Old 01-09-2006, 09:11 AM   #1
jgheels2003
Member#: 64562
2012 Boss 302
Default Blow-through MAF set-up
The car runs so smooth (STi 380whp DB 20g, FMIC on pump Ecutek tuning done by Doug at Topspeed). Thought you might like to see its placement etc.
jgheels2003 is offline   Reply With Quote
Old 01-09-2006, 10:50 AM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
is bov befor or after the maf?
Old 01-09-2006, 11:48 AM   #3
jgheels2003
Member#: 64562
2012 Boss 302
The maf is after the turbo/bov on the charge pipe. Instead of being at the intake charge location and venting metered air, the air that is now blown off with the throttle closed isn't metered.
Old 01-09-2006, 02:51 PM   #4
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
cool thats where it should be
just wondering how much bounce(squiggle) you get in maf voltages as the bov opens -probblay depends on how taught the spring in the bov is
Old 01-09-2006, 03:10 PM   #5
jgheels2003
Member#: 64562
2012 Boss 302
Good question. The HKS isn't the easiest opening bov by any means, but w/o question it holds boost better than anything I've used. I'm not sure how much the voltages fluctuate (I could ask Doug/tuner) but its amazing how smooth the car rides.
Old 01-09-2006, 03:41 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 5MT EJ22T AWIC Swap
I'd be curious to know how well the MAF holds up in the long run with the more turbulent & hotter intake charge.
Legacy777 is offline   Reply With Quote
Old 01-09-2006, 03:51 PM   #7
jgheels2003
Member#: 64562
2012 Boss 302
Good question. Its now on the colder side of the intercooler piping (large FMIC) though after previously placed directly after the foam filter on the short ram intake. Short rams can get waarm, so if this intercooler is doing its job I'd think it would be ok.
Blow through maf /rec. BOV set up. 03twrx Factory 2.5L Turbo Powertrain 11 09-12-2010 06:19 PM
FS: Intakes and blow through maf - Perrin short ram, BIG maf, K&N.... 2theMAX Private 'For Sale' Classifieds 12 02-15-2006 12:19 AM
Blow through maf set up majnthr33 Mid West Subaru Owners Club Forum -- MWSOC 9 09-19-2005 10:01 AM
Blow Through MAF users! Javier Factory 2.5L Turbo Powertrain 6 07-29-2005 10:15 AM
Blow-through MAF Sensor serendipity Factory 2.5L Turbo Powertrain 85 06-23-2005 08:32 PM
Message Board Statistics All times are GMT -4. The time now is 05:56 PM.
