Old 01-08-2006, 12:46 PM   #1
Sti-lysh
Member#: 72573
2005 Suby STi
Default Trunk Swap Instructions
Does anyone one know if there are instruction out for trunk swaps? If so could someone post a link. Thanks
Sti-lysh is offline   Reply With Quote
Old 01-08-2006, 01:57 PM   #2
4wdrift
Member#: 1403
99 RBP GC8 Impreza
C'mon....
Did you look at the trunk?
Open it,
unplug the third brake light (if you have one in a wing),
take the four bolts out,
and remove the trunk.
If you don't have the mechanical aptitude for a trunk swap, should let someone else do all of the work on your car. I mean ALL!
4wdrift is offline   Reply With Quote
Old 01-08-2006, 05:54 PM   #3
Sti-lysh
Member#: 72573
2005 Suby STi
FYI, i am mechanically inclined. I heard people having problems with the torsion spring removal. But I guess during your smart ass comment you missed that part in your instructions. So next time if you dont have a helpful comment dont leave on at all.
Old 01-08-2006, 06:00 PM   #4
supermarkus
Member#: 6971
2008 WRX STi
SSM
Really, you didn't mention anything about the torsion bar swap, he was just thinking a trunk swap. The whole process is very simple, you should be able to do the ENTIRE swap without explicit instructions.
That being said, make sure you note the orientation and differences between the two torsion springs. They come out pretty easy with a long flat head screwdriver and some channel locks. And dont get all butthurt from the intarweb, save that for when the torsion spring pinches your fingers.
Oh and make sure you support the spring carefully so it doesn't pop out suddenly and break your trunk light.
supermarkus is offline   Reply With Quote
Old 01-09-2006, 12:44 AM   #5
njskatchmo
Member#: 94618
2002 Bugeye
It's fairly easy. the brake light unplugs.
You need 2-3 people.
The trunk comes off with 4 bolts. Have the other two people hold teh corners.
Lay the trunk on something soft.
The trunk support bars have the torsion bars connected to pivoting holding devices.
What you need to do is getin the trunk on your back and pull the torsion bar down and collapse teh folding device. You'll understand when you see it. Then the bar just slides left or right out of it's holding place. Make sure to note which one is left and which one is right. Other than that, there's nothign else.
njskatchmo is offline   Reply With Quote
Old 01-09-2006, 01:12 AM   #6
rally_on
Member#: 86849
2005 GMC Savana
white
if you put the torsion bars on backwards would it hold the trunk shut?
rally_on is offline   Reply With Quote
Old 01-09-2006, 01:24 AM   #7
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
18L Java Black Pearl
^^^^^ LOL....
from reading the instructions for the torsion bars, removal and reinstallation is pretty straight forward....
try not to be so thin-skinned......
couchflambeau is offline   Reply With Quote
Old 01-09-2006, 04:50 AM   #8
supermarkus
Member#: 6971
2008 WRX STi
SSM
I did a trunk swap by myself in the pouring rain I was caught in a sudden downpour. I highly advise against doing this by yourself, but it can be done.
Old 01-09-2006, 04:55 AM   #9
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
on my gc car its 4 bolts, no torsion bars or anything to unhook.
svek is offline   Reply With Quote
Old 01-09-2006, 04:59 AM   #10
BlackoutWRX
Member#: 74589
2000 94 Infiniti G20
90 S13 Coupe
the torsion bars are tricky. that all i remember from my trunk swap
BlackoutWRX is offline   Reply With Quote
Old 01-09-2006, 05:19 AM   #11
svek
Member#: 82259
1999 impreza 2.2L
Old 01-09-2006, 08:21 AM   #12
njskatchmo
Member#: 94618
2002 Bugeye
The torsion bars are logical if you look at them. if you put the wrong one on each side they wont latch on cause of the mway the L in the metal is shaped.
Old 01-09-2006, 10:00 AM   #13
ninethreeeleven
Member#: 99777
Swaping the key cylinders is also easy. I did this two weeks ago with Ghost Rider (member here).
To swap key cylinders you have to take out the 5 "fake" screws holding in the emergency trunk release. That is simple. It attaches to the trunk lever with a sort of bicycle brake line, you'll know what I am talking about when you see it. Then you have to reach into the inside of the trunk lid (should bring a flashlight) and there is a pole that goes from the trunk latch to the key cylinder. This pops right off, but only in one direction you have to see it to understand.
Then there is a C-Clip holding on the key cylinder. This is removed by pulling on it, although it might be a bit stuck it will come off.
Assembly is much the same.
ninethreeeleven is offline   Reply With Quote
Old 01-09-2006, 10:34 AM   #14
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
They should be there. Look at the pics posted in that link and then look at your car. You don't have those?
garface is offline   Reply With Quote
Old 01-09-2006, 12:42 PM   #15
ninethreeeleven
Member#: 99777
Another note. The torsion bars in a Wingless WRX vs a Winged WRX are different.
I did not switch with the guy (didn't feel like it I guess). My trunk flies open while his has to be manually opened. So you should probably switch the bars as well, but it's not that bad if you don't.
Old 01-11-2006, 08:41 AM   #16
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Impreza GC8
Originally Posted by Sti-lysh
...instruction out for trunk swaps? ...
WAaaaaa!!!
You did not mention what you were swapping for, winged, wingless, carbon, or any other type of trunk in particular. You did not mention anything about springs either. You just stated trunk swap. For that scenario it is literally just as I described. You get what you ask for. Perhaps you should write what you mean not what you are thinking. As your post was vague, you got a vague, albeit, smart ass answer.
Don't be so sensitive. It's not that serious.
Trunk Swap or Not Trunk Swap. This is the question... missiceblast Alaskan Impreza Club Forum -- AKIC 32 08-26-2009 03:58 AM
N00b JDM STi swap instructions? perret318 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-31-2005 07:26 PM
clutch swap instructions? sailil Mid Atlantic Impreza Club -- MAIC 5 08-03-2004 09:03 AM
Trunk and lock swap instructions? Fair Oaks STI Interior & Exterior Modification 2 08-16-2003 02:59 PM
Bring back the bumper swap instructions! AccidenT General Forum Archive 1 03-17-2001 12:33 AM
