Old 01-09-2006, 02:10 AM   #1
jrmsti
Member#: 103675
Subaru Stars widest tires
does any1 now the widest tire u can fit on 05 sti all round or just the on a a 17 inch rim?
jrmsti is offline   Reply With Quote
Old 01-09-2006, 03:14 AM   #2
shane86
Member#: 67387
04 WRX - STX
05 LGT Limited Wagon
that's a pretty broad question....
The pretty standard "BIG" tire for the WRX/STIs wind up being 245/255s.
But.... i think some A Stock STI guys have squeezed 275 Hoosiers on their stock wheels. wouldn't recommend that for the street...
shane86 is offline   Reply With Quote
Old 01-09-2006, 02:25 PM   #3
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
there is a big thread in the motorsports thread.
but the Cliffnotes are 255/40 17 is about as wide as you want to run on the stock wheels.
I have the 255 rt615s on my car and i'm lowered on STi pinks, fits like a dream.
Rumor has it that a 48mm offset and 255s lowered on pinks doesn't fit.
the stock +53mm offset works perfectly.
WRX8XB is offline   Reply With Quote
Old 01-09-2006, 02:42 PM   #4
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
275's will work on a 8 inch wide wheel on a stock STi, but needs to be a 48 offset. The stock 53 offset would rub against the strut. As WRX8Xb said i would not run anything more than 255's on the street on stock size wheels.
rankink is offline   Reply With Quote
Old 01-09-2006, 07:11 PM   #5
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
8.5" wide +45mm lowered on Tein S-tech, 265/35.........so dreamy
JDM addict is offline   Reply With Quote
Old 01-10-2006, 06:39 AM   #6
jrmsti
Member#: 103675
thanks for the help but i will not being them on a stock wheel as i'm going to get a set of bbs lm's rim so tucking tire wld not be an issue.
Old 01-10-2006, 08:31 AM   #7
subieworx
Member#: 47769
255 Falken 615's will rub when lowered on an 04 with 17x8 et 48 wheel. May fit on an 05 though. As others have said you really don't need more than 255 for the street.
subieworx is offline   Reply With Quote
Old 01-10-2006, 08:55 AM   #8
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
BBS LM's won't fit, unless you're talking about the JDM-specific ones. Find the wheel you want, post the size and offset, and we'll tell you what we think will fit.
UltimateLurker is offline   Reply With Quote
Old 01-10-2006, 12:50 PM   #9
Farnsrocket
Member#: 83567
08 Outback
Obsidian Black Pearl
I wanna chime in here. I have an 02' WRX with 8.5" Advan RCII's +48 with Bridgestone Potenza 245/40-17's, lowered with JIC's.
The rears just edged the fenders and after some hard driving you could see small, spaghetti like rubber on the outer corners of the tires. Well, I rolled my fenders this fall and they have not rubbed since.....I probably gained 5/16" of clearance.
I was wondering if I could get some 255's in there? Anyone have luck with this width and are the STi fenders different from the WRX? Thanks!
Farnsrocket is offline   Reply With Quote
Old 01-10-2006, 01:08 PM   #10
jruben4
Member#: 50784
2005 STi
I was planning on a 17x8.5 wheel, 48 offset w/ a 255/40 tire; On a 05 sti stock springs. Should fit, right? I thought I'd do 255 the first set of tires, and if there's plenty of room try 265/275 next time...
jruben4 is offline   Reply With Quote
Old 01-10-2006, 01:48 PM   #11
subieworx
Member#: 47769
You could prrbably fit 255's, but it will depend on what 255's you are talking about. Some are wider than others. The 04 sti fenders are the same as the wrx's. The 05 on sti have wider fenders in the rear.
Old 01-10-2006, 01:48 PM   #12
subieworx
Member#: 47769
On stock springs you should be fine, but again it depends on the tire you use.
Old 01-10-2006, 03:17 PM   #13
Farnsrocket
Member#: 83567
08 Outback
Yeah, I have been comparing tread widths of 245's and 255's and some are quite different, by as much as .4"
All the Bridgestone Potenza models I looked at seem to be the wider than a comparably sized Falken Azenis, except for the new Azenis 615....it is consideraly wider.
Thanks for the info!!!!
Old 01-10-2006, 04:49 PM   #14
titsataki
Member#: 4402
2009 Outback XT
Anyone tried Michelin Pilot Sport in 255/40/17's on the stock 05 rims with JDM pinks?
How is the fitment and how is the noise?
Nick
titsataki is online now   Reply With Quote
Old 01-12-2006, 08:02 AM   #15
mx_9
Member#: 36138
2004 STi
Do you autoX with that setup? Also, did you roll the fenders or do anything else to make them fit? Any rubbing?
I have an '04 as well and have been hanging back on buying 245's for the stock rim as it appears that I'd rub with the lowering that the JDM pinks gave me.
mx_9 is offline   Reply With Quote
Old 01-13-2006, 01:11 AM   #16
JustinWRC
Member#: 34299
2004 STi
im running 255/40's on 17x8 w/48 offset with no rubbing (now) cutting rear fenders fronts fit fine. jic flta2s lowerd about 2'' front 1.75'' rear. tires will almost always fit just depends on how bad you want them too
JustinWRC is offline   Reply With Quote
Old 01-13-2006, 08:19 AM   #17
WRX8XB
Member#: 45323
the fender its self isn't wider, there is just less metal on the "lip" (the part people usually roll.
Old 01-13-2006, 10:40 AM   #18
UltimateLurker
Member#: 82488
06 Lotus Exige
Storm Titanium
Exactly. The inside lip provides structural integrity and a convenient place to put spot welds, but the '05/'06 STi's don't have the lip at all, the quarter panel comes straight down and stops, so there is an extra bracing piece added to the outside (ugly IMO). Funny thing is, there is no way in hell that the stock suspension/wheel/tire combo would ever touch this area, even under super aggressive driving, so they made the change to allow after-market spring/wheel/tire combo's. Bravo Subaru!
Old 01-14-2006, 03:10 AM   #19
z71amigo
Member#: 71430
2005 STi
i am getting 255/40/17 mounted on my stock wheels on monday. I will take some pictures and let you know how they fit. BTW i am stock height.
z71amigo is offline   Reply With Quote
Old 01-14-2006, 11:28 AM   #20
austinpike
Member#: 11279
2o11 wrx dgm
2oo8 tribeca swp
section width is where the rub happens, Pilot Sport Cups go up by .9" from 245 -> 255... they are practically a 275.
which tires? Looking forward to pics...
austinpike is offline   Reply With Quote
Old 01-14-2006, 01:12 PM   #21
z71amigo
Member#: 71430
2005 STi
BFGoodrich KDW2
Need tire help - widest tire on 17x8 wheel? Zspectrum Tire & Wheel 17 11-04-2007 03:05 PM
widest tire for a 17x7.5, yes, another tire question Machine Age Victim Tire & Wheel 18 04-13-2007 01:25 PM
Widest tires on stock 2001 RS 16" Wheel?? ITR&RSGUY Brakes, Steering & Suspension 3 07-25-2001 03:49 PM
Widest tire size? recommended on WRX ? DarkLite Brakes, Steering & Suspension 3 04-23-2001 12:46 AM
widest tire on a BG5? sybir Legacy Forum 3 04-16-2001 06:53 PM
Message Board Statistics All times are GMT -4. The time now is 10:06 PM.
