01-09-2006, 12:43 AM | #1 |
Member#: 35313
Vehicle:Spry Forester Silver Spark |
JDM V7 STi TMIC vs USDM STi TMIC
So the reported difference is 15% larger for the JDM V7 over the USDM STi intercooler. Where is this difference accounted from? I have counted the finds and both intercoolers have 34 external rows of fins and 32 internal. So I am assuming the width is the same. I am just wondering if it's thicker or taller from front to back. Does anyone have any measurements?
Thanks, Justin I did a search (multiple ways) but keywords like "JDM" and "V7" always get washed out. Maybe I just don't know how to search better, lol.
01-09-2006, 12:48 AM | #2 |
Member#: 2258
Vehicle:1999 gc8 ver7 6mt GT35R 504.7whp;) |
It's taller by a visually noticeable difference.
Louis |
01-09-2006, 12:49 AM | #3 |
Member#: 54672
It is taller front to back by about 0.625(15mm?), I believe because the JDM's aren't DBW.
I would like to know what kind of pressure drops these TMIC's have? Anyone? Sorry about the thread highjack.... |
01-09-2006, 08:26 AM | #4 |
Member#: 35313
Ok, so JDM's aren't DBW, but they will fit a USDM STi right? I am thinking of putting one on my 2004 STi (US)
01-09-2006, 08:48 AM | #5 |
Member#: 54672
I believe you would need to modify the brackets. When they lengthened the IC, they also changed the position of the mounting tabs on the sides, rather than changing the brackets.
01-09-2006, 10:10 AM | #6 |
Member#: 51370
RMIC
Vehicle:a leaf, a yamie DCAWD |
Just out of curiosity, why are you swapping to a *slightly larger* TMIC? Any particular reason? Are you just looking for some slightly increased cooling headroom? What are your power goals? Will the car be tracked at all? For example, I try to track my car as often as possible, so ANY TMIC wasn't enough for me, I ran into constant heat-soak problems after just a few laps. Moving the IC out of the hot engine bay really seemed to help keep intake temps cooler, longer.
Now if you don't track the car, but plan to upgrade teh powAr, I might look into something larger than any of the OEM TMIC's. But if you're just going to keep things pretty close to what they are now, you should be fine for daily driving and autocrossing. Just my .02USD, ymmv, restrictions apply. |
01-09-2006, 12:56 PM | #7 | |
Member#: 35313
Justin |
01-09-2006, 01:16 PM | #8 |
Member#: 88322
Vehicle:2009 BMW 135i |
Thermal dispersant? Ya know bare aluminum is actually a very effective material for air heatsinks... I'd have to see some pretty convincing evidence to coat an already highly effective surface with another in hopes of an efficiency improvement.
01-09-2006, 01:43 PM | #9 | |
Member#: 35313
01-09-2006, 02:31 PM | #10 |
Member#: 54304
South East
Vehicle:04 STi TopSpeed-dAng! |
Can you run an auto IC sprayer?
I assume that heat wrap / shields are open in SP? I would wrap and spray rather than buy a 15% bigger core. |
01-09-2006, 02:35 PM | #11 | |
Member#: 35313
01-09-2006, 02:51 PM | #12 | |
Member#: 51370
RMIC
J, I'm not too familiar about the thermal dispersant you speak of, so I wouldn't be able to offer an opinion. As far as JDM TMIC vs. Perrin or TXS or APC or whatever brand TMIC, In that location, on an STi, they're ALL a PITA to get in and out. My next question would be a cost/benefit analysis of JDM TMIC vs. brand X TMIC. Which one flows the best, has the greatest cooling efficiency, the lowest pressure drop, etc for your money. Of which I'm sure there are plenty of opinions here on Nabisco. If you're shooting for 350awhp on C16, I'm assuming your class allows boost modification and engine management. That being said you should be able to get close to those numbers, but the VF39 really starts to run out of breath at those levels. If you are allowed I would probably recommend an upgrade like the 20g. Same boost response as stock, MUCH better top end. Also you wouldn't lose anything on the bottom end either. (Slightly unrelated to your question, but worth considering) Also, are you allowed to run an IC sprayer? I would think that can become a significant helper as well. Water reeeeely helps fight heat soak and would extend the cool periods for your runs. You might even consider the 12L JDM bottle (mounts across the back seats). But I agree with javid, et all. I probably would not spend my money on a 15% bigger core. For a little more (or less if you can find one used) you can get a lot more internal volume. From what I've read even the eBay TMIC cools pretty darn well. Hope I gave you a few things to think about, or even pointed you in new directions. Colin |
01-09-2006, 05:32 PM | #13 |
Member#: 62221
a 20g will have the same repsonse and boost characteristics as a stock STI....that means stock eninge and ECU....not sure if thats what u meant colin. A stg2 STI tuned with its vf39 will spool a good 500-600rpm before the 20g....maybe even more. I think the vf39 would be better for autox.
01-09-2006, 05:58 PM | #14 |
Member#: 51370
RMIC
My concern was his 350awhp requirement, that's why I suggested the 20G. And properly tuned it's pretty darn close to the VF39. I think 600 rpm might be overstating it a bit, but I guess that's also dependent upon the tuner as well.
Don't get me wrong, for autox the 39 is a great turbo, with fantastic response. |
01-09-2006, 06:06 PM | #15 |
Member#: 35313
350awhp is a goal, and I am being optimistic with the C16, on pump and the drive around tune it will not be a reqiuirement, maybe somewhere around 300-310whp for daily driving on pump gas. Basically I plan on using C16 for 15 minutes every weekend, lol, for autocross. I cannot change turbos in StreetPrepared. I was just thinking the JDM would fit the best, be a little bigger and may work better with the dispersant than my stocker STi for ~200$ difference.
01-10-2006, 09:06 AM | #16 |
Member#: 50891
For $300 buy an ssautochrome TMIC core (over 700 c.u.) or get the core, bov and piping for $400. (ssautochrome.com)
01-10-2006, 10:47 AM | #17 |
Member#: 35313
I already have one. I plan on testing it vs. my stocker in the near future with true bench testing.
J |
01-10-2006, 08:51 PM | #18 | |
Member#: 45323
Vehicle:MY05 Impreza WRX STi Pastelito Racing & SFSOC |
01-13-2006, 03:16 PM | #19 |
Member#: 35313
Does anyone have the Subaru Part number for the V7 JDM TMIC? Or ways to identify via pictures it's the real deal?
thanks, Justin I also notices the V8 is missing some of the top section, it looks like that might help distribute air through the IC better. J Last edited by crystalhelix; 01-13-2006 at 03:40 PM. |
JDM STi r180 vs. USDM STi r180 (6 speed) | garface | Transmission (AT/MT) & Driveline | 9 | 03-26-2011 01:38 AM |
AutoDynasty TMIC vs. USDM STi TMIC | davidm_sh | Car Part Reviews | 28 | 03-01-2007 06:16 PM |
WTB: JDM V7 gauge cluster/ V8 USDM sti cluster | rb22b | NESIC Private Classifieds | 0 | 01-02-2007 08:44 AM |
WTB: complete DCCD module (switch, harness, etc...) for JDM V7 or V8 or USDM STi | V6 | Private 'Wanted' Classifieds | 0 | 05-13-2005 01:06 AM |
jdm ver 7 tmic vs. usdm sti tmic | showcasewrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 05-09-2004 08:45 PM |
