Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 01-07-2006, 03:36 PM   #1
romanelli
Member#: 102247
02 WRX
Default ABC and utec
I just a quick and easy question for everyone. I'm planning on running the stage one map on the turbo xs website and was wondering what to do with the srew on top of the ABC valve head. The directions from turbo xs don't seem to say anything about it. I imagen this srew has to do with adjusting the amount of pressure. Well thanks for the help. Also I should not that this is a used utec and therefore I need to know where the srew should be at for a stage one set up. Thanks again.
romanelli is offline   Reply With Quote
Old 01-07-2006, 05:25 PM   #2
Gethin
Member#: 2998
read the UTEC manual. It's explained in there.
http://www.turboxs.com/downloads/UTE...nual%205.0.doc
It's a bleed screw, use it to reach your proper boost targets if your boost map does not reach there.
Gethin is offline   Reply With Quote
Old 01-08-2006, 02:41 AM   #3
hpracingwrx
Gone... But not forgotten
Member#: 16772
2003 R6
i miss my rex....
the abc is just that, an auxiliary boost controller, u will use the boost maps in your utec for the initial tuning your boost curve, then u will adjust the abc to make ur boost peak where you would like it to.
example:: u set ur boost curve how u would like it, and u do a demo run, u come to find out that ur running 1 psi too much boost, so instead of changing the whole map in the utec, simply adjust the abc about half a turn closed
iirc: clockwise closes meaning less boost
counter-clockwise opens which means more boost
hpracingwrx is offline   Reply With Quote
Old 03-07-2006, 06:13 PM   #4
TheMainFrame
Member#: 104251
2002 Impreza WRX
Pearl Silver Metallic
OK so would the stage 1 map be capable of boosting the 16 psi mentioned in the manual by just tuning the ABC?
TheMainFrame is offline   Reply With Quote
Old 03-07-2006, 09:30 PM   #5
hpracingwrx
Member#: 16772
2003 R6
i miss my rex....
u do not "tune" your abc, u tune ur UTEC, the abc is there for fine adjustment
the UTEC is the primary boost control, the abc is just what it stands for the auxilary boost controller.
use ur UTEC to tune to roughly 16psi, then use the abc for fine adjustment.
i.e. you are boosting 15, use the abc to bump it up 1psi. do not use it as a manual boost controller
Old 03-09-2006, 12:34 PM   #6
shift_rex
Member#: 69434
2002 Impreza WRX
Also, if you've ever run a MBC, it's possible that your SBS has gone bad, so the ABC acts as a way to crank up and turn down your boost, your UTEC allows you to adapt your fuel maps and such to adjust accordingly.
shift_rex is offline   Reply With Quote
FS VA: TurboXS UTEC from 02 WRX w/ ABC and Remote Map Selector poorboy760 Engine/Power/Exhaust 2 03-26-2008 11:59 PM
FS VA: TurboXS UTEC from 02 WRX w/ ABC and Remote Map Selector poorboy760 MAIC Private Classifieds 4 03-26-2008 11:59 PM
Ditching the UTEC ABC and going back to MBC waveoff Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-29-2004 04:12 PM
Spoolup UTEC w/FBC/ABC vs UTEC/MBC? paulw Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-13-2003 11:10 AM
abc with utec HonduhEater Engine Management & Tuning 6 09-29-2002 01:49 PM
