Old 01-07-2006, 02:20 AM   #1
chaddeus
Member#: 56624
2004 Subaru WRX STi
Default EcuTek Dash Display
http://www.ecutek.com/products/dashdisplay/
With this, does this means we can almost eliminate the gauges and a seperate EM?
Because if I would to get an AccessPORT, it will cost me like $600 unless someone is kind enough to sell their unmarried for cheap. Then if I get gauges, it will cost me an additional $200-300, making a total of $1000.
However, someone at IWSTi forum posted that he made someting like that for $742 and can measure a lootttt of stuffs.
What do you guys think?
- Charles
chaddeus is offline   Reply With Quote
Old 01-07-2006, 03:05 AM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Yeah, but that think is like $700 all by itself. Harder to read at a glance than gauges, and more expensive.
mcowger is offline   Reply With Quote
Old 01-07-2006, 08:48 AM   #3
jim1969
Member#: 34877
2005 Legacy GT sedan
doesn't read EGT unless from ECU (which your's won't). Also, the ECU only reads to 18.3 psi for boost.
jim1969 is offline   Reply With Quote
Old 01-07-2006, 08:52 AM   #4
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
I have the PSi3 unit which is basically what this is. I love it.
But you need to buy the sensors for the egt,oil pressure.
Got it used for 300.
enewtabie is offline   Reply With Quote
Old 01-07-2006, 09:45 AM   #5
jim1969
Member#: 34877
You cannot hook up an external EGT probe at this time. Only oil pressure, oil temp and Boost. EcuTeK is looking intom making an external EGT sensor available this year.
Old 01-07-2006, 09:53 AM   #6
LastResort
Member#: 99289
That will not provide any engine management, it just does Display. If you have an EcuTek flashed ECU it will do the map switch, rather than the gas pedal/defroster button.
LastResort is offline   Reply With Quote
Old 01-07-2006, 10:05 AM   #7
jim1969
Member#: 34877
Most of the newer ECUs won't support map switching from either of the above methods.
Old 01-07-2006, 10:17 AM   #8
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
For the Ecutek,not for the PSi3 unit.
Mine is switchable on egt from ecu to external.
Old 01-07-2006, 10:32 AM   #9
mantra1
Member#: 23568
'08 Forester STi
Shaggin' Wagon Thrice
Map switching available only for 02-03 models. I love mine . Being able to adjust boost, timing, WGDCyles, etc through the user tuning mode and map switching is awesome, especially when running race gas. Not to mention h20 inj control, shift light setup etc.
mantra1 is offline   Reply With Quote
WTB: Ecutek Dash Display and Delta Dash disk singincanary Private 'Wanted' Classifieds 0 08-31-2007 02:03 PM
EcuTek Dash Display Monitor - IN STOCK!! Subaru Gwinnett Interior/Dressup/Audio & Security 0 02-26-2005 09:52 AM
Ecutek dash display with sensors RR-racing Private 'For Sale' Classifieds 1 12-15-2004 11:59 PM
EcuTek Dash Display robbswrx Engine Management & Tuning 5 07-13-2004 12:19 AM
