Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 01-09-2006, 12:05 AM   #1
JDM 3SGTE
Member#: 35479
Default timing needs retune after changing to colder plugs?
i changed my plugs tonight to one step colder, copper, ngks gapped at .028. i had planned on going out to tune later in the week to advance a little more timing. well i took it out for a spin after the install, just to make sure everything was running ok. first thing i noticed when i started the car was that the idle was noticably smoother. second thing i noticed was that the car felt slower. i spent a few nights last week tuning so what it felt like before the colder plugs is still fresh in my mind.
i knew the colder plugs would give me more room to advance timing here and there but didnt realize they would change how the car felt otherwise. will i not be reaping the benefits of colder plugs until i retune my timing map??
another thing, saw this on scoobymods after i was done with the install.
"Also, remember to reattach the ground wire on the passenger side coil screw. I think it is somthing easily forgotton as I did and then you will have to remove your airbox to reattach it."
i dont remember unattaching a ground wire when removing either of the passenger side coilpacks. what ground wire is being refered to here? if i did remove a ground and forgot about it, i figure that could be the problem.
JDM 3SGTE is offline   Reply With Quote
Old 01-09-2006, 01:53 AM   #2
wall of tvs
Member#: 29716
2006 wrx wagon
booze powered e85 monster
I just replaced my plugs last weekend, and NEVER saw anything that resembled a gound wire attached to any of the coilpacks.
There is, however, a bracket that routes the front o2 sensor wire that is held in place by the bolt for the #3 coilpack on the pass. side.
2004 WRX
wall of tvs is offline   Reply With Quote
Old 01-09-2006, 04:12 PM   #3
JDM 3SGTE
Member#: 35479
my stock plugs were gapped at .032 and the new ones are gapped at .028.
Old 01-09-2006, 04:36 PM   #4
Freon
Member#: 88322
2009 BMW 135i
I'd think a colder plug would idle worse and perform better under high load... ???
Freon is offline   Reply With Quote
Old 01-10-2006, 09:08 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
crazymikie changed plugs and had to retune. maybe he can chime in. iirc he got some knock where he did not previously have any.
Old 01-10-2006, 07:27 PM   #6
bboy
Member#: 56468
04 Improved STI
Dirty White
Read that jblaine thread too, he talks about the "noise" increase he saw on knock sensor with colder plugs. It was a wierd thread.
`do You Need Retune After Installing Catch Can Set To Atmosfere casper64 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 42 08-21-2009 01:39 AM
Rough idle after changing out spark plugs, help? ctkeith Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-07-2009 08:57 AM
STG2+ STi: any benefit to colder plugs & fuel pump? overdose Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 05-07-2007 03:21 PM
Whining noise after change to stock BOV STIRS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-30-2006 05:11 PM
Knock after 1-step colder plugs? SJwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-22-2003 03:40 AM
