Quote
Old 01-15-2006, 02:27 AM   #5
joeyd02
Member#: 16742
07 STI UGM
AP Stage2 Clark Tuned
I did a 2.5l STi sblock into mine using the WRX heads, tranny, and clutch
joeyd02 is offline   Reply With Quote
Old 05-29-2006, 01:50 AM   #6
STL WRX
Member#: 88304
05 VF34 Aspen WRX
First let me say sorry for digging up an old thread but can you give us an update on how your setup is holding up?
STL WRX is offline   Reply With Quote
Non-STI 2.5 swap vs. 2.0 swap? anon_az Subaru Conversions 6 03-20-2010 12:33 PM
bit confused on 2.2 to 2.5 swap Mk3Design Subaru Conversions 7 03-04-2007 11:51 AM
2.2 or 2.5 swap cindergarden Normally Aspirated Powertrain 3 09-25-2002 04:12 PM
2.2 - 2.5 swap 97 impreza wagon MC Racing Normally Aspirated Powertrain 7 04-24-2002 06:55 PM
97 impreza l wagon 2.2- 2.5 swap clutch questions MC Racing Transmission (AT/MT) & Driveline 1 04-24-2002 01:47 PM
