Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 01-06-2006, 04:33 PM   #1
makofoto
Member#: 25243
2006 Legacy Outback
Default Rear Dif Out? How to Tell?
I was going to finally pick up my WRX after Steve @ Suby Specialties rebuilt my 5 spd and pulled my SM mods so I could run STX.
When he test drove it, the front inside wheel spun very easily, now that I don't have a front LSD. But he said it spun way to easily ... as if my oem rear LSD was gone. It's like I now have a 290 hp FWD car.
I believe him. It's not like the busiest Suby Mechanic around is trying to drum up more business. I bring him a lot of new business and he gives me discounts.
But HOW does one know the rear dif is gone?
Since we are allowed to have a rear LSD in STX ... can one replace it with a mechanical LSD or must one stay with the oem viscious coupling version?
makofoto is offline   Reply With Quote
Old 01-06-2006, 04:44 PM   #2
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Couldn't the problem also be the center diff?
Sorry, I have no potential solutions. Well, except in my STi when you try to exit too hard or too quickly the rear end makes all kind of racket. I assume this is the rear diff and wheel hop due to the inside wheel being unloaded.
javid is offline   Reply With Quote
Old 01-06-2006, 04:50 PM   #3
tacomaprime
Member#: 70572
2005 Tacoma
put the car up on a lift, turn it on, press slightly on gas, see if rear wheels spin?
tacomaprime is offline   Reply With Quote
Old 01-06-2006, 04:51 PM   #4
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
How does the inside front wheel spin relate to a broken rear diff?
afpdl is offline   Reply With Quote
Old 01-06-2006, 05:21 PM   #5
javid
Member#: 54304
04 STi
TopSpeed-dAng!
with an open center if your rear diff is completely shot (no shaft torque gets to either axles) then all power goes to the front, aka twice as much as normal and so it would be twice as easy to spin the inside front....
Old 01-06-2006, 05:27 PM   #6
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Maybe use some e-brake action during this test too? You can adjust the pressure of the shoes on the right and left differently, which may explain a little more.
Old 01-06-2006, 06:43 PM   #7
skuttledude
Member#: 738
2008 Lexus IS-F
Ducati Monster 800
rev to 6,000rpm's, drop clutch, see which tires spin
seriously, I like the put the car on lift idea
skuttledude is offline   Reply With Quote
Old 01-06-2006, 09:25 PM   #8
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
AWD cars have to use the factory diffs in Street Touring unless they came from the factory with NO LSDs (including the center diff) then they can add one. So, sorry...factory viscous only for the WRX.
Shane
Warp3 is offline   Reply With Quote
Old 01-06-2006, 09:32 PM   #9
cowapult
Member#: 25324
2016 WRX
Dark Gray Metallic
a) I don't see how this could have anything to do with the viscous rear coupling. He must have said (or meant) center diff. If anything, a shot rear vicous would do the opposite of what you're describing. Javid does point out one way that a rear diff would cause this problem, if it had completely grenaded and lost all its teeth, but I think you would notice if your rear diff had detonated that bad.
b) A blown viscous center diff would cause these symptoms, but it's not nearly as bad as having a FWD car. With an open diff, you will still get exactly 50% of the torque to the rear. You'll tend to spin the front a bit sooner than the back because they have less weight on them. That is, unless "bad diff" means you're actually missing teeth in the center. That's a whole different story.
c) I think Javid pointed out the only way to test it. Put the car on a lift, put it in first and let it idle. See if all the wheels turn. If all 4 spin, then none of your diffs grenaded. If just the front spins, then something is completely busted and disconnected in your rear diff or drive shaft
Assuming all 4 spin, then get the engine going faster and apply the e-brake. Your rear wheels should obviously slow down. Listen if the engine slows at all, watch if the front wheels slow at all. If the engine keeps going the same speed and front wheels speed up - that means your center diff is working but it's open, not viscous. By contrast, if the front wheels and the engine slow, then your center diff is doing its viscous job and all this fuss is just you noticing that you took out your front LSD.
cowapult is offline   Reply With Quote
Old 01-07-2006, 01:17 AM   #10
makofoto
Member#: 25243
2006 Legacy Outback
I haven't had a chance to drive or see the car myself, and won't be able to until next week now. Steve is a MASTER Suby Mechanic with his own garage ... that gets rave reviews.
The Center Dif is BRAND new. The "old" one was blown open when I stripped 2nd gear.
The Center Dif and Rear Dif are viscous coupling ... no teeth.
Found a brand new oem rear dif for $200.
Old 01-07-2006, 03:21 PM   #11
cowapult
Member#: 25324
2016 WRX
Dark Gray Metallic
Oh, they have teeth alright
Old 01-07-2006, 05:34 PM   #12
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
I believe cowapult is talking about ring and pinion teeth.
-Wes
RebelINS is offline   Reply With Quote
Old 01-09-2006, 10:08 AM   #13
ratt_finkel
Member#: 46218
06 EVO 9
IWhen he test drove it, the front inside wheel spun very easily, now that I don't have a front LSD. But he said it spun way to easily ... as if my oem rear LSD was gone. It's like I now have a 290 hp FWD car.
How do you think us Evo owners feel?
ratt_finkel is offline   Reply With Quote
Old 01-09-2006, 10:32 AM   #14
leecea
Member#: 37359
2003 WRX
You probably have a big front sway bar - I think that will help make the inside front spin.
leecea is offline   Reply With Quote
Old 01-09-2006, 10:39 AM   #15
ratt_finkel
Member#: 46218
06 EVO 9
Indeed it will. Something I noticed after slapping the FSB on my Suby.
Old 01-09-2006, 12:29 PM   #16
makofoto
Member#: 25243
2006 Legacy Outback
Doesn't have a big front sway bar, only a Hotchkis hollow = 22 mm
Old 01-09-2006, 02:08 PM   #17
solo-x
Member#: 37624
jack up the rear of the car. put the tranny in gear, then while someone holds one wheel, try to turn the other. there will be nearly no resistance at all if the diff is "blown".
to blow up a viscous diff it would take a LOT of work.
fyi, there is a lot of misunderstanding/misinformation of how diffs work being tossed around in here. i'd try to help straighten it out, but it's such a mess already it would be difficult to clarify everything without a page long post. i'm pretty confident that the rear diff in mako's car is fine. i'd be looking at center diff possibly. if the rear diff was blown, the inside rear would spin to high heaven. you KNOW it was blown. saying the rear diff is blown and causing massive inside front wheelspin is suspect.
nate
solo-x is offline   Reply With Quote
Old 01-11-2006, 10:40 PM   #18
makofoto
Member#: 25243
2006 Legacy Outback
You're correct ... mine is OK.
There are three tests according to Subaru:
If the fluid is really burnt ... it should vent through a "blow" hole at the top of the differential.
Second, with the rear wheels off of the ground turn one wheel by hand while holding the other one stationary. It will turn fairly easy at first, but after a couple of seconds it should noticeable stiffen. Apparently it takes a couple of moments for the fluid to start being forced through some apertures.
Third, with the drive shaft locked in position, turning one rear wheel should make the other wheel turn in the same direction if the rear LSD is OK. If the rear LSD is really out, the other wheel will either not turn or turn in the other direction. I think I got that right.
Old 01-11-2006, 11:25 PM   #19
kcscoob
Member#: 31222
2005 Legacy GT wagon
6 speed, BNR 18G, E85
Default Axle shaft?
This is likely not the issue but I had an axle shaft come out of the rear end of my WRX and my car acted like it was a front wheel drive for a while and then it would barely go at all because of all the slippage.It was a while before it was diagnosed because the shaft was only out about 3/8 of an inch and everything looked normal from first glance. The center diff needs resistance from both the front and rear diffs to work. You might check to see if both shafts are completely in before you tear things apart.
kcscoob is offline   Reply With Quote
Old 01-12-2006, 12:17 AM   #20
Student Driver
Member#: 65161
2002 2.5RS, AW
I can taste teh suck
Honestly, it seems like there's a longer delay between front wheel spin and rear diff lock than I would think. Ever since I went Cobb Stg 1, I would get a little front spin during certain turns on my way to work (if I felt a little punchy anyway ). Now, at Stg 2 with a 22mm front bar, I can get that front inside wheel to light up briefly (less than half a second I think) and then "wooshhhh" when the rear hooks up. On the RS, both the inside wheels would just spin in similar situations (albeit a little wet so it could actually turn the wheels).
Student Driver is offline   Reply With Quote
how to tell if i have rear lsd yeos Transmission (AT/MT) & Driveline 4 02-23-2009 02:25 AM
R180 rear diff: How to tell if its plated Ben v5 Transmission (AT/MT) & Driveline 2 05-04-2008 06:44 AM
How to tell size of rear sway bar Tom MY03 Brakes, Steering & Suspension 4 05-11-2005 06:52 PM
How to tell Stock Front Springs from Rears? MY99 2.5GT Brakes, Steering & Suspension 7 04-19-2002 08:54 AM
How to tell how much brakes left? Penphoe Brakes, Steering & Suspension 3 06-19-2001 02:08 AM
