Old 01-07-2006, 11:57 AM   #1
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Default AP on swapped car
Heres the deal. I've got a 01 RS w/ 04wrx engine+ecu. Everything works perfectly, OBDII port works perfect, test mode connectors when connected send the car into its crazy cylcling stage.. Anyways.. I have an AP for an 04wrx, but can't for the life of me find or really remember if we wired in the "other" connector, the semi-clear one that you use with the supplied cobb jumper.
If its not there, how big an issue is it? I can't seem to find any info to tell me what the hell its supposed to do.
Also, if i were to use a friends 04 wrx, with my ecu in it, and marry the AP to it using a donor car for the wiring, would that work? Any help or insight is appreciated.
subbyspeed is offline   Reply With Quote
Old 01-08-2006, 04:16 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
extreamly important
that has to be jumped in order for marring the ecu to the ap or flashing base maps
Old 01-08-2006, 04:18 PM   #3
hondaeater69
Member#: 60324
cobb can get you one for a small fee, and like he said, you def need it. I don't understand your other question about your friends wrx and blah blah blah.
hondaeater69 is online now   Reply With Quote
Old 01-08-2006, 10:40 PM   #4
ivrep
Member#: 53237
2006 sleeper wagon
black
Ooooo... This sounds like black magic but I think I know what you are tring to do.
All I know for sure is if you do attempt the ECU switcharoo and it works...now pay close attention...
If it works then every time you want to switch base maps you will need to use the donor car.
The AP mates itself to your ECU forever untill you unmarry it. Man Good luck with this!
If it does'nt work you will most likely have to send your ecu to Cobb because it will be dead.
ivrep
ivrep is offline   Reply With Quote
Old 01-09-2006, 08:23 AM   #5
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
^^^ yeah, thats what i thought.. I only thought of that as an alternative.
I'll have to look through the old harness and see if its still laying in there..
AP on new car? DAC17 AccessPort 30 09-26-2009 05:13 PM
a/c question on swapped car wildacex187 Newbies & FAQs 5 08-08-2009 12:18 AM
Emissions on swapped cars wrxlover87 General Community 7 05-14-2009 10:19 PM
Would an AP married to one car work on another car that has another AP married to it? zuczek AccessPort 13 10-24-2006 02:06 AM
Has anyone used AP on RS with swap???? greenemac2003 Subaru Conversions 5 07-24-2005 03:32 PM
