Old 01-08-2006, 01:10 PM   #1
poruki
Member#: 68792
Default Ej21 ??????
Has anyone ever put an EJ25 crankshaft into an EJ205 engine ??
Give you 2100 cc.
poruki is offline   Reply With Quote
Old 01-08-2006, 01:28 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yep,
Most of the tuner shops like Crawford, Cobb and Axis actually refer to is as a 2.2l stroker...
Old 01-08-2006, 01:56 PM   #3
kheff46
Member#: 66739
2002 WRX wagon
any difference with putting that crank (or sti 2.5L if possible) in to the ej20K? any difference in bearing types that may not work right?
kheff46 is offline   Reply With Quote
Old 01-08-2006, 02:05 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
Ej20K is phase I, so you would need a phase I Ej25 crank. Or, as Crawford does on the Ej22T's that they stroke, you can remachine the block to accept a phase II end thrust crank...
Old 01-10-2006, 09:58 AM   #5
kheff46
Member#: 66739
2002 WRX wagon
either better(more reliable) with higher revs or boost? thanks!
Old 01-10-2006, 12:17 PM   #6
poruki
Member#: 68792
Well if nobody wants to admit to trying this combo, then
I'll have to do it and can claim to be the ONLY 2100 cc
EJ engine in existance.
It will be carbed (Webers) & cammed and go into my Porubi
http://www.projectaerosol.com/porubi/
Old 01-10-2006, 01:31 PM   #7
steve_d
Member#: 315
cool.
I don't have enough parts laying around yet to do it...why not do it to a 2.2L block? then you'd have 2300 CC's.
BTW wayne, www.porscharu.com/forum is up and running...come over and play. (except for the fact that we're transferring servers today)
sjd
steve_d is offline   Reply With Quote
Old 01-10-2006, 02:14 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
Wayne,
Did you miss the first reply to your thread? It's been done many times...
And I am sad to say that I won't be owning a Porscharu anytime soon. I sold the 914 this last weekend...
Old 01-10-2006, 03:13 PM   #9
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
can we assume that 2.0 to 2.1 would produce 5% additional HP with all other variables being the same? That simple?
Streetman is offline   Reply With Quote
Old 01-10-2006, 05:20 PM   #10
poruki
Member#: 68792
Yes Matt, I saw your reply, but the 3 businesses that you refered to only
mention stroked 'EJ22' and no mention of a stroked 'EJ20'.
Did the jackstands go with the 914 ?
Old 01-10-2006, 06:29 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
It can be a little deceptive when looking at their sites. A lot of the consumers who are not in the know don't realize that they are just taking an Ej20 block and adding an Ej25 crank to the mix.
And nope, the jackstands didn't go with the 914. They will shortly have a good home under a 1970 911T targa. The engine is too fresh to even consider an EJ based engine swap. It's going to be a restoration type build that will eventually be given to my father as a birthday present for his 60th birthday in a couple of years...
Scoobyclinic, The **EJ21 PROJECT** JAKbauer24 Member's Car Gallery 11 09-06-2009 07:29 AM
