![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 72859
Hey i ahve a set of rotas 17/7.5 and i want to run 235/45 tires its on a 03 wrx lowered bout an 1inch on eiback springs what do u guys think
#2 |
Member#: 35584
South East
Vehicle:1965 FFR Roadster Coyote + TR-6060 |
Wirelessly posted (Treo 600: Mozilla/4.0 (compatible; MSIE 6.0; Windows 95; PalmSource; Blazer 3.0) 16;160x160)
I run 225s on a wagon with 18s and people thought it couldn't be done without rolling the fenders. I'd say "yes you can run 235s" on the sedan. Keep in mind, if it is an issue, you can run more negative camber to compensate. I have mine dialed an additional -1deg in the front and -1/2deg in the rear. Then if you still have problems, try rolling the fenders. ![]() |
#3 |
Member#: 35584
South East
I forgot, your offset does factor in as well. I'm running Prodrive P1s 18x7.5 with 53 offset. |
#4 |
Member#: 35584
South East
I probably shouldn't be in such a rush... I also forgot to mention that every brand of tire is different. 225 Falkens are not the same as 225 Nittos in the same sizes. I hope this is somewhat helpful, and not more confusing. I say go for it, regardless. You still have options if you rub. |
#5 |
Member#: 91021
TXIC
Vehicle:1997 impreza red |
im running 235/45/17 on my car. but i have tein coil overs and i had to raise the car up a bit and also roll the rear fenders a bit.
car is a 97 brighton 2 dr with a ver2 rhd sti conversion. |
#6 |
Member#: 72859
hmm so anyone with a sedan running this size tire i mena i got 2 brand new tires for free this size and before i buy the other 2 wanted to make sure they would fit
#7 |
Member#: 104501
Vehicle:04 STI |
Yes thoes will work, i run 235/45/17s on my 04 STI, there more agressive then 225s and work fine.
#8 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
a 225/45 or even 235/40(what I run) would be a better choice as the WRX gearing sucks anyway and a taller tire(235/45) makes it even worse.
| Thread Tools | |
| Display Modes | |
| 235/40/18, will they fit? | carfan | Tire & Wheel | 10 | 03-10-2006 02:32 PM |
| SCCA: '02 WRX in STX -> 245/45-17's will they fit? | Sporqster | Tire & Wheel | 14 | 10-07-2005 06:01 PM |
| 235/40/17 Will They Fit? | Cronos | Texas Impreza Club Forum -- TXIC | 7 | 03-11-2005 11:09 PM |
| 225/40/18 wheels with 45 offset: will they fit/rub? | anthonyrb98 | Tire & Wheel | 2 | 02-20-2005 11:33 PM |
| 235/45/17 Will fit WRX right? With Rota 17x8? What tire? | neuspeed | Tire & Wheel | 3 | 09-04-2004 08:12 PM |
