Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 01-08-2006, 05:49 PM   #1
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
Default Counter measure to rear diff noise...HELP
http://techinfo.subaru.com/html/dis...sp?doc_id=79712
Service Bulletin #03-55-05
Pages: 2
Bulletin Description: A countermeasure has been made to address noise coming from the rear differential area. The noise may make a high frequency Hoo (Harmonic) noise and is most noticeable with little to no throttle application (coasting or deceleration). The peak of the noise occurs at 63mph (100km/h). The noise may occur in any gear or engine speed; however it is most noticeable in 4th gear (4EAT equipped) or 5th gear (5MT equipped). Dynamic dampers were added to the rear differential member to eliminate the noise. If you encounter a customer complaint prior to the countermeasure, follow the procedure on page 2.
I have this problem like crazy, dealership has never heard of it, any idea or links to page 2 procedure? thanks.
bren wrx is offline   Reply With Quote
Old 01-09-2006, 03:32 AM   #2
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Try this: Keep the front tires 4psi higher than the rear. Just a change in tire pressure can often make the difference. The '02s had issues with the clutches and such making noise but I believe the rear diffs were a bit noisy and thus a co-culprit.
-Biggly
DrBiggly is offline   Reply With Quote
Old 01-09-2006, 07:23 AM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
That bulletin appears to apply to 04+05 cars - anyway, here's a link to it on Scoobymods
http://www.scoobymods.com/forums/showthread.php?t=5275
Old 01-11-2006, 04:50 PM   #4
subieworx
Member#: 47769
This is a well documented problem on the 04/05. I am finally taking my car in tomorrow to have it looked at. Hopefully they don't mind the mods.
subieworx is offline   Reply With Quote
Old 01-11-2006, 05:18 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
HAHA!!! You are so screwed!!
Edit: See, they totally treated you like garbage. Stupid local dealers. Good thing Jamie is so helpful so you can get the part at a decent price. Big thumbs up for Subie Gal!!
Old 01-21-2006, 02:16 PM   #6
mpbikerxt
Member#: 78050
2005 STi
-Biggly
keep the tires 4 psi higher in the rear??? even the factory recommends 30 rear 36 front - this can be found on doorsill and in the owners manual... i have 245/45/17s all around on my 05 sti and i keep them at 45 front 40 rear for my day to day stuff... all the weight is on the front - dont know why you would want more air in the rear... if there is a noticable noise - that should def. be a warranty issue... it would be total b.s. to contradict what the owners manual says just to make the vehicle act and sound how its supposed to ... thats a warranty issue for sure man... i wouldn't mess around w/ your tire pressure that much... dont get me wrong - try it out - but you will be sourly disappointed in the traction you get thereafter..
mpbikerxt is offline   Reply With Quote
Old 01-22-2006, 09:57 PM   #7
sparco
Member#: 4977
01 2.5 RS
Default Problem with GC8
Well if you play with front and rear pressure you could effect some balance between all the diff's and drive line. But for handling, an increase in front tire pressure would induce more understeer, as increased rear pressure would induce some over steer. Old autocross trick I learned the hard way once.
Now for my some what related question. I just installed wrx 5spd drivetrain. After a few hundered miles I started having this same problem and it really kicks in at around 63 mph like the bulletin said. Now when I was staring blanklie at my rear carrier when it was up on the lift, I noticed the dampners installed on my GC8 carrier. Now would any one know if there was a diffrence between the balancers on a GC8 vs. the newer carriers?
I'm not sure if I should take the 25 mile highway trip to my nearest subaru dealer or if I should just try removing the current balancers and keep my fingers crossed that the insane noise will go away?
Any ideas?
Thanks
Danny
sparco is offline   Reply With Quote
Old 01-23-2006, 08:15 AM   #8
subieworx
Member#: 47769
Re-read what he said. You got it backwards.
Old 01-23-2006, 06:10 PM   #9
Jasper
Member#: 80136
2006 Ford F-150
i still say you try my idea i said on AIM. its wayyyyyy cheaper than ALL dealership options, and if it doesnt work, you're only out $10. total...including changing the rear diff fluid.
Jasper is offline   Reply With Quote
Old 02-05-2006, 12:16 PM   #10
strohausii
Member#: 26770
'02 WRX
midnight black
strohausii is offline   Reply With Quote
Old 02-24-2006, 01:52 PM   #11
mikeyc
Member#: 32338
03 WRX Wagon
JasperSTI, any chance you'd feel like sharing your idea? I'm curious to see if it'll fix the noise I've got out of my WRX rear diff.
mikeyc is offline   Reply With Quote
Old 02-24-2006, 02:05 PM   #12
Turn in Concepts
Member#: 93646
Many Track Records
I have the new crossmember dampeners to install. Hopefully that will help.
Old 02-25-2006, 10:21 AM   #13
Jasper
Member#: 80136
2006 Ford F-150
im on my way out of the house right now (stupid open house thingy), and wont be back for a couple of hours. drop me a PM w/ your AIM screenname and i'll tell ya all about it.
Old 02-26-2006, 11:04 AM   #14
subieworx
Member#: 47769
Well, the new damper things looked identical to the old ones and only slightly lowered the noise level, but by no means eliminated it.
Old 03-06-2006, 04:10 PM   #15
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
oh really?
im going to install mine soon, ill drill my stock cross member for them to fit
Rear Diff noise 2007 STi (Andrewtech thoughts?) (not normal noises they tend to make) rxer311 Transmission (AT/MT) & Driveline 74 03-01-2016 01:30 PM
Rear Wheel Bearing vs. Rear Diff Noise? turbobird14 Transmission (AT/MT) & Driveline 7 03-11-2008 10:44 PM
Rear diff noise? Help please... GeeCee8 Transmission (AT/MT) & Driveline 0 06-18-2006 04:39 PM
Rear diff noises scooby5 Transmission (AT/MT) & Driveline 12 12-18-2003 08:50 AM
Rear diff noise, NOT! Grap Mid Atlantic Impreza Club -- MAIC 1 08-07-2001 10:48 AM
