Old 01-07-2006, 12:50 PM   #1
ChristopherG
Member#: 66086
2008 STi
Default 04+ Open/Closed Loop Problem
Hey guys, I've been researching the open/closed loop problem regarding the 04+ WRX's. I've been running a catless exhaust for about 2 months now without any engine management. According to my EGT gauge, I'm not seeing anything over 1600 degrees. From what I understand, even though I don't see full boost often, I should get some form of engine management to eliminate the open/closed loop problem.
My question is simple, but I couldn't find exactly what I was looking for when I searched. What engine management will help eliminate the delay in the open/closed loop transition on the 04+ WRX's? Will an off-the-shelf Stage II Accessport do the trick, or will I need to get something more custom, like an ECUtek tune?
Thanks, and sorry if the answer is right in front of my face.
Chris
ChristopherG is offline   Reply With Quote
Old 01-07-2006, 12:58 PM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
AP takes care of it. Stage 1 and up.
I'm pretty sure the other EM's do as well, ecutek,utec, etc.
subbyspeed is offline   Reply With Quote
Old 01-07-2006, 02:20 PM   #3
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Pretty much any. UTEC, AP, EcuTek will all do it.
mcowger is offline   Reply With Quote
Old 01-07-2006, 02:46 PM   #4
Spiider
Member#: 13680
With the tactrix cable and openecu.org you can fix it yourself for free.
Spiider is offline   Reply With Quote
Old 01-07-2006, 02:49 PM   #5
ChristopherG
Member#: 66086
2008 STi
Thanks for the concise input guys.
Old 01-07-2006, 08:03 PM   #6
iiiezekieliii
Member#: 101624
2011 F-150 5.0L
i went this route.... w00t
iiiezekieliii is offline   Reply With Quote
Old 01-07-2006, 08:50 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....nothing for the '06's yet, though
Old 01-07-2006, 08:57 PM   #8
JRSCCivic98
Member#: 67080
I believe EcuTek flashes are available for 06 WRXs and STIs.
JRSCCivic98 is offline   Reply With Quote
Old 01-07-2006, 09:53 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
....and AP....but nothing like a cable a progie and a laptop
Old 01-08-2006, 03:07 PM   #10
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
I hope to take care of that soon. Does the '06 have the same problem anyway? It's a completely different code base...
Colby
colby is offline   Reply With Quote
Old 01-08-2006, 04:36 PM   #11
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Yes, because due to regulations they are still required to put such a delay in there for emissions reasons.
Old 01-08-2006, 07:28 PM   #12
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Colby
Yes- there is a delay in the 06 wrx- Is the ECU the same on that is used for the 04/05 STi?
If so, i would assume the CL/OL logic is the same as the STi, but with different parameters.
It should be easy enough to remove.
Mike
crazymikie is offline   Reply With Quote
Old 01-10-2006, 06:42 PM   #13
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
I don't have a '06 in my hands right now, but it is basically the same. It is a 1MB flash SH7058 processor. I have a couple of '06 STi/WRX ROMs already..., but I'd like to get an ECU for the bench too... Let me know if you want to poke around and try to find the OL/CL params...
Colby
Old 01-10-2006, 06:58 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
...damn.....I would SO like to NOT have to buy AP for my '06.....
Problem with open/closed loop Cyberguy Engine Management & Tuning 13 06-06-2009 01:40 PM
Can anyone explain the 04-05 closed loop/open loop lean cond.? boxxxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-11-2005 09:00 PM
04 WRX open loop/closed loop problem -- should I be concerned? perret318 Newbies & FAQs 2 05-03-2005 05:38 PM
2004 open/closed loop question nate49509 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-24-2004 05:35 PM
at wat RPM does MAP cars switch open/closed loop? wistful Normally Aspirated Powertrain 4 10-14-2001 03:06 PM
