Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 01-07-2006, 04:11 PM   #1
Member#: 42177
2005 STi
Default FMIC untuned on StreetTuner stage 2?
I have an 05 STi with a FMIC, short ram, turboback, and a tweaked stage 2 street tuner map. The map was tuned on a KN typhoon and turboback, with advanced timing and 11.1 AFR at WOT, tapering down to about 10.5 at redline.
I am running that map right now after I just installed the FMIC. My question is how safe is it to run untuned? I plan on getting a gt35R and supporting mods late spring/summer and getting it Protuned. Should I go to a more conservative map (ie. richer) since the FMIC leans out the car? i dont go flooring it around town but it would be nice to hit some spirited runs.
Im split because some threads say dont go into boost until you get tuned and others show people running FMICs on the stock ecu, no AP.
BrandonWRX is offline   Reply With Quote
Old 01-07-2006, 06:15 PM   #2
Member#: 96668
2006 WRX TR
id say it might make it richer than leaner...since the cooler air
06WRXTR is offline   Reply With Quote
Old 01-07-2006, 06:16 PM   #3
Member#: 50596
04 wrx breakin
necks in JBP sucka!
Id say don't do that dumb stuff and get it tuned!
MPREZD is offline   Reply With Quote
Old 01-07-2006, 09:31 PM   #4
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
You will be running safer now because your motor is seeing less boost. After I installed my FMIC, I lost about 2psi because of the length of the pipes. We adjusted the WGDC on the StreetTUNER program and solved that problem. Check your boost gauge and see what it's doing.
bigmike25rs is offline   Reply With Quote
Old 01-08-2006, 12:24 AM   #5
Member#: 33296
can you explain how a fmic makes the car lean?
WrXwaBBit is offline   Reply With Quote
Is there a thread on Cobb Stage 2 vs. Prodrive Stage 3 Power Pack? casualsurfer Newbies & FAQs 4 05-03-2004 05:06 PM
12's on cobb stage 2 ? cre Proven Power Bragging 4 10-15-2003 10:15 AM
best deal on stoptech stage 2 wrxlay Brakes, Steering & Suspension 4 09-05-2003 02:30 PM
Wanted: Lowest offer on TurboXS stage 2 Kit Stang2WRX Private 'Wanted' Classifieds 1 08-13-2003 10:27 AM
UTEC on otherwise stage 2 HonduhEater Engine Management & Tuning 3 11-12-2002 11:18 AM
